Question about IBM Belkin Enterprise 900VA (31P7076) UPS System
Shut Down When ever we have an electrical glitch, my Belkin 900VA shuts down, the battery does not kick on to keep my cimputer running. What can I do to fix this? Thanks for your help. herbh
  • 192 Answers
It might be too old or ther is not enoph power in it to kepp you computer running.
Posted on Jan 23, 2009
  • 4 Answers
Replace the batteries. Ritar RT1245 (2ea) with same or equivalent.
Posted on Jun 27, 2010
Lenovo r61i has just started to shut down if I try to run it with the power supply attached. When I run the computer on the battery only it does now shut down until the barrry runs out of juice. Why?
If you are running Windows 7 or 8 there is a power setting that you can change to tell it when to shut down the screen or go to sleep. Click on the power icon in the lower right task bar. You will see something like power settings. Also you will see when to shut down the screen, for both battery an electric. You can make changes there an fix problem. I just did this a week ago an fixed the same problem.
Jan 27, 2016 | Lenovo Computers & Internet
Toshiba laptop satellite L645D-4040 keeps shutting down
does it shut down and then just start right back up? If it does then press and hold the power button and make sure it shuts down all the way. Then take the battery out and press and hold the power button after the battery is out for about 5 seconds. Then let it sit like 10 - 15 seconds. After that put your battery back in and turn it back on and see if this solved your problem. I think its in a loop to make it keep restarting. Let me know if this helped. Thanks, Herb Stacey
Oct 04, 2013 | Computers & Internet
My split system keeps kicking out it runs for a while if i shut down and restart but compressor kicks out after 5 min. it is contrlled with remote
The unit is usually low on freon when this happens...the machine will over ride the freeze stat and the low pressure control for five minutes and then shut down...
Have a tech. check the system for leaks and repair them.
Then recharge the system and you'll be good to go...
heatman101
Jul 05, 2011 | LG LS-L1210CL Mini Split Air Conditioner
I use a Belkin Surge Protector UPS 600VA, and run Win 7 64 bits. In "System Configuration", "Services" tab, Belkin APmonitor is stopped, and Belkin APMRMI is running. Nothing shows on...
2 scenarios will either play out at the end of the day:
1. During power outage, your UPS will continue to supply backup power for the number of minutes.it is built/designed to do for your PC after which it shuts down and your PC due to lack of power shuts down too.
2. if you've programmed your PC to shut down after say a short period it idles, your PC will shut down even though your UPS is still fully operational.
A third approach is to sync the situation/scenario you envisage by powering off your UPS power supply at the mains/wall receptacle.
Watch what happens next by leaving your PC idle but still connected to the UPS still powered on (but without the mains power supply to it)
Oct 06, 2017 | Computers & Internet
What doies it mean if the unit turns itself off, resulting in a loss of power to my electronics?
Most likely your battery is dead in the UPS. Replace the battery if you can. Belkin should be able to help you with that.
Mar 14, 2011 | Belkin 900VA ( F6C900-UNV ) UPS System
Hi, I have a Dayton 3ug73 heater. The heater will not shut down after the initial heat requirement is met. I have the thermostat set on low but it continues to heat. I shut the power off to it to keep...
It sounds to me like your thermostat may be bad. I would check power incoming to t-stat then turn temp. setting up and down to see if it is switching on and off. If not then replace. If it does then I would check all wiring to gas valve and if power is shutting off to valve but burner continues then replace gas valve. Thank you.
Mar 07, 2011 | Dayton (3UG73) Electric Utility Heater
Kick stand safety shut down, once bike warms up it shuts off if kick stand is down
The bike is supposed to shut down if the kick stand is down. It is a safety feature designed to prevent starting out with the stand down, which can be very inconvenient on your first left turn. If you are saying the bike runs with the stand down when cold, then the switch must be in need of adjustment. Please rate my answer.
Feb 21, 2010 | 2001 Suzuki VL 800 Volusia
I didn't take note of how the wires were connected to the RT1250 battery pack in my Belkin 900VA when I took them out to order replacements. Can anyone tell me the correct configuration? Thanks!
The two batteries are taped together with terminals and labels facing out. The jumper wire goes red(+)[battery1] to black(-)[battery2] on one side of each battery. This is a series connection making the total voltage 24v (12v+12v). Do not connect in parallel, the voltage will be too low and not charge. Do not connect the jumper to (+)&(-) of same battery, you could start a fire.
Nov 05, 2009 | IBM Belkin Enterprise 900VA (31P7076) UPS...
The Startup repair program is running and wont stop
A complete scan can take several hours to complete. If you want to shut it all down unplug it and remove the battery. Leave the battery out for at least 10 minutes, and until it cools down.
Nov 04, 2009 | Computers & Internet
IBM Belkin Enterprise 900VA (31P7076) UPS System Logo
175 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
