Error code 31 on a konica royal 1500 ''paper mishandled''.
I removed all feed rollers and feed belt to clean and rough up surfaces but it still faults out with error 31. Sometimes it will work using manual feed tray. However, it still gives fault 31 most of the time. I wonder if there is a timing issue when removing the feed roller assembly.
  • Richard Smith Jan 23, 2009
    Thank you Cogz for your reply. Parts for this machine are hard to find so I am trying to restore the rubber rollers and belt with alcohol based cleaner and wire brushing to rough up surface. Paper actually starts into machine, goes about 80% of the way, stops for a moment then continues on into developer and stops just short of image drum. It is not wrinkled or deformed in any way. Problem is consistent stopping each time at same location.
    You do have a good memory! There was indeed two or three plastic gears I had to JB weld because of cracking. However, They are still holding and we have used the machine for several hundred copies since then. I will locate Precision Roller and try to order these parts. I also installed a new image drum, roller and cleaning blade. I also restrung the chare grid array with new wire. It worked like a brand new machine for a short while. I do have a service manual for the 7033 Konica but nothing for the 1500, not even a parts manual. Thank you for your help. It's an oldie, but a workhorse I am told.
  • 1,326 Answers
Have you replaced the paper pick up & paper feed & paper sep. rollers? Also, have you cleaned the paper pick up clutch? The reason it works with the manual feed is that it is not used as much. Also, have you cleaned the rollers with wd-40 or simple green and did it work better, if so you need new rollers. Good Luck
Posted on Jan 23, 2009
  • Chris Coughlin
    Chris Coughlin Jan 23, 2009
    You may want to try "Precision Roller" for the parts they may have them, you are dealing with a old copier. It has been a long time since I've worked on one, but I kinda remember a problem with jamming and it had to do with a gear in the back of the copier, it was a pain to get to, it is behind all of the stuff on the back of the copier, it may have been a torsion spring. May the force be with you to fix that one. LOL
Error J1
Hello Sharon,
When a document jam occurs, "J" and "1" will display alternately on the function number display panel of the scanner.Please perform the following:
  1. Remove all documents from the ADF paper chute.
  2. Open the ADF while pressing down the ADF open lever. If you are using fi-6130 with the imprinter option attached, please open the imprinter and then open the ADF.
  3. Remove the jammed papers from the ADF.
  4. Close the ADF pushing the center part of the ADF carefully.
If document jams occur frequently, please check the followings:
1. Do the documents satisfy paper specification?
2. Have the documents been jogged?
• Align the edge of documents for stable paper feeding.
• Remove documents with crease or dog-ear.
• Scanning different width of documents may cause skew and result in paper jam.
3. Are Chuter Unit (ADF paper chute),Guide P ASSY (Sheet guide), Feed roller cover (plate guide) and Brake roller cover installed correctly?
4. Clean the Feed rollers, Eject rollers,Plastic rollers, glass surface and paper feeding surface, and see if the error is
resolved.
5. Replace Pick roller or Brake roller, and see if the error is resolved.Check the consumable counter from the TWAIN driver screen or from the built-in Maintenance mode. When the counter exceeds the values, replace Pick roller or Brake roller.
6. If the issue still persists, then you are recommended to contact the nearest Fujitsu service center for further assistance.
Hope the above information is helpful.
Thanks & regards,
ScanCare
May 03, 2013 | Fujitsu Office Equipment & Supplies
I have a konica minolta 1690mf. paper feed problem error 094
Transfer roller issue. the sponge looking roller across from the transfer belt.
Jun 26, 2012 | Konica Minolta magicolor 1690MF All-In-One...
Paper feed not collecting paper, clicking noise
Clean the pickup roller(s) (in the paper tray) with mild soap and water if you can remove the pickup roller easily or with a q-tip if you can't. DO NOT USE alcohol as it will dry out the pickup. Use at least two q-tips, don't stop cleaning too soon. You can use a little fine steel wool to rough up the roller surface too. Replace the rollers if that doesn't work. Usually cleaning them is a stop gap measure. This works for the top rollers too.
Sep 09, 2009 | Brother HL 1250 Laser Printer
Hi, i have a lexmark x4550. The pick up roller (the roller that grabs the paper and feeds it into the printer to get printed on), is not working, at least one of them isnt (there are two i think,,, but on...
Try the following: take an A4 sheet of paper and glue a 2 - inch strip of sanding paper onto the top of the sheet (full width of the page). sanding paper should be about 120 grain.
Now feed the page with the sand paper first (rough surface on top) into the paper inlet. grab and hold the paper, then press paper feed or send a print job. The printer tries to feed you special sheet, but you won't let go. This will sand off the gunk from you feed rollers and give a bit of rough surface to the rubber. Repeat if needed, it should cure the problem.
This works if the problem is the roller surface, it will not fix a problem with misalignment or a missing/broken spring in the feed roller mechanism.
regards, the perfessa
Aug 23, 2009 | Lexmark X4550 Multifunction Wireless Color...
Paper pickup problem
Can you be more specific about which canon copier you have. There are different feed rollers in different copiers. A short term fix is to clean the feed rollers. You will have to remove or remove the paper tray(s). depending on which copier you have. Some type of dry cloth (free of any residue/I use white dry shop towels) and a little rubbing alcohol will usually get you going again. You should be able to see the feed roller. Just clean it all the way around the roller. Use the alcohol sparingly, you don't want any liquid dripping inside of your copier.
The feed rollers also wear out. Once they get to smooth, they may no longer pick up the paper. If the rollers are removable, some just snap out, you can even lightly rough up the surface with a really fine emory cloth.
Feed rollers wear out and eventually reach a point where they must be replaced. The more card stock that you run through your copier, the fast they wear out.
Hope this helps. If you look inside and are confused what the feed roller is, then your best best is to call a copier repairman.
Jun 21, 2009 | Canon Office Equipment & Supplies
5300 won't load 8 1/2x 11 photo-weight paper.
''grabber'' roller out of work sometimes, you may try
1) there is a input paper sensor around roller, the roller out of runing if the sensor is not senitive enough or sensor switch dirty,
clean the sensor as you can find it,
2) Lighter-weight paper feeds and prints fine, which means this paper input sensor works ok, but you need to make sure they are same paper input sensor,.
3) the paper surface bright and the roller worn could be cause paper feed fail, you need clean the roller anyway. still not fixed, you need to adjust the roller pressure by increase the spring force.`
Feb 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Pagepro 1350 will not feed paper
I have the same printer and had the same problem.
Cleaned takeup roller wit isopropyl and it has worked now for 18 months. If you dont use it often, remove top sheet from stack and blow the dust off it before printing.
Nov 14, 2008 | Konica Minolta PagePro 1350W Laser Printer
Printing business cards
Feed sheets through front manuel feed slot.
base tray is mainly for up to 90grm paper,anything heavier
can feed for a time but tends to fault.also try and clean the
paper pick up rollers regularly.
mongrelken.
May 20, 2008 | Brother HL-2040 Laser Printer
Paper in 3310 HP
You have a possible paper jam or foreign matter in your roller area or feeder area, get a torch and thoroughly check inside unit, near carriages, roller and paper feeder.
Aug 17, 2007 | HP Photosmart 3310 Printer
140 people viewed this question
jasbo
jasbo
