Question about Sony Ericsson K850i Mobile Phone
Do not understand a function on my sony k850i
I do not understand a function on my sony k850i. Recently on thr front screen next to the bars indicating signal strength and 3G there is a cartoon picticture of a person with a red bent arrow... driving me mad as i want to know what it is and how do i access it.. please help
  • zanwar7 Jan 24, 2009
    how do i find out which number this relates too
  • 67 Answers
This is the sign for a number divert, its were one number in your phone is being diverted to your answerphone, everytime they ring you.
Posted on Jan 22, 2009
Hello is there a way I can change the network setting on my LG phone LGL63blight now it's set to Lte and I can be next to my WIFI and I can only get 2 bars
The LTE indicates the phone network signal strength and not the Wifi signal strength. Go to your wifi setup and connect screen to see the Wifi signal strength.
You can try changing your connection to 4G and seeif you get a better connection in your area
Settings ->> Mobile Networks
Sep 26, 2017 | LG Cell Phones
Iphone 4 lost signal,when try to make a call
Sounds like a problem with the radio transmitter in the phone. You will need it repaired or replaced I fear.
Apr 05, 2014 | Apple iPhone 3G
My Kindle is not connecting Via 3G. It is 3G enabled.
The information provided below was tested on a Kindle 2, international version with Wi-Fi and 3G.
The Kindle automatically searches for the best connection signal in the area you're in. But for that, you first need to check if the wireless mode is turned on.
If you can see the signal strength bars next to the battery icon at the top, it is on. If close to the battery icon you only see another icon marked OFF, then you need to change that, as follows:
Press MENU,
Move the 5-way controller button up, till the selecting bar is under "Turn Wireless On" and press it once.
The Kindle will start to look for the providers in the area. The kind of connection it is connected to will be shown next to the battery icon and can be 3G, 2G, GPRS, EDGE and 1X. But to see this information, you need to press the MENU button, because it is not shown in the normal view.
That icon at the top indicates the connection that was established by your device.
Another way to check the connection you have is via the settings display, in an undocumented feature. Here, a note of caution: THIS IS A FEATURE NOT DOCUMENTED IN THE KINDLE MANUAL AND YOU WILL BE USING IT AT YOUR SOLELY DISCRETION. IF YOU SELECT A NETWORK THAT DOES NOT PROVIDE THE RIGHT SERVICE, YOU WILL NOT BE ABLE TO CONNECT YOUR DEVICE - YOU SHOULD BETTER LET THE AUTOMATIC SELECTION MODE ON.
If you still want to proceed, you need to press MENU, select Settings and, when the Settings screen is displayed, press type 311.
A warning note indicating that the connection will be lost momentarily and that you may not successfully reconnect to the Amazon Whispernet networks appears. Selecting OK in this panel will take you to the "Available Wireless Providers" screen and the Kindle will take a while to scan all the networks available in your area.
A list of the networks found will be displayed. You can move the cursor and select the one you want, pressing the 5-way controller button. But it is better to select the "Switch automatically" option and let the best option be selected by the Kindle.
I hope these tips can help you solve your problem. Good luck!
Mar 09, 2011 | Amazon Kindle Wireless Reading Device
BlackBerry Curve 8520 signal swing
#1 Your BlackBerry does not have sufficient Power
Check the battery charge level as shown by the battery icon on the top left of the home screen. No Power - Battery Charge Indicator does not show a charge or is very weak. The battery icon may be red. Charge the battery.
#2 You are Out of Network coverage area
Check the Signal Strength Indicator on the home screen. (1 to 5 bars, as shown below, indicating signal strength). If there is no signal, you may be out of range of the network.
If you are sure you are in range of the network, but show no signal strength, press Alt-Right Shift-Del at the same time. This will cause the BlackBerry to reacquire a network connection.
The process for this procedure is:
  • Press Alt-Right Shift-Del (The Del key is also the Backspace key.)
  • The screen will go blank, and an hourglass will appear. Wait for the hourglass to go away.
  • The startup screen will appear. Wait for it to go away.
  • A screen that says Verifying Security Software will appear. Wait for it to go away.
  • Check the Radio Tower icon.
If you are in Coverage Area of your Service Provider, You will get the network.
#3 Your Data plan is switched Off.
Feb 22, 2011 | RIM BlackBerry Curve 8520 Smartphone
I charge my i phone over night and after a few hours the battery dies
you should try turning your wifi off, and disable 3g
if you dont know how; just go to settings, general, then network. you'll see the option to disable Wifi if its enabled, as well as 3G. If you have 3G enabled, your iphone will die within 5 hours!! You can tell if your phone is on 3G mode by looking at the top left of it next to your signal bar, and see if there is an "E", a signal strength bar (Wifi), or an E, which is just the standard At&t network that takes less juice to run.
Try it lol
Dec 30, 2009 | Apple iPhone Smartphone
Letter h
i have that one too.. yes, it stands for High-Speed Downlink Packet Access (HSDPA) for a 3G mobiles. i had network problems/signal issues weeks ago when i used that setting, so i changed my phone setting from 3G to GSM. [uhm..i don't think you can find that in the user guide either, hehe. you have to browse and make yourself familiar w/ your phone=) ] with that i don't think i can make video calls, but who cares.. my signal issues were resolved. now, whenever i switch back to 3g, i can still see my signal bar on the upper left fluctuates.. sigh ;c
anyways, you can make that "H" disappear by going to:
settings=
connectivity=
mobile networks=
gsm/3g networks=
then choose GSM only.
Nov 20, 2008 | Sony Ericsson W910i Cellular Phone
3g is on my phone
The 3G on your phone is simply indicating that you are in a 3G data service area. You may also see G (GPRS), E (EDGE), or 3G+ (HSDPA) - This are merely indicators of the data capability signal strength. Whichever icon is up, ( G E 3G 3G+ ) will become animated, or highlighted when you are sending or recieving data. The indicator is a normal function of the phone display and unfortunately cannot be removed.
Aug 05, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Icon on screen.
faster internet connect for up and downloading or streaming videos online
Apr 21, 2008 | Sony Ericsson W850i Cellular Phone
Pc suite
If you mean connecting the handset to the PC and using it as a modem then if you make sure you have 3g switched on and have a signal then this will increase the speed . the 3g symbol is like a blue box with waves coming out of it ( when you see it you'll know what i mean ) its right next to the signal strength bars .
Mar 09, 2008 | Sony Ericsson K800i Cellular Phone
Sony Ericsson K850i  Mobile Phone Logo
65 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
