Question about Poulan P4018wm Wildthing Chainsaw Wild Thing
HOW DO YOUREMOVE THE SPROCKET - Poulan P4018wm Wildthing Chainsaw Wild Thing
  • Poulan Master
  • 2,239 Answers
The P4018 has an out board sprocket, so to remove you need to remove the side cover nuts and take away the cover, the bar and the chain, there is then an e clip on the end of the crank, insert a suitable screw driver into the inner edge of this clip and gently pry off, take away the large backing washer, the sprocket will now just pull off the crank.
Posted on Jan 13, 2013
  • 1 more comment
  • Jim England Jan 13, 2013
    I inherited this saw and have discoverd that the clip and large backing washer
    the large backing washer were not there, (which explains why the sprocket is very chewed up.) The shaeft that the sprocket fits on does not come thru the sprocket far enough to put the backing washer and clip on. Does the clutch need to be tightened on the shaft more to expose more of the shaft?
  • Andrew White Jan 13, 2013
    the clutch will govern how much crank is exposed, so if the clutch is not screwed on far enough it will not expose the grove for the clip
I am changing the timing chain in a 1993 Chevy S-10 with a 4.3L engine. I was told you have to disconnect a wire to reset it but I don't know where the wire is.
Timing Chain: Service and Repair
REMOVAL
Tools Required = Crankshaft Sprocket Puller
1. Remove the timing cover.
2. Remove the crankshaft position sensor reluctor ring.
3. Remove the camshaft sprocket bolts.
4. Remove camshaft sprocket.
5. Remove timing chain.
6. Remove the crankshaft sprocket.
7. Remove crankshaft sprocket key.
INSTALLATION
1. Install the key into the crankshaft keyway.
2. Use the crankshaft balancer installer to install the crankshaft sprocket.
3. Install the camshaft sprocket and timing chain.
4. Install camshaft sprocket bolts.
Be sure to align the camshaft and the crankshaft sprocket marks. Timing marks (Number 4 Firing).
Tighten bolts to 21 ft. lbs.
5. Align the keyway on the reluctor ring with the key in the crankshaft.
6. Install the reluctor ring onto the crankshaft until the ring is completely seated against the crankshaft sprocket.
7. Install the timing cover.
Don't know what Wire you are referring to.
Jul 30, 2013 | Cars & Trucks
Pressure release from gas tank when removing cap
You have a check light on & pressure when you
remove the gas cap,so the question to you is,
why are you not getting the codes & repairing the
Evap System
Pretty simple I would say !!
Oct 26, 2012 | 2002 Chevrolet Suburban
Not cleaning properly, and Water will not drain out. However when we pull the house out the water does drain. Assuming pump? KUDV24SE Kitchen Aid Built In
During normal operation the outlet hose should be higher than the outlet nozzle, if the water drains when youremove the hose it means that the pump is not working, open the bottom of the machine and remove the inlet side pump hose and check for any obstruction, clean and replace the hose. If this does not work you need to replace the pump.
Jun 02, 2011 | KitchenAid 34 in. KUDV24SE Built-in...
How do youremove and replace a charbroil gas grill burner on model number 463268007
Here is a link to the Owners Manual for your model grill. It has the assembly instructions, so just reverse what they are and you'll be in business. As they say, "one picture is worth a thousand words."
http://www.charbroil.com/bps/char-broil/char-broil/knowledge/463268007%20manual%20-%20english_3d4c7147-c_.pdf
Apr 03, 2011 | Char-Broil Grilling
How to reset timeing on a 1991 chevy lumina 3.1
Timing is not resettable by the user, as the computer controls this based on knock or no knock conditions which will advance or ****** ignition timing for optimum performance.
The valve timing is something that is set when installing the timing chain:
2.5L, 2.8L and 3.1L Engines Fig. 4: Timing chain and sprocket removal - 2.5L engine 88003ga8.gif
Fig. 5: Timing chain and sprocket removal - 1996 3.1L engine shown 88003gb5.gif
Fig. 6: You must use a suitable puller to remove the crankshaft sprocket 88003gb6.gif
  1. Disconnect the negative battery cable.
  2. Remove the timing chain front cover assembly, as outlined earlier in this section.
  3. Rotate the crankshaft until the timing marks on the crankshaft sprocket and camshaft sprocket locator hole are aligned to the marks on the engine block or timing chain dampener. This is the No. 1 piston at TDC (No. 4 firing position).
  4. Unfasten the camshaft sprocket retaining bolt/screw, then remove the camshaft sprocket and the timing chain. NOTE: If the camshaft sprocket does not come off easily, a light blow on the lower edge of the sprocket with a rubber mallet should loosen the sprocket.
  5. Remove the crankshaft sprocket using tool J 23444-A or equivalent puller.
  6. If necessary, remove the timing chain dampener retaining bolts, then remove the dampener. To install:
  7. Install the crankshaft sprocket using tool J 38612 until it the sprocket is fully seated on the flange of the crankshaft nose. Apply a coat of Molykote® or equivalent, to the sprocket thrust surface.
  8. Hold the camshaft sprocket with the chain hanging down, and align the marks on the camshaft and crankshaft sprockets.
  9. If removed, install the timing chain damper to the engine block.
  10. Align the dowel in the camshaft with the dowel hole in the camshaft sprocket. Install the camshaft sprocket and chain, use the camshaft sprocket bolts to draw the sprocket on to the camshaft. Tighten the sprocket bolts to 18 ft. lbs. (25 Nm).
  11. Lubricate the timing chain with engine oil.
  12. Install the front cover assembly, as outlined earlier in this section.
  13. Connect the negative battery cable.
Feb 12, 2011 | 1991 Chevrolet Lumina
We need to change the font on our swintec 640
  1. Remove ribbon
  2. pull printwheel release lever toward you
  3. remove and replace print wheel
  4. push printwheel release lever forward - away from you until it snaps in place
  5. replace ribbon
  6. adjust pitch selector on keyboard if needed.
Dec 08, 2009 | Swintec 7040 Typewriter
Replace heater core in 96 mustang
if you have ac, its quite a job, take your time and label all the parts as youremove them, also make notations of the order you have removed them, i think the book calls for 5-6 hrs, hat is for someone expperienced , i have seen the dash diagrams and it did not help much,
Dec 07, 2009 | 1996 Ford Mustang
I need to replace my timing belt on my hyundia elantra 2003 with 1997 cc engine
Dear Friend
Removal: Support engine: remove -engine mounting, auxiliary drive belt, water pump pulley, crankshaft pully bots & crankshaft pully, timing belt covers....turn crankshaft to TDC on No 1 cylinder, ensure crankshaft sprocket, camshaft sprocket, oil pump sprocket & balancer shaft sprocket timing marks lighned. Pls note: Timing marks on camshaft sprockets should align with cylinder head uppter face, dowl pins on camshaft sprockets should face downwards....Slacken tensioner botl. Move tensioner away from belt & tighten bolt.
Remove: automatic tensioner unit bolts, automatic tensioner unit, timing belt, crankshaft bolt, crankshaft sprocket, crankshaft sprocket guide washer...slacken balancer shaft belt rensioner bolt, move tensioner away from belt & lightly tighten bolt...Remove balancer shaft belt.
Installation:
ensure timeing marks aligned.Note: Timing marks on camshaft sprockets ahould align with cylinder head upper face, exhaust sprocket mark is on recess but inlet sprocket mark is on tooth. To check oil pump sprocket positionded sorrectly: remove blanking plug from cylinder block, insert 8mm diameter Phillips screwdriver in hole. ensure screwdriver is inserded 60mm from face of cylinder block. If screwdriveer can only be inserted 20mm-turn oil pump sprocket 360". Inset screwdiver again.
Fit balancer shaft delt in anti-clockwise direction starting at crandkshaft sprocket....Slacken balancer shaft belt tensioner notl, turn tensioner clockwise to tension belt. Tighten bolt to 15-22 Nm... Applu thump pressure to belt at tentioner, belt should deflect 5-7mm. If not: Repeat tensioning procedure.... Install - chankshaft sprocket guide washer & crankshaft sprocket.
Thighten crankshaft centre bolt, tightening torque:110-130Nm. Please note, ensure crankshaft sprocket guide washer is fittet correctly. oil threads & contact face crankshaft botl before fitting.
Sep 21, 2009 | Hyundai Elantra Cars & Trucks
Poulan P4018wm Wildthing Chainsaw Wild Thing Logo
65 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
