Question about Frigidaire Dishwashers
My Frigidaire Professional Series Aqua Surge with Speed Clean has stopped heating water, could it be the heating element needs replaced
My start button doesnt work on the panel
Posted on Jun 12, 2013
  • 8 Answers
SOURCE: Bosh 24 in.shu5315uc/u06Build-in...
Check PCB relay possible joint burn out
Posted on Apr 25, 2008
  • 72 Answers
SOURCE: Water level below heating element and element does not appear to heat
Make sure the drain hose high loop is installed properly, normally you have this in the sink cabinet high up. Otherwise the water inside the machine may drain "by itself", leaking through the inactive drain pump during the wash cycle and cause this and other troubles.
Posted on May 24, 2009
jyackle5
  • 8197 Answers
SOURCE: Calcium/Lime Build-up on Dishwasher Heating Element
You can clean the calcium/lime build up with CLR and a scotch brite pad.
Posted on Apr 27, 2010
heatman101
  • 43501 Answers
SOURCE: Our glasses don't rinse clean. This is a Frigidaire FDB750RCS0
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
gkj
Posted on Sep 30, 2010
  • 1891 Answers
SOURCE: I have a Frigidaire Aqua
HELP s on it way . it is or may be a install problem . take a look at the drain and how it connected to the disposal . If where it connects at that point the hose is going down hill then when the disposal is sending the grap down the dishwasher drain line . the dishwasher drain hose should leave the disposal and head up to the under counter edge and then return in a downward way to the dishwasher . this would be called a reverse trap . prvent ing food to go to the dishwasher .. this will prvent the odor .. mm hope this will help feed back pls ..
Posted on Nov 10, 2010
Er3 flashes hot water will not reach set point
Had this happen to me before, if you have hot water from the boiler going in and out of the boiler mate and the temps are not rising within the hot water means more than likely you may need to remove exchanger and clean sediment off element, basically sediment creates a blanket over the heat source causing poor thermal conductivity. Things to check before removing heat exchanger
- outlet temp of boiler water to aquamate -inlet temp of boiler water to aqua mate= 20-30'F if low then bad thermal transfer or poor water movement
-make sure sensor is reading properly
- get boiler temp higher to speed up thermal gain in water heater
Jan 19, 2014 | Amtrol 2704E76 41 Gallon WH-7C BoilerMate...
Doesnt seem like water is heating and element not getting hot
Sounds like you checked the basics. Do you have hard water? Our element got covered with calcium over time and didn't heat efficiently anymore. I was able to chip some off, then ran the dishwasher with LemiShine a few times. The element worked much better after that.
Dec 17, 2012 | Frigidaire Professional Series 24 in....
Oven elements have power but do not heat up
Hello kyren1999 - If the broiler element and the top of the unit works, but just not the heating element, then you possibly have a bad bake element or connection. However, if you are experiencing other performance difficulties, then you may have a bad control board that needs to be replaced. Consult a professional for an accurate diagnosis.
Nov 23, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire convection oven stopped working after self clean
Hello Margaux K - The unit needs to be reset. The temperature had tripped the internal sensor of the unit. This usually has to be done by a professional since the back panel needs to be taken off and the power reset inside.
Nov 15, 2012 | Ovens
My dish washer is 4 years old and is not cleaning dishes or disolving soap. HO appears in the status window which my manuel says indicates a water heat delay. How can this water heat delay be repaired ? ...
The water heat delay indication could be caused by the fact that the heating element has failed so that the washer will not proceed with the wash program until the water is up to the correct temperature. You should be able to tell if the element is getting hot. You could try manually putting in hot water before the washer fills up with cold to see if the wash then proceeds.
Sep 22, 2010 | Frigidaire 24 in. PLD2850 Built-in...
My new Frigidaire Profesional Series dishwasher is not cleaning my dishes and the rinse aid leaks. I am finding residue still on my dishes at the end of the cycle.
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried in vainto clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if the heating element goesbad then that also can mess things up bad... So I would buy new spray arms, and also check out theheating element to make sure it is working... Here is a tip that will help you with the online buying...
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Sep 20, 2010 | Frigidaire Professional Series 24 in....
Already replaced heating element, still not drying and not cleaning very well. Any suggestions would be very helpful. Thanks!
If your system has hot air blow check the blower if you can locate in the machine.
For not cleaning, you have to check the inlet water pressure. Clean the strainer. Check all the the rubber parts that is getting attached, when you close the wash tray for the job.
Sep 17, 2010 | Electrolux Frigidaire Professional Series...
Why aren't the dishing getting clean? It sounds like every cycle is running.What should we do?
Check your heating element..
A bad heating element causes many problems in dishwashers…
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 18, 2010 | Electrolux Frigidaire Professional Series...
Fridgidaire professional series drain smells and won't clean
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
heatman101
nmsgjh
Jun 18, 2009 | Electrolux Frigidaire Professional Series...
Dishwashers Logo
145 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
