Question about Garden
I have eight Clark King 140 I'll wash the problem is sometimes the boiler will not ignite and the pressure drops
Hi I have a clark king 140 hotwasher ,the motor runs water comes out know burner ,it's full off fuel I have tried to bleed but nothing any ideas filters are clean
Posted on Dec 04, 2014
2 Suggested Answers
SOURCE: Clarke king 140 power wash,
Remove the main cover, look on top of the grey boiler cylinder and remove the black cover marked FUEL PUMP. You will see the fuel pump unit, on the side of the unit there is a small wingnut used for bleeding the fuel pump. Carefully switch on the washer onto its hot setting and while it is running undo the bleed screw until you see fuel start to drip from the screw, you can then tighten the screw and the boiler should fire. Be careful not to touch any of the high voltage ignition components while you carry out the bleeding procedure.
Posted on Mar 20, 2011
What is the normal PSI of the operating system?
As with any hot water or heating appliance, a hot water boiler system requires a constant pressure flow to maintain the optimum temperature. Hot water boiler systems are equipped with a pressure gauge and an automatic pressure reducing valve that will add water to the system if the pressure drops. Despite the pressure reducing valve, owners should be familiar with the standard PSI of their hot water boiler system and should check the pressure reading regularly.
OBD Tools 365 Days Shop
Sep 29, 2014 | Cars & Trucks
Boiler ignition failer
Try adjusting the gas to air mixture and flow rate. I don't work well in very cold weather, either. I think that's fairly typical. Even a diesel engine is difficult to start in cold cold weather. Perhaps heating the room where the boiler is would help or at lest insulate the room well. Including stopping any drafts that may be causing a windy condition in or around the combustion chamber.
Feb 06, 2014 | Honeywell Triangle Tube Prestige Solo 110...
Wickes 102 combi boiler constantly loosing water pressure
It sounds like your thermostat could be the problem. Have you noticed the boiler cutting off at all, or does it run continuously until it goes out on low water?
You stated, "when boiler is on", so I am wondering how you get the boiler on. If your boiler is controlled by a thermostat, you need to check it for a cold draft possibly from behind the thermostat in the wall where the wires come through. The thermostat should never be on an outside wall. The thermostat could be defective.
An aquastat can also control your boiler. If you have an aquastat, check the setting, typically 175 - 180 degrees. You should also have a "high limit" which should be set at 210 - 220. Some people run that high side limit higher; not a good idea - defeats the purpose. If the aquastat is set too high, the boiler will operate too hot and the problem you have will occur.
"pressure rises and pressure relief valve opens" This could mean that your pressure switch is prematurely venting. Check boiler temperature to see exactly at what temperature the T&P valve purges. If it blows off below the high side setting, either adjust or replace. The T&P valves are usually not adjustable. That blow off temperature is stamped on the head of the valve. So, if it discharges too soon, replace it.
Have you actually seen evidence thgat the T&P valve is opening? You may have a bad bladder in your expansion tank and your system may have air in it. Your boiler should have 12 psi when cold and 20 - 22 psi when operating. Check your boiler pressure guage.
this eventually drops below the minimum operating pressure" Technically, there is set point for a NO MINIMUM OPERATING PRESSURE. That is a function of the amount of water in the boiler. If the T&P is blowing off, it will vent water from the boiler and the boiler pressure will go down. There is a minimum operating TEMPERATURE.
Your boiler could be low on water. You will have to manually fill the boiler. Be careful of thermal shock to the boiler. Feel the piping, and fill only when the circulator is running. Make sure the water is not going directly into the boiler. The supply water should go into the circulating supply side which feeds the radiators, radiant floor, or base board circuits.
All this will adversely affect your hot water. The heat exchanger for the potable hot water may have scale build up in it. Using the hot water keeps the boiler running, and a scaled heat exchanger will give you cooler hot water and the boiler keeps running. If this is a problem, you will need to replace the heat exchanger. A better idea is to not use the boiler for your domestic hot water. Why run the boiler in the summer?
Feb 02, 2013 | Water Heaters
Pressure is to high
is this a steam engine by any chance ,pressure on the boiler or hot water boiler maybe
Feb 10, 2012 | Cars & Trucks
The ignition light flashes on my vaillant 282 boiler at the end of the pump overrun time and the boiler will not reignite. Have changed the pressure diff switch, pump and now the two circuit boards with no...
j skinner508
I have exactly the same problem with the same model of Vaillant as you. Two plumbers have not solved the problem so, like you I am still looking for the answer. If I have any luck I'll let you know
adrian994
Apr 15, 2011 | KDS Valiant 6380iPTD-01 Notebook
Clarke king 140 power wash, boiler wont fire up
Mar 10, 2011 | Garden
Boiler won't fire even though the pilot is lit
Check if the ignition plug works. Upon putting your boiler on, a spark will normally trigger the
the firing. Then, check the ignition transformer if it works. Check the secondary voltage which is between 15000 to 20000 volts to trigger the ignition plug and the boiler to fire. If no spark,
have your ignition transformer replaced to make it work.
Sep 21, 2009 | Heating & Cooling
Worscester 24i boiler
there is sometimes a large screw on the front of the of the pump un screw a bit and see is air comes out
Feb 03, 2009 | Combi Centre DX - Mango
Garden Logo
148 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
