Question about Lenovo ThinkPad T61 Notebook
Cant get online
It does the scan but comes bak with cannot find servers message....im using a normal wired modem, not wireless When trying to access mysoftware I get the error message that the web site cannot be located
  • workhard Mar 21, 2009
    i use a wireless router, linksys, which is connected to my desktop. my laptop says 'cannot find server'
  • Josh Marquez May 11, 2010
    Is your laptop plugged into a AC Adapter? Some laptops disable the internal network card when they are unplugged in order to save on power consumption.
Why does it keep timing me out on gta5 while online?
Matthew, check your NAT type. For live games like GTA5, it needs to be set to "open" If it's type 2 then media is being sent, but blocked when coming in. Limited communication with the servers. It's usually caused by the wrong settings over a wireless connection. If you use a cat5 "hard wire" from your modem directly to your system, it should report back "open"
Aug 21, 2015 | Sony PlayStation Portable (PSP) Console
Im from d Philippines, im currently seting up my Linksys wireless-G WRT54G Router, after entering the password it says "Setting up router" then the next message would be "checking internet connections" and...
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jul 20, 2010 | Linksys Wireless-G WRT54G Router
Hi, Im getting a message that there could be problems with my network adapters so I cant access the internet, what should I do?
Hi, Unplug your Modem/Router for 10 seconds, let it start up, if this doesnt work try using an Ethernet cable and plug it in directly (Wired). let me know, thanks. Mark
May 03, 2010 | Toshiba Computers & Internet
Why cant i access sites on my laptop it comes up with security certificate also i cant acess my email account on google its all new to me never used a laptop before and im not sure if it comes with any...
If you cannot access any website on your laptop check if you have interent connection first. Check if your laptop is set to connect using a proxy server check the Local area connection. If your using wireless check if you wireless setting is correct. Run ping test to determine your internet connection For windows click START > RUN > type ping yahoo.com if the message is reply from then your connected check you laptop security settings. If unable to connect or request timed out contact your internet provider
Nov 20, 2009 | Google Gmail
I have a wireless broadband router (802.11g) and as im trying to install it, it comes up with the message "there was an error reading the configuation file." please help.. all my connections are good.. i...
First make sure that the computer is able to go online when connected directly to the modem.
Once you are online with the modem , you can try to set up the router manually without the set up disc.
Click Here for step by step solutions
Nov 07, 2009 | Arris WA840GP 802.11g/b (51807400100)...
Belkin wireless problem
If you are connected straight from the modem, your router will not have internet access, only if your modem is connected to the router you will be able to go online wireless. connect your modem to the router nad router to the desktop, so that you can access both wired and wireless connection
Aug 12, 2008 | Belkin (F5D9230-4) Wireless Router...
Cant get online
im using a wireless modem, i keep getting cannot find server everytime i try to connect...how can i fix this problem?
Aug 08, 2008 | Sony Playstation 3 (PS3) Console
Cant get online or pick up a wireless network?
A couple of issues and questions
First generally a wireless router in installed onto a network either to the ISP's modem or to another router that is connected to an ISP's modem it is not connected on the wan side to a computer (unless that computer is acting as a firewall or proxy server to the internet). Computers are generally connected with a wire to the (optional) switch portion of a wireless router or wireless connection.
Have you tried testing with a computer wired to the router to assure internet access is possible without worrying about wireless issues?
If you are considering encrypting the wireless router did you test it unencrypted first to assure the unencrypted radio transmissions work?
Is the wireless communication encrypted for other computers you own and possibly not for the HP you are now trying to connect?
Are you sure the distance between the wireless router and the garage is not an issue. Perhaps you could test and configure the connection in the room with the router and when it is working move it to the garage.
According to the product specs for the HP Pavilion it has built in wireless B & G you did not include the router manufacturer and model does it operate on the either wireless B or G?
Dec 08, 2007 | Computers & Internet
Can't Connect to Internet
there is a need to reconfigure your router to work with your modem. If configured already before, then there is great chance that this has been set back to factory default.
Oct 06, 2007 | U.S. Robotics USRobotics USR5461 Wireless...
Lenovo ThinkPad T61 Notebook Logo
47 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
