SOURCE: sony cdx-m610 BIG PROBLEM
yal ever fix them? its the ribbon cable between the face and the circuit board inside the unit the ribbbon cable is very cheap on ebay just google for example cdx-m610 ribbon cable now for the repair close ur face before u take out ur radio assuming u guys still have ur remote to do so theres 3 screws on the bottom of the face when u go to carefully pop the front panel off after pullin them hold ur deck facing down (this will keep ur reset and open buttons from fallin out then theres 4 screws holding in the face's circuit board roll the board out of the face very very carefully pry open the little black lock holding the cable in the connector then open ur radio up pull out the cd player assy same thing with that connector then ull notice the cable goes thru a tension roller pull each end of the cable to unroll it hold it there while removing the cable and sliding in the new one then slowly let go of the roller reattach the cable ends and put everything back together with the face remember its easiest to hold the deck face down those 2 buttons will stay in place hook the top of the face's cover first then put the deck back in ur ride and enjoy these ol sonys r worth a $20 fix specially if they still work good hope this helps yal
SOURCE: Frozen buttons
Hi I am Vortash your radio I take it has a removeable security face , is it the type that folds down on a slide that allows you to put the cd in behind or do you place the cd through a slot in the faciure .. if it is the afformentioned then check the connecting ribbon is not damaged and cracked stopping the opperations .. if it is the latter check that the pins on the rear of the facia are clean and undamaged .. failing that there is nothing that you can do other than try a new facia or return it to the manufactures .. If you are In the Uk and your unit is under six years old then you have rights under the consumer act to get it repaired or replaced by the shop you purchased it from even if the guarantee has expired . All goods in the uk are coverd by this act so dont let the shop tell you any diffrent .. if they dont play ball report them to trading standards and they will take up your case in law . check out www.bbc.co.uk/oneshow and it is explained on there . If in the USA check out your consumer rights with the department of consumer trading .. hope this helps regards Vortash
SOURCE: MY Sony CDX-R3000 will only play CD's. It will not
Try and reset it . disconnect battery under the hood for like 5 min and see what happens ..I had that radio and sometimes its just tempermental . take cd out and try it ? Sre any buttons stuck ? If that doesnt work then hopefully u like your cds at the volume they are at . Good luck
SOURCE: Sony CDX-S2210 CD Player stuck on demo mode
make sure the unit is switched off and the clock is displayed then
1 Press and hold (SEL).
The setup display appears.
2 Press (SEL) repeatedly until the
desired item appears.
3 Press the volume +/– button to select
the setting (example “ON” or “OFF”).
4 Press and hold (SEL).
The setup is complete and the display returns
to normal play/reception mode.
Note
Displayed items will differ, depending on the source
and setting.
With the card remote commander
In step 3, to select the setting, press < or ,.
The following items can be set (follow the page
reference for details):
“z” indicates the default settings.
*1 When the unit is turned off.
*2 When the audio output is set to “SUB.”
CLOCK-ADJ
(Clock Adjust)
(page 4)
BEEP To set “BEEP-ON” (z) or
“BEEP-OFF.”
SUB/REAR*1 To switch the audio output.
– “SUB” (z): to output to a
subwoofer.
– “REAR”: to output to a
power amplifier.
DIM (Dimmer) To change the brightness of the
display.
– “DIM-ON”: to dim the
display.
– “DIM-OFF” (z): to
deactivate the dimmer.
DEMO*1
(Demonstration)
To set “DEMO-ON” (z) or
“DEMO-OFF” (page 4).
A.SCRL
(Auto Scroll)
To scroll long displayed items
automatically when the group/
track is changed.
– “A.SCRL-ON”: to scroll.
– “A.SCRL-OFF” (z): to not
scroll.
LPF*2 (Low
Pass Filter)
To select the cut-off frequency
“78HZ,” “125HZ” or “OFF
SOURCE: my sony cdx s1000, the source button does not
you may have a bad switch. if you can you can use a multimeter to check the resistance of the switches. anything less than a few megaohms, denotes a bad switch usually.
