Question about Refrigerators
Dometic rm 2330 not working on 240 volt or 12 volt
It is working on gas
22yooper
  • 828 Answers
SOURCE: Dometic Caravan Fridge 7271
Your refrigerant may have completely separated in the system. Shut of the gas, disconnect the electrical and remove refrigerator from the coach or if you have sufficient room inside set it on a clean area. This operation is what is called burping the system.
1. From the base roll it onto the door and wait five minutes.
2. roll it onto the top and wait five minutes.
3. Roll it on the back and wait five minutes.
4. Return it to the base and wait five minutes.
Reinstall it or test it on electrical. It should show signs of cooling in about 30 minutes in the freezer compartment if the system is not plugged in the boiler.
Posted on May 26, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: My dometic frig will not work no power. Has 12 volt and 110 volts
Replace the bulb and also check the relay and the sensor in the back of the unit. But first try replacing the bulb
Posted on Feb 13, 2009
  • 68 Answers
SOURCE: Dometic rm 2612. Shuts down on gas.
Ron;
Check the burner assembly. 1 screw, remove the sheet metal cover and clean it. The burner collects rust. This is the likely. Other issues would be the gas pressure usually checked with a manometer. Should 11" of water column. If your furnace works good then the gas pressure is probably ok. Also could have a faulty ignitor which sends a miliamp signal back to the circuit board. Check the burner first, after that leave the cover off and turn the fridge on. Watch the ingnitor attempt to lite the burner. Be sure the spark is going to the burner and not shorting out on the sheet metal it is mounted in. If it is shorting to the frame the ignitor needs replacing.
Thanks for using Fixya
Jerry
Posted on Mar 31, 2009
  • 159 Answers
SOURCE: It works on 240volts and gas but not on 12 volts. Why and how do I gain access to the parts that I must test?
in the rear it have a round element you will see there are four wires going in the 12v side must be tested if there are any circuit if not it need to be replaced
Posted on May 20, 2009
dcramer531
  • 1654 Answers
SOURCE: Hi, My dometic RM 2350
More that likely the control board has gone bad or the thermostat quit working. You might have to try and light this on gas several times to finally get it to go, if there is any air in the line it won't light and the air must be purged. This can take several minutes of continious trying to get it to light. When it kicks off switch from gas to off and back to gas again till it lights. Have you checked the thermocouple that lets the control board know that there is fire in the pilot? If this is bad it won;t kick the main gas valve on. You can check these with a volt ohm meter, when there is fire on the thermocoule you will get a small voltage reading in the mil amps portion on the tester, no reading means bad thermocouple.
When you say failed, what all happened, are the lights on the fridge indicating electric or gas working? Is it just not cooling? Have you hecked for power to the control board on the fridge? There should be a wire diagram on the cover for the board on the back of the fridge, check to see if you have power coming in to the unit, if not check your fuses.
Posted on Dec 24, 2010
Where is the heating element for the 12 V side on Rm 2510 3 way Electrolux
two black wires from lower control board to chimney the one marked 12 volt on board
Mar 29, 2018 | Electrolux Refrigerators
Dometic fridge not working on 240 volts gas ok and 12 volt ok
The AC heater element is most likely open. Replace it and it will restore AC operation.
Sep 21, 2016 | Dometic Refrigerators
Three year old Dometic RM 2555, 3 way Frig/freezer has failed on 240VAC however works on Gas. I suspect the PCB is faulty
My rm2555 has just failed on 240 volt. But not 12 volt.
It turned out to be the 240 volt element .
Fairly easy to replace. If you have a multimeter test the resistance, mine was open circuit.
Does yours work on 12volt?
The two heater elements (ie 12v and 240v ) are on the right when viewed from behind with four large wires coming out, plus an earth wire. There are labels on some of the wires. The 12 volt conects into a terminal connector, where as the 240 volt is fitted with spade connectors and is attached to the printed circuit board, under the white plastic cover. The elements are "L" shaped and are just pushed down in down next to each other. The cover seems to unclip fairly easily to enable removal.
Hope this helps.
Mark
Dec 26, 2010 | Dometic Refrigerators
My dometic rm 2612 stops working at least once a day the check light goes on.
Your 'frige has either; a 12 volt power supply or, a gas flame to circulate the refrigerant gas to cause absorption refrigeration to work; check or, replace your power supply as it 1. holds open the gas valve relay, 2. heats the gas with a heating element.
Mar 30, 2010 | Dometic RM2620 Refrigerator
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
