Question about Dacor Preference SGM365SS Gas Cooktop
New lp gas reg needed
I need to know the part required to replace the lp (or ng)
regulator on a new Dual Fuel convection cooktop Kitchenaid slide in stove. Electric oven so only the cooktop has gas. New part from whirlpool very expensive, I assume that a generic regulator will do the job? Any help would be much appreciated.
Thanks
Michael
  • 10,865 Answers
Hello Michael - I recommend that you call your propane provider. They will be able to help you.
please rate my answer. thanks
Posted on Feb 12, 2009
Control knob doesnt adjust flame height?
Use a manometer to insure lp gas pressure is correct. The regulator for the stove may need adjusting. The air mixture adjustment may not be correct for PL as well.
Aug 18, 2014 | DCS Professional RDU305N 30" Pro-Style...
Cooktop not hot enough like before, the flaming is smaller than before
Your problem could be or probably is with the regulator...not enough gaspressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Oct 25, 2010 | KitchenAid 30 in. KGCS105GSS Gas Cooktop
Hi I am trying to convert my Dacor stove/oven from NG to Propane. We can't find the conversion kit anywhere. Any ideas?
Hi, to convert from NG to LP is easier in some ways but harder in others. The pressure part is easy because LP runs at the same pressure that comes into the house so the regulator is normally locked wide open to allow a direct by-pass. You could just as easily remove the regulator and plumb straight in from the houseline. You don't say what model but usually the sealed cooktop burners will need smaller orifices and the oven and broiler orifices are adjustable. If that is the case, the oven and broiler orifices can be tightened until they bottom out which be the correct output for LP. You would need to remove the cooktop orifices and find replacements which are correct for LP, these are non-brand specific. Honestly, if you go to repairclinic.com and enter the brand and model number, I'd be surprised if you couldn't find the conversion kit. Even the Dacor site should be helpful. I found many different kits available at the repairclinic.com site even without a model number. Best of luck.
Jan 29, 2010 | Dacor Preference SGM365SS Gas Cooktop
In this model of gas cooktop is the gas regulator inside the cooktop or outside? I got a open box deal without the gas reg. and wonder if it is inside or if I have to order one?
On most cooktops the regulator is installed externally and is not includes... if it is there it will be right on the pipe that you hook the gas too...
heatman101
Nov 12, 2009 | KitchenAid KGCC766RSS Stainless Steel Gas...
Converting cooktop regulator from NG to LP
LP is higher in pressure than NG, so regulator spring pressure has to be greater.
Aug 06, 2009 | GE Cooktops
I have a Dacor 48" ERD dual fuel range set for LP and need to convert it to NG. Dacor says "NO can do" I know it is not rocket science. Parts people such as appliancepartspros.com first say I need about 5...
If Dacor does not supply a conversion kit you may have big trouble changing it to natural. In addition to the burner valves you must change the orifices, the regulator, and venturi tubes. This would be quite a challenge. Good luck!
Jan 07, 2009 | Dacor Preference SGM365SS Gas Cooktop
Converting Dacor ERD30S06CH/LP/H to Natural Gas
I know they won't convert gas water heaters but I didn't know they were afraid of stoves. See if your gas company will help. Sometimes they can drill out the orfices. Some of the older repair people still remember how to do this. The orfice for natural gas is larger as the pressure is a lot less. The gas pressure regulator will also need to be replaced. This can be done with a generic part.
Jul 12, 2008 | Dacor Preference SGM365SS Gas Cooktop
KitchenAid 5 burner Cooktop conversion to LP gas
you need orifices for lp and the regulator should be convertable there is a "plug" thing in the middle of it that you remove and turn over and install
Apr 15, 2008 | Cooktops
Convert to LP?
If it is possible, then the orifice has to be changed. The regulator may need to be changed as well. I am a certified LP technician for recreational vehicles, but I don't know enough about this particular appliance to say for sure if it can be converted. The best thing is to contact Miele directly, but this sort of conversion always requires a different orifice. Note that propane, butane, and natural gas are all forms of LP (Liquified petroleum), so conversion between the 3 is usually possible
Oct 15, 2007 | Miele 35 in. KM326G Gas Cooktop
Dacor Preference SGM365SS Gas Cooktop Logo
169 people viewed this question
Top Dacor Cooktops Experts
jdthefixer
Mike
Mike
Are you a Dacor Cooktop Expert? Answer questions, earn points and help others
