Question about Dell 3100cn Laser Printer
Our Dell 3100CN pcl6 still prints, but it makes a grinding noise.
Can it be fixed or are we making it worse by running it this way?
I had the same problem, tried to use the MFP tray, got jam, couldnt't close the rear door and used appropriate force... terrible noise with every print thereafter.
I fiddled with the roller at the back of the MFP tray. It didn't want to move much but after rotating it ~ 45 degrees back and forth it was in a more loose position. That seems to have solved it, no more noise!
Posted on Feb 15, 2009
How to stop my printer from smudging line on my paper
This often occurs when using aftermarket toner cartridges that are lacking sufficient developer. If you are not using a fresh genuine Dell cartridge, I suggest you try one.
Oct 06, 2014 | Dell Laser Printer 3100cn PCL6
Grinding noise when printing
If you have replaced a toner cartridge recently, eject the cartridge again and reseat it correctly.
Apr 25, 2014 | Dell Office Equipment & Supplies
Dell 3100cn prints the wrong colors
Go to Control panel
Click on: Hardware and Sound
Click on: Devices and Printer
Click on your printer
Click on Adjust printing preferences
Then go to the Maintenance Tab at the top (should be last tab)
Then click Print a test page
You can also Align Ink cartridges from here and clean the Ink Cartridges
If that does not work then update the drivers:
Go to Start
Type in box Device Manager
Click on Device Manager in list
Wait till list populates.
Click on Imaging devices
Right click on the printer
Update the drivers by searching online
Apr 03, 2013 | Dell Laser Printer 3100cn PCL6
My dell 3100cn makes a horrible grinding noise and eventually stops and says paper jam on tray 1 even though I am using the MPF
sound problem with the gear set, if your plastec gear where worn out and jam, it can occured error you need to trace what gear is that and need replacement.
Apr 09, 2010 | Dell 3100cn Laser Printer
Loud Abnormal Sounds with each print job
It may be a paper feed issue. If using a duplexer, try removing the duplexing unit and try printing again. It's often attached to the back of a printer.
May 21, 2009 | Dell 3100cn Laser Printer
My Dell 3100cn prints dark on one side of the paper. The "roller" that the ink "dust" sits on is only collecting "dust" on one side. Can you tell me how to fix this?
take the toner out and shake it. even distribution is require for the print to come out even. if that doesn't work then it is time to get a new toner.
clen the roller and the heating element. make sure the heater element is cool.
May 13, 2009 | Dell 3100cn Laser Printer
Grinding noise when the printer is printing
You should check out this site, it might help.
http://www.dellcommunity.com/supportforums/board/message?board.id=S2500&message.id=6202
Mar 08, 2008 | Dell 3100cn Laser Printer
Big black marks down the center of every sheet?
REPLACE THE PHOTOCONDUCTER DRUM OR CLEANINGBLADE ASSY MOST LIKELEY JUST NEEDS NEW CLEANING BLADE
Jan 04, 2008 | Dell 3100cn Laser Printer
Right side no yellow ink
You can get the manuals for the 3100cn printer from the Dell support website (http://support.dell.com/support/edocs/systems/3100cn/en/index.htm). They include some troubleshooting steps for determining what is causing a number of different problems with the printer. Did you make sure there was nothing blocking the toner on that side of the toner cartridges you replaced? If you haven't already tried it, I would also suggest cleaning the printer to see if that fixes the print problems you are seeing. The User's Guide (in the link above) has a section describing how to do this. If that doesn't fix things, run the tests for print quality and contact Dell support (contact information is in the manual, or on the Dell.com website). Hopefully this will help you get the problem fixed if you haven't already done so. Larry Dell Customer Advocate
May 17, 2007 | Dell 3100cn Laser Printer
Dell 3100cn Laser Printer Logo
415 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
