Question about Jenn-Air JJW8230D Electric Double Oven
Jenn-Air elec oven finished self cleaning, door locked,F3 error
My Jenn-Air electric oven was self cleaning, finished and now the door won't unlock and the electric panel gives an error code of F-3. If you push the right buttons the panel will read d-o-o-r, but will not open. We have turned the circuit off for over 24 hours hoping that it would reset. No such luck. Oven is about 13 years old, no manual. We have pushed cancel, off, timer, cook time, cook time off and any other combination of buttons to puch. Any suggestions?
  • 1,214 Answers
Have a wall mounted Jenn-air oven. Have used self-cleaning feature before. Followed step by step instructions to the end including locking the door and pushing "Enter". Went to bead expecting to wake
This is a general answer and not specific. The oven thinks is still in the cleaning mode. If it has one, push the clean button again. Set the oven to a regular bake cycle.
Dec 15, 2013 | Jenn-Air 27 in. Electric Single Wall Oven...
After self cleaning process oven door would not unlock replaced display panel F3 error fan runs constantly lower unit still works upper unit still will not unlock
Shorted or open oven temperature sensor
(RTD) Check sensor harness and harness connection
between oven sensor and oven control. Replace oven temperature sensor (RTD) if
wiring is ok.
Dec 04, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
I tired setting the bottom oven to the clean cycle, it switched on for a few minutes, then locked. It didn't finish the clean cycle and the door remained locked. I have tried setting the clean cycle...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Nov 29, 2010 | Jenn-Air Electric Double Oven
We used the self cleaning option and now we cannot get the oven door open. The lever is stuck in lock mode. Can you give suggestion?
IF you can locate the model number tag (bottom left of door opening) you can look up the manual at
The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock.
IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can unlock (safety feature)
Thank you and thanks for using fixya
Sep 29, 2010 | Jenn-Air JGW8130A Electric Single Oven
Jenn air oven stuck closed after attempt to activate self-cleaning
The lock motor may have failed. Most often, bending a coat hanger into a hook and sliding from the right side as you move the door to the right,will allow you to release the lock and open the door.
Jun 09, 2008 | Jenn-Air JJW8130D Electric Single Oven
Oven door won't unlock
I posted a message on 12/27 and since then I have contacted Jenn-Air again and as I mentioned above the two things they told me to do didn't work, so I looked at the schematic of the unit and there appears to be a motor that locks and unlocks the door. I have a service repair coming this Saturday and seems to believe the motor is bad. Trenatru are you getting an error message? I was told by Jenn-Air that there is a 6 yr. warranty on electrical parts so will try to keep you posted if that is the cause. If you havn't tried shutting off the power try that first. They said keep it off for a couple minutes before turning back on. If that try pushing on the door and hitting cancel twice. If those two things don't work, will let you know what I find out next weekend.
Dec 24, 2007 | Jenn-Air W30400P Stainless Steel Electric...
Selfcleaning Jenn-Air electric oven
How do I clean my jenn-air double oven when I lock oven door and turn oven to clean mode set time to start I don't get anything. Also when I lock the oven door the oven lock light does not come on.
Dec 05, 2007 | Jenn-Air JJW8230D Electric Double Oven
Self cleaning
Maryann, try shutting the breaker off for 5 minutes and see if the door unlocks. Im assuming the oven has cooled down. If that doesn't work try holding the cancel and broil pads for 3 seconds. This will put it into the quik test mode. Once in this mode press the clean button. This should toggle between lock and unlock. Don't know if this will work for you but it's worth a back.
Oct 12, 2006 | Jenn-Air JJW9330D Electric Single Oven
Jenn-Air JJW8230D Electric Double Oven Logo
739 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
