Question about Acer Aspire 7520-5185 Laptop
My acer aspire 7520-5185 will not turn on
It is full charged it just won't turn on
    Novelist:
    Champion:
  • 233 Answers
Hello. There is a hardware failure with the laptop not the AC charger. AC chargers have some range of protections of their own. If the power requirements of the laptop are bigger then what the charger can handle, the charger will turn off. Also other parameters can bring the charger offline. In your case, you have a problem with a small chip, the battery charge controller unit, witch regulates the amount of current required to propperly charge the battery. When this thing fails, the charging requirements for the battery are reported rong and the AC charger is forced to give more power then necesary. This results in disconnection of the AC charger ( an internal fail safe of the
AC charger) and the laptop to swich back to battery power. When the laptop is turned off, it can charge the battery because the power requirements are low, having all processor, main board, hard disk etc turned off. Therefore the AC charger can handle the load. However you will need to have it checked by a service center as it is a hardware fault. Both AC charger and laptop needs that check.
The charge controll circuit needs to be replaced probably. It will be a somewhat expensive repair. Don't buy any other battery untill you have the laptop checked.
Acer Aspire 7520
Posted on Jan 16, 2013
djromann
  • 158 Answers
SOURCE: Acer Aspire One won't turn
You probably get damaged the charging connector, or it is simple dissoldered from the mainboard, thats a very common problem. Check first if it turns on with another fully charged battery. If yes, you should resold the charging connector.
Posted on May 14, 2011
  • 106 Answers
SOURCE: We spilled water on top of the keyboard of an acer
I'm sorry to tell you but water can be vary damaging to your laptop. When its spilled on electronics while running it can cause shorts and they can permanently damage your laptop beyond repair. But Thats only a worse case scenario, your laptop may still be able to be repaired.
The first thing you should do is immediately remove the battery and unplug the laptop from the ac adapter to avoid further damage, Then try to get as much of the excess water out as you can, you could turn it upside down on a towel. If you have dry rice or a desiccant(Its a chemical used to **** up moisture) and a seal able container your could submerge it in either to help dry up the water as fast a possible.
The next step would be to take it to a local repair shop asap, avoid geek squad and the like, as there likely to cost as much as a new laptop. I would find a local shop and ask them how mush it would cost for them to dry it out and test it. If you cant afford to have it fixed at a shop or the amount of water was minimal, you can try to leave in the container for a few day and hope for the best next time you start it. I've save quite a few soaked electronics this way.
I hope I could Help.
Posted on Jun 21, 2011
TechyDrood
  • 2072 Answers
SOURCE: My laptop won't charge. I have
For a test -Remove the battery from the laptop. (leave it out) -Plug in the adapter and turn the laptop on. -Gently wiggle the adapter plugged in
If the computer powers off the solder and/or pins have broken loose from the DC jack. This is very common. Average repair bill is around $150, if your in the Denver Colorado Area I can do the repair for about $50
If it won't turn on while you wiggle the adapter and hit the power button then the adapter is bad again sadly
Posted on Jul 09, 2011
jryc32
  • 408 Answers
SOURCE: My daughter's Acer Aspire 5732Z laptop will not
It sounds like the battery charging ac cable might be faulty.. You might want to go to a local shop and see if they could try another cable before you go out and spend money on a new one. They usually will try a cable to see if that's the problem.. Please let me know if this washelpful and if it solved the problem and good luck..
Posted on Sep 10, 2011
luis_david
  • 407 Answers
SOURCE: ACER ASPIRE ONE D255E POWER CORD WON'T CHARGE
Hi: Acer chargers have a very short life time, in the past 2 years I had bought 2. Just buy a new one from amazon they're very inexpensive. Here's the link: http://www.amazon.com/Laptop-Adapter-Aspire-AOA110-AOA150/dp/B0028LK6IU/ref=pd_bxgy_e_text_b
Regards,
Posted on Sep 25, 2011
Acer aspire m5 won't charge
it sounds like one of three things:
1. Battery itself no longer functions
2. Laptop Charger has inadequate amperage
3. The motherboard is defective (most likely).
If you have another battery, or a friend with the same battery, you can try that first (and someone else's laptop charger).
If the problem is the motherboard, you can try to have it repaired but I don't trust many companies to do this kind of work. I outsource my motherboard jobs to a company called Laptop Rescue (http://www.laptoprescue.com/laptop-repair-2/). Coincidentally, they also sell laptop chargers in case that's the problem. Hopefully it's just a charger or battery issue and not a motherboard.
http://www.aurabuy.com/cheap-4400mah-battery-for-acer-travelmate-4740-4740g-4740z-4750-5335g-5335z-5340g-5542g-6495tg-8473g-8472t-tm5740-paypal.html
Apr 06, 2013 | Acer Aspire One PC Notebook
Acer 5820T quit while using and won't restart
Take out the battery and replace after some mins. If this doesn't work, remove the ram and place it back
Jan 27, 2013 | Acer Aspire TimelineX 5820T-5951 Notebook
Replaced the power board on acer aspire battery will charge to 28% overnight but charge nlight doesnt lightup
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Aug 22, 2012 | Acer Aspire 4720 Notebook
My battery indicator won't turn green when it is fully charged.what is this issue?
It is possible one of the battery cells has degraded enough the battery is not showing a full charge, or there is an issue with the green light, but this is minor provided everything is working.
Mar 07, 2012 | Acer Aspire One D250 16GHz Intel Atom...
Acer aspire battery critically low but not using battery, it shuts off anyhow
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Mar 04, 2012 | Acer Aspire 3610 Notebook
ACER ASPIRE ONE D255E POWER CORD WON'T CHARGE BATTERY PLUGGED IN THE POWER CORD WON'T CHARGE THE BATTERY ALL THE TIME ...
Regards,
Sep 25, 2011 | Acer Computers & Internet
Sep 10, 2011 | Acer Aspire 5732Z-4855 Notebook
My laptop won't charge. I have an acer aspire 5315 that won't charge, I had problems with the charging adapter before so I thought that was the problem and replaced it, the replacement worked for...
Jul 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
I have acer aspire 4741z, when I plug the battery charger, it says plugged in, not charging (6% available). how can I fix this problem? thanks a lot
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jul 07, 2011 | Acer Aspire 4730-4947 Notebook
Acer Aspire One won't turn on or charge, totally dead. DC power pack tested ok.
May 14, 2011 | Acer Computers & Internet
Acer Aspire 7520-5185 Laptop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
