Question about Minolta EP1083 CS/PRO Copier
Minolta EP2030 shuts off immedietly when I power it on
    Problem Solver:
  • 6 Answers
Open back cover of the machine.find reset button on the mainboard.try resetting by pressing reset button and switch on power button at the same time.problem solve.
Posted on Jul 18, 2011
  • Minolta Expert
  • 1,326 Answers
Do you see a error code? Like a C5? Try holding the power botton on and look for a code that shows up on the display. You may have a blown heater lamp or scanning lamp. You are losing your AC power some where.
Posted on Jan 23, 2009
I have a minolta ep2030 and when i hit copy all i get is black page.
- clean the scanner optics
- if this don't work check and replace drum cleaning blade
Jul 26, 2012 | Minolta EP1030/1030F CS/PRO Copier
EP2030 Minolta error code C0660
Under the big glass to your right under that black cover is a lens assy., and mirror assy., something is jammed in there or bad motor. open front door upper left access cover remove cover touch trouble reset to reset machine.
May 08, 2012 | Konica Minolta EP2030 Fuser Thermofuse
I HAVE A MINOLTA COPIER EP2030/ WHEN I TURN ON COPIER IT SHUTS OFF IMMEDIATELY. CAN'T FIND A RESET BUTTON,DOES IT HAVE ONE? ANY SUGGESRIONS?
In my 27 years working on Minolta copiers I have seen this problem twice. Both times it was because the top half of the machine that opens up as when removing paper jams is not fully closed down. Also called the "clamshell". I may be wrong but check to be sure the top 1/2 of the machine is fully closed and latched to the bottom half.
Good Luck and Thank You for using Fixya.
Sep 10, 2010 | Minolta Office Equipment & Supplies
Minolta Ep2030 Error C06
open and close the front cover while machine is in error stage
Jun 21, 2009 | Office Equipment & Supplies
My copier Minolta EP2030
does not follow to do the repeated installation of developer. If you doing the installation, they will be different from factory. Minolta itself is determined concentration of the toner and after a certain time will stop the miks. Simply backfilling new portion developer and set the bank up with toner. Include the device. He stops in a certain time itself.Good luck.
Nov 24, 2008 | Office Equipment & Supplies
Minolta EP2030 exposure lamp timing wrong
"Exposure lamp timing wrong" simply means that the lamp is coming on at a time when it should not be coming on. It is not a problem with the lamp itself. It is most likely a power supply problem. There is probably no simple fix.
Just because Konica Minolta no longer will sell you an agreement does not mean that you cannot get the copier serviced. There are plenty of independent repair agencies that would love to service your copier, unless you are in a really remote location.
The EP2030 was one of the last Minolta analog copiers, and parts are still readily available.
Nov 13, 2008 | Minolta EP1030/1030F CS/PRO Copier
Minolta Photocopier EP2030 service code
This code is related to the exposure lamp, Either the lamp is burnt or the fuse, a small device in the carriage of the lamp, is blown due to overheating. The reset is made with the machine switched on and by pressing the micro switch (right bottom corner) on the main board ( back of the machine).
GOOD LUCK.
Oct 31, 2008 | Sharp AL-1217 Copier
108 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
