Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
Can't backup files on computer
After cleaning Windows One Care from my computer I now cannot back up my computer I get error mesage 0x80040154 I think my registry has been corrupted.
  • 50 Answers
Try system repair or restore.
Posted on Feb 09, 2009
Windows xp backup utility
1st possible solution: Check your hard drive(s) and partitions for errors. You can do this by going to My Computer > right click on a drive > Properties > 'Tools' tab > Check Disk or Check Now
2nd possible solution: You may have backed up your files from an NTFS system and are trying to restore to a FAT32 system. If so, convert your computer to NTFS by right clicking on 'My Computer' > Manage > Storage > Disk Management> Right click on your primary drive > and select convert to NTFS.
Jul 07, 2013 | Computers & Internet
Computer wanted to to backup files. I received a message, "The back-up did not complete successfully". "An error occurred. The following information might help you resolve the...
please clarify a little to what program did you use to backup files or which program wanted to backup files, also which windows do you have?
Add a comment and il help you.
Aug 18, 2008 | Computers & Internet
Need command prompt for Acer Aspire
The Windows Backup and Restore feature allows you to save files and system images to external backup devices such as hard drives and flash drives. However, backing up files become problematic if the directory your backing up files from isn't configured properly, or if you're having issues with the devices you're backing files to. There are ways to solve or work around backup problems quickly and safely.
Hard Drive b> A backup will not complete if the files you're backing up exceed the amount of space left on the external hard drive. If you're backing up large system files, Microsoft recommends saving the backup to an external hard drive that can hold at least 200 GB. If you're running out of space, you must delete content to create space for others or use another hard drive. Error Codes In some cases, Windows displays the following error codes when it's unable to complete a backup: "0x80070001 (Invalid Function)" or "0x81000037: Windows Backup failed while trying to read from the shadow copy on one of the volumes being backed up." These error messages usually appear if Windows is unable to backup a specific library or if you opt out of adjusting your backup settings and settle for the default settings in the Windows Backup and Restore Feature. Reparse Point b> If you're unable to backup a specific library and run into error code messages, removing the reparse point allows you to complete the backup. A reparse point is a file that contains information about the user on a computer. If it doesn't point to a location that contains some of the data you want to backup, error messages appear when you try to back up your files. Type "CMD" in the Start Search box to open the Command Prompt. In the Command Prompt, typing "DIR /AL /S" and pressing Enter lists the reparse points. Each entry says "JUNCTION," which also means reparse point. The entries also tell you the location of the reparse points in Windows Explorer. If you locate a specific reparse point in Windows Explorer, delete its mounted volume from the device's Properties. Once deleted, you should be able to back up your files. Discs b> If you're backing up files to a disc, you'll run into problems if the discs are non-rewritable and already contain data, or if they are severely scratched or damaged. Non-rewritable discs can only be used once, while rewritable discs can be used to read and write data several times. If the CD or DVD you're using is severely scratched, the optical disc drive spins harder than usual in an attempt to read it. If it's incapable of reading the disc, the backup feature may freeze or display an error.
Windows backup or restore errors 0x80070001, 0x81000037, or 0x80070003
http://support.microsoft.com/kb/973455 - workaroundissue12
Apr 20, 2013 | Computers & Internet
Windows 7 error code 0x80040154 in backup and restore
What is H Drive? You want to change it to what? C drive? Can you clarify. Perhaps this will help: http://support.microsoft.com/kb/979281
Apr 15, 2013 | Computers & Internet
Windows cannot open the back up files
This error mostly comes when the bkf file is corrupt, BKF file may gets corrupted due to virus attack or interruption during backup process. You can repair your corrupt or damaged bkf file with the help of bkf repair tool. Download a good bkf repair tool from http://www.restorebkf.org/
Nov 01, 2012 | SimpleTech Computers & Internet
My computer will not let me install WindowsVista. Error code 0x80040154. Can U help?
This is a common but harsh error to get tackled. This is one of those generic "no one knows" or "has a thousand fixes-and none work for you" errors. In outlook it comes up as "unknown error" which is very frustrating. But sometimes you might get lucky. Try following this link:
http://0x80040154.com/
Towards the left side of this page, you will find the Fix procedure. Not sure if it would work for you. Thankfully it did for me.
Hope this one solved your problem. If you have additional doubts, please come back to us.
P.S: If the solution is helpful, please accept the solution.
Regards,
Sunny.
Sep 02, 2011 | Computers & Internet
My Operating system is going slow day by day
i suggest you do a maintenance task.
1. Defrag your hard drive
2. Do a disk cleanup
3. Check the disk for errors
4. Use utilities like Ashampoo Winoptimizer
5. Delete unnecessary startup files
6. scan your computer for viruses.
7. Upgrade your memory or change your processor.
Its all maintenance and tweaking tips.,^_^
Aug 07, 2009 | Microsoft Windows XP Home Edition
Error 0x80400005
First of all you can try to reinstall the pc suite,
also try the followings -
- try creating backup (file) to different location
- try changing backup content (e.g. first only contacts etc.)
- if there is memory card in device, exclude card content from backup or even remove memory card from device and try backup again..
Good Luck!!
Apr 06, 2009 | Nokia 6680 Cellular Phone
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
32 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
