Question about Kenmore 98702 Stacked Washer/Dryer
Kenmore 98702 Stacked Washer / Dryer WON'T DRAIN
Hello, I have a Kenmore 98702 Stacked that will not drain after the wash cycle. It will still [try to] spin, and agitate, but when the wash cycle is over the pump does not come on to drain it. How do I test/replace the pump? Where would I get a new one? Thanks.
  • Tommy Walker Jan 22, 2009
    Thanks for the response. Yes, it used to drain just fine. Now when it gets to the point when it should drain, there is no noise except for the timer. The unit has not been moved, and if there was a pinched hose, it seems that the pump would still be making some sort of noise ...
I had the same problem. It was the lid lock switch. I bought one at www.searspartsdirect.com for at total of 59.82
Posted on Apr 30, 2009
    President:
  • 1,214 Answers
Did the unit ever drain? If it did, has anything changed?
Make sure the drain hose in back has not pinched (unit slid backward against the wall, pinching the hose.).
Motor is two speed, and if it's not kicking to the high speed, then there may be a timer problem.
Posted on Jan 22, 2009
  • Mark Egan Jan 22, 2009
    Double check the drain hose then, and while your back there, make sure there is an air gap between the drain hose and the standpipe (drain pipe is larger diameter than drain hose.).
    If it's not that, then pull the back panel off, and track down the pump. Make sure none of the hoses there have collapsed, and if all looks OK, pull them off and look inside to make sure something hasn't clogged them. And you can always test to see how well the washer drains by bringing a trash can inside, and drain the water into it.
    Let me know what you find and I'll give you some more direction.
    SearsPartsDirect will have the pump, if you need one. There are otherplaces on the internet that you can order one as well.
Kenmore 98702 not draining
sounds like the pump failed, its always worth getting repair price first as could be as little as 40 or 50 pounds to supply and fit a pump where new machine will cost few hundred.
May 05, 2012 | Kenmore 98702 Stacked Washer/Dryer
98702 Stacked Washer / Dryer Your question about 98702 Stacked Washer / Dryer has been posted. Mom has a Kenmore stackable washer. She ran water in for a load and the water ran out of the washer and onto...
Get the control panel off and remove the water pressure tubing. Blow it out and reconnect to pressure switch. Remove water so that pressure can once again build inside the tube. Retry>
Oct 22, 2011 | Kenmore 98702 Stacked Washer/Dryer
Our kenmore stackable washing machine on the rinse and wash cycle is not filling up with water. the water keeps running out
Make sure the drain hose is not pushed too far down the drain pipe. It could cause a siphon effect and drain the tub.
Make sure the drain hose is not tight in the drain pipe. It should fit loose so as not to trap the air which can also cause a siphon effect.
Dec 15, 2009 | Kenmore 98702 Stacked Washer/Dryer
Water won't drain
Check filter or pump. Clean as required..
Oct 03, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stackable washer/dryer 417.97802792 won't drain
its your brushes on your motor or the motor itself but my guess is the brushes replace and enjoy
Jun 23, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stacked washer / dryer 2002
hi thanks for the question so your saying your tub is full of water ,did it stop in the middle of the wash cycle or at the end of the wash if its at the end of wash and it doesn, drain then you have a lid switch problem . if thats the case reset your timer as if you want to start a new wash load if it starts to wash your timer is ok replace the lid switch
Aug 27, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Washer/Dryer Does Not Drain. Please Help!
Check out your exit hose spigot, it may be clogged. This is if your filter is all clean(ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Some connect to sink, fine. Snaking out your standpipe would be good too.
If the above fails, check to see if your pump is blocked. Pl rate if helped.
Jun 17, 2008 | Kenmore 98702 Stacked Washer/Dryer
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
408 people viewed this question
Sal De
fordexpert
Robert Rankin
