Question about Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound
Backfires and bogs
I have a 1998 polaris 600 XC and when you first take off it will backfire sometimes and also when you put the throttle to the handle it will bog and almost shut down. when i was riding it would also have a hesitation when you hammer on it. It's pretty much a brand new sled with only 1500 miles on it. I thought that i might be bad spark plug so I put new ones in and I also put a new belt on it also but that didn't fix the problem. I heard that it could be the cluch that could do that but i'm not sure about that. What do you think could be the problem??
Thanks, Dustin
    Brigadier General:
  • 5,158 Answers
Put it in a warm garage overnight the other possibility is the timing is out.
Robert
Posted on Jan 22, 2009
    Problem Solver:
  • 12 Answers
Check your throttle position sensor. If you lift up on throttle lever when you apply it and it doesnt stumble thats your problem
Posted on Jan 24, 2010
Hey there,,before you get carried away,check the simple things first. Is the fuel fresh? A 99 sled with only 1500 miles must have done alot of sitting. You may need to clean carbs, and I would change fuel filter. If this doesn't help, clean and lubricate clutch and secondary. But make sure you have fresh fuel first off. Good luck!!
Posted on Feb 09, 2009
    Problem Solver:
  • 4 Answers
You need to take the carbs apart and have them cleaned and make sure they are adjusted properly. you also should make sure your choke is not stuck open . check theintake boots for leaks and also make sure your clutches are cleaned up and lubricated
Posted on Feb 04, 2009
93 xlt 580. Only runs on 2 cylinders sometimes at cold. Change plugs and works sometimes.. Not always same cylinder.. Any way to check stator,coil?
Ask The SnowMan Your Sledding Questions Answered: Off ...
www.off-road.com/.../ask-the-snowman-your-sledding-questions-answer...
Mar 1, 2009 - Its a 96 polaris indy xlt 600 triple not the special edition though. ... THEM SITTING ON THE HEADS BUT ONLY 2 CYLINDERS ARE RUNNING WHEN ... Q: I have a arctic cat ext580 the compression in both cylinders is about 70psi .... i have a93 polaris 600 xlt and I just got home and the antifreeze is ...
93 XLT Carb settings? - Snowmobile Forum: Your #1 Snowmobile Forum
www.snowmobileforum.com/polaris.../41045-93-xlt-carb-settings.html
Nov 27, 2009 - I bought a new to me 95 polaris sport last year. it had not run in twoyears. ... It's all in the tuning, clutching, jetting and gears.. i have a 93 xlt 580 and i ... he is loading up with fuel and just cutting the spark out of a cylinder.. i had ... XLT w/ Triple Pipes Question?
May 8, 2013
93 XLT Ran Great, Shut Down, Now Backfires
Feb 13, 2012
Dead cylinder
Dec 11, 2011
1998 ski doo f3 700 wont run right
Feb 22, 2011
More results from www.snowmobileforum.com
Polaris Indy 600 XLT HELP! - Snowmobile Fanatics
Jan 04, 2016 | Cars & Trucks
I HAVE A 1999 POLARIS 335 SPORTSMAN STARTS FINE WHEN I TRY TO ACCELERATE THE QUAD BOGS FEELS LIKE ITS GOING TO STALL BUT THEN GOES BUT NOT AT FULL POWER AFTER RELEASING GAS THERE IS A LOUD BACKFIRE ...
carbon on the plugs indicates flooding
the backfire indicates fuel being ignited in the exhaust
have the carby /fuel system professionally overhauled
May 27, 2017 | Polaris ATV
I have an 2001 Polaris XC 500 that sputters and backfires
Before you do any of that check exhaust for restriction.
Oct 26, 2017 | Winter Sports
Polaris Xpress 300. Won't start, backfires through carb sometimes
Sounds like maybe the needle and seat in the carb letting gas through.
Jun 28, 2009 | Polaris ATV
Xc 600 stalling
when it stalls, is it on a warmer day? ie 20+ degrees? is it overeheating or hot? If you have never had the carbs serviced, the summer/fall may be a good time. inside the carbs, you have differnt circuits, they may be gummed up. Good luck
Feb 08, 2009 | Polaris New Genuine Polaris Snowmobile...
Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound Logo
1,189 people viewed this question
Top Polaris Winter Sports Experts
Larry Fostano
Larry Fostano
Bill Boyd
Are you a Polaris Winter Sport Expert? Answer questions, earn points and help others
