Question about Hitachi EDX-3280 LCD Projector
Need filter and filter cover for Hitachi edx3280
Missplaced or taken out of my classroom. I need to replace before I continue using projector
  • Hitachi Master
  • 19,396 Answers
Posted on Jan 23, 2009
  • 8,197 Answers
Ok you can get the filter here. they are checking for a filter cover if they can get one.
http://online.projectordoctor.com/Support
Call the 800 # for help
Good Luck and Please Rate FixYa!
Posted on Jan 22, 2009
  • 1 more comment
  • Jyackle5
    Jyackle5 Jan 22, 2009
    The filters are 19.00 there.
  • Jyackle5
    Jyackle5 Jan 23, 2009
    The part number for the filter cover is QD34851, and the cost is $39. The
    air filter itself is part number MU01691 and is $19. They don't have either
    part in stock but can get in 3 to 5 days at the link above.
  • Jyackle5
    Jyackle5 Feb 03, 2009
    Did you get the parts.
    Also please Rate FixYa!
    Brigadier General:
  • 3,614 Answers
Hi there,click on the LINK below;
Hitachi edx3280
  • Hitachi Master
  • 13,433 Answers
Hi, contact hitachi
http://www.hitachi-homeelectronics.us/contact/index.html
Model number muo1691 Air filter for EDX3280
  • 10,594 Answers
Please ask nearby Hitachi service center for required parts because its not common utilized parts.
  • 716 Answers
1-800-HITACHI
For Parts And service
  • 4,472 Answers
Http://products.isc365.com/AVCat/images/documents/pdfs/Accessories%20List.pdf
follow this link, it has the parts number for the filter and assembly your referring to. you can contact hitachi for parts replacement.
www.hitachi.com
Thanks,
Lee
NEC NP 1150
The temperature in the classroom is to hot. Turn down the
temperature in the classroom or get a small fan and place it near the
projector. The projector is running at border line and just needs a few
degrees of cooling...
Jul 20, 2010 | NEC NP1150 Projector
My hitachi cpx201 projector says to check the air flow
Hi There Teacher!
the air filter unclips on the left hand side, lens facing out.
after vacumming out the filter see below for filter reset counter procedure
Good Luck!
Turn the projector on and reset the filter time using the FILTER TIME item in the EASY MENU. Before taking care of the air filter, make sure the power switch is off and the power cable is not plugged in, then allow the projector to cool sufficiently. Taking care of the air filter in a high temperature state of the projector could cause an electric shock, a burn or malfunction to the projector. Use only the air filter of the specified type. Do not use the projector without the air filter or the filter cover. It could result in a fire or malfunction to the projector. Clean the air filter periodically. If the air filter becomes clogged by dust or the like, internal temperatures rise and could cause a fire, a burn or malfunction to the projector. WARNING Please replace the air filter when it is damaged or too soiled. When you replace the projection lamp, please replace the air filter . An air filter of specified type will come together with a replacement lamp for this projector . Please reset the filter time only when you have cleaned or replaced the air filter, for a suitable indication about the air filter. The projector may display the message such as ?gCHECK THE AIR FLOW?h or turn off the projector, to prevent the internal heat level rising. NOTE (1) Press the MENU button to display a menu. (2) Point at the FILTER TIME using the ??/?? button, then press the button. A dialog will appear. (3) Press the ?? button to select RESET on the dialog. It performs resetting the filter time.
Jan 14, 2010 | Hitachi CP-X201 Projector
Upside down image
These projectors are designed to be mounted upside down. Think of a projector that is ceiling mounted in a classroom. Change this setting in Menu - Advanced Menu - Setup - Mirror.
Jun 09, 2009 | Hitachi CP-X445 LCD Projector
When I turn on my hitachi CP-X205 projector, there is a very noticeable "fan" sound. Yesterday while using the projector it made a sound and then turned it self off. After unplugging it, I plugged it back...
Hi!
You need to clean the projector. Take of the filter and clean it, open the topschell of your projector and clean it.
In time a projector collects a lot of dust inside, if you dosenrt regulary clean the filter the dust pass it and stucks inside the projecotor. Use compressed air for the job but be verry verry carefull so you dont damage anything vital. If you arent sure how to to it i sugest you take it to a electronic repairshop, its cheap and they will clean it properly.
Good luck to you
Nic
Feb 27, 2009 | Hitachi Office Equipment & Supplies
Locate filter
The air filter for the Hitachi CP-S240 is located below the lens if the projector is sitting flat on a surface.
There will be a plastic cover that slides off by pulling it towards the front of the machine. Inside this cover you'll find the filter.
To clean it, simply pull the filter out of the cover or housing and blow the dust out of it. Replace the filter and the cover, and then make sure to go into your menu and reset the filter timer.
Jan 05, 2009 | Hitachi CP-S240 Multimedia Projector
Using the computer monitor and the projector at the same time?
I kind of have a solution for you. I know you need a splitter cable. You might want to go to Radio Shack or your local geek store or the manufacturer of the desktop and see what they have as far as accessories.
Or
Get yourself a laptop and run the projector from that, All you have to do then is hold down the FN key while pressing (depending on the make and model) F3 or F7. I use two differant laptops and those are the keys I use. I hope that I helped.
Dec 11, 2008 | Hitachi CP-S240 Multimedia Projector
I have an hitachi projector in my classroom that keeps displaying the sign check the airflow. What is this problem and what can i do to fix it?
Hi - You can download the manual by clicking the link underlined in blue below:
ED-X10
See page 51:
If you have replaced the filter and are sure that there are no obstructions or dust then rest the timer to clear the error.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 10, 2008 | Hitachi Computers & Internet
Resetting the air filter timer
If you do not have a remote here is how to reset the filter time. Use the "Menu" bottun to get the "easy menu" to display. Push the down arrow until you get to "Filter Time," then push and hold the RIGHT arrow to reset the filter time. DO NOT try to reset using the "Reset" option on the easy menu, it will not work.
Apr 22, 2008 | Hitachi CP-S335 Multimedia Projector
Projector Reset
Hi Here is the info for you :: Caring For The Air Filter The air filter should be cleaned about every 100 hours. If the indicators or a message prompts you to clean the air filter, clean the air filter as soon as possible. If the soiling will not come off the air filter, or it becomes damaged, then it needs to be replaced. Please replace the air filter as soon as possible. memoWhen you replace the lamp, please replace also the air filter. Turn off the projector, and unplug the power cord. Allow the lamp bulb to cool for at least 45 minutes. Apply a vacuum cleaner to the top of the filter cover and the air filter to clean. If the soiling will not come off the air filter, or it becomes damaged, it needs to be replaced. If the air filter needs to be replaced, contact your dealer to prepare a new air filter. Tell the dealer your air filter type. Turn on the projector power, and reset the filter timer. (1) While the projector running, press the MENU button to open the menu. (2) Choose the ?OPTION? on the menu using the / button, then press the button or ENTER button. (3) Choose the ?FILTER TIME? using the / button, then press and hold theRESET button for 3 seconds. (4) Choose the ?RESET? using the button. memo Incorrectly resetting of the filter timer (resetting without replacement, or neglect of resetting after replacement) will result in incorrect message functions. Here is the link to the users manual :: http://www.aboutprojectors.com/Hitachi-CP-X1250-projector.html Further Questions ?? Email Me hartmansp@inbox.com Have a great evening.
May 03, 2007 | Hitachi CP-X1250 Multimedia Projector
Hitachi EDX-3280 LCD Projector Logo
104 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Chris Goulet
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
