Question about Apple iPhone Smartphone
Wifi button does not work on my iphone 4s
When i try to activate wifi on my iphone 4s, it will not allow me to slide the wifi button to "on"
    Filmmaker:
    Uploaded 5 video answers.
  • 93 Answers
Try to reset all your settings - before doing this Backup all data
2nd - try to restore it (Warning) You must have a Factory Unlock before Restoring
3rd - if those Solution doesn't fix your problem better visit your nearest apple center. It's a hardware proble - wifi module
Posted on Jan 13, 2013
Can not slide to unlock my iPhone 4s
There are a couple ways to overcome this problem:
Method 1.
Hold the home button and power button until it turns off and turn it back on. This usually works.
Method 2.
Restore the iPhone using Itunes, it usually fixes any software issues. Make sure to back it up.
Jun 13, 2016 | Apple iPhone 4S
The button to access Wifi is grayed out on my I phone 4S
Iphone 4s wifi gray out problem is hardware problem, the wifi chip got welding off (or called fake weld). This is nothing to do with software upgrade.
I just fixed my iPhone 4s with gray out problem. This is not same as the way others talked --heating and cooling. this method needs to open iPhone case.
here is how (with phone power off):
1) open case (many youtube videos will teach you how).
2) remove metal covers, you will see the wifi chip (within red lines.);237135_750913605901185076329097be036.jpg
3) carefully (with a sharp knife) remove the black insulation layer completely (red lines), will put insulation layer later.
4) after remove the insulation layer, you will see the wifi chip like this picutue ( I borrow this picture. wifi number and ID is blacken out):237135_aed31360590130dc0aac5421381e0.jpg
5) then, heat-up your solder iron (40-60 W is OK).
6) use a wood stick, press down in the middle of wifi chip (black big dot in the middle). then use the tip of solder iron to push each blue dot about 20-30 seconds tightly, the heat of soldering iron will be passed to the chip to do re-soldering work. you need to do this step with 8 dots one by one, not stop.
7) after soldering work, put back black insulation layer back.then resemble the iPhone 4S.
the Job is done and your wifi should work now.
Good luck.
( this is only for those Iphone 4s with warranty expired)
Oct 12, 2014 | Apple Iphone 4s I Phone 4 S Factory...
My wifi wont turn on my iphone 4S why
common problem with iphone 4s. Means your wifi chip is disconnected from circuit board or defective. Some small iphone shops fix it by resoldering, but under some conditions it may happen again. High/low temperatures, drops and so on. If phone is still under warranty - apple will replace it free.
Sep 18, 2014 | Apple Iphone 4s latest Model - 16gb -...
I lost my apple i phone 4s is there any hope of getting it back
If you had IOS 7 or later and activated "Find my iPhone" featured you will
Sep 09, 2014 | Apple iPhone 4S
How do I connect to WiFi on my Apple iPHone 4s?
Try settings - general - reset - reset network settings
Then try to look for available wifi networks again. If that doesn't work check your router has wifi switched on
If that doesn't work it may be that your wifi antenna in the iPhone is faulty
Aug 22, 2014 | Apple iPhone 4S
Wifi isnt working
this is a common fault on these phone you can get them repaired but it will cost you a lot of money to repair it
Mar 08, 2018 | Apple iPhone Cell Phones
What are the main power and battery differences between iPhone 4s and iphone 5S?
Both Apple products have a built-in rechargeable lithium-ion battery that can be charged via USB from a computer or power adapter.
The Apple iPhone 4S battery allows:
8 hours of talk time on 3G
200 hours of standby time
6 hours of internet use on 3G, 9 on wifi
The Apple iPhone 5s battery allows:
10 hours of talk time on 3G
250 hours of standby time
8 hours of internet use on 3G, 10 on LTE and 10 on wifi
Both provide 10 hours of video playback and 40 of audio.
Sep 11, 2013 | Apple iPhone 5S
Apple iPhone Smartphone Logo
1,081 people viewed this question
Top Apple Cell Phones Experts
David
Martin Murray
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
