Question about Royal Postal Scale Gray
Starts up beeps put somehing on it and it dosn't weigh
Scale starts then it beeps i tare it out put something on it and it doesn't wrigh
    Genius:
  • 1,669 Answers
The pressure sensor under the platform is probably corroded or broken...it may not be economic to replace it...buy a new scale.
Posted on Jan 13, 2013
2003 ford ute, what is tare? what is engine cap?
tare is the unloaded mass of the vehicle
what it weighs on scales
capacity is the cubic inches or liters of the engine ( as in 450c" or 5.8 l you will get those details from the owners manual or local service dealer
May 18, 2017 | Ford Cars & Trucks
How do I switch from grams to ounces on the Polder kitchen scale?
There is a button on the back of the scale with "g/oz" below it. This changes your scale from grams to ounces or vice versa.
Feb 24, 2015 | Polder Slimmer Digital Scale
How can you fix error on screen can it be reset
It often just needs recalibrating. Try turning the scale on while holding the mode/tare button with nothing on the scale. Then press the tare button again. It should show a calibration weight which you should put onto the scale. Then it automatically calibrates.
Nov 30, 2014 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
I have a DigitZ DZ3-600 and when I turn it on the word FULL in the display screen . What can I do to clear this and start using it?
My search is telling me that this is a scale. Is this correct? If so - this is the manual. \'FULL\' is not an error, but this is the correct model. If this is not a scale, please write again and provide more information:
The manual is short and PASTED after link to same here:
http://digitzscales.com/index.php?option=com_content&view=frontpage
Digitz DZ3-600 Manual
I. Operation
1. Place the scale on a flat, level surface and press the ON/OFF key to turn the scale on.
2. Once the start-up process completes and the scale goes to zero you are ready to weigh.
3. Place the quantity to be weighed onto the weighing platform.
4. Wait a couple seconds for the display to stabilize before taking a weight reading.
II. Changing the Unit of Measure
1. Press the MODE key to change the scales displayed unit of measure.
2. If the scale is turned off then back on, it will default to the last unit used.
• DZ3-100 Units: g (gram) oz (ounce) ct (carat) gn (grain)
• DZ3-600 Units: g (gram) oz (ounce) ozt (troy ounce) dwt (pennyweight)
III. Using the Tare Feature
You can use this scale\'s tare feature to subtract the weight of an empty container or vessel for net weight determination. NOTE: The weight of the container will subtract from the available capacity.
1. Place the empty container or vessel on the weighing platform.
2. Press the TARE key once. The display will then reset to zero. If the container is removed, it\'s weight will be displayed as a negative number.
3. You may now fill the container with the quantity to be weighed. The display will show the net weight of the contents.
4. To return to normal weight display (gross weight), remove any items from the weighing platform and
press the TARE key again to re-zero the scale.
IV. Calibration / Adjustment
1. Turn the scale on by pressing the ON/OFF key.
2. Wait for the display to show "0.0g" or "0.00g" then press and hold the MODE key until the display shows "CAL", then release.
3. Press the MODE key again. The display will flash "CAL" followed by the required calibration weight.
4. Place the required calibration weight on the center of the platform. The display will show "PASS" then return to normal weighing mode. Calibration is complete! You may now turn the scale off.
V. Error Codes
1. OUTZ - Zero range has shifted. Perform calibration adjustment. If the problem persists, the load cell may be permanently damaged due to overloading.
2. 88888 - Maximum capacity exceeded. Remove the extra weight to avoid damaging the load cell.
3. L - Batteries are low. Replace the batteries.
VI. Specifications
DZ3-100 DZ3-600
Max. Capacity 100g 600g
Readability 0.01g 0.1g
Min. Weight 0.03g 0.2g
Power Two (2) AAA Batteries
Dimensions 3.0 x 5.0 x 0.8 in.
Platform Dimensions 2.5 x 3.0 in.
For warranty and support, please email
warranty@digitzscales.com
Aug 20, 2014 | Office Equipment & Supplies
How do I reset my Weight Watchers Scale WW67T? It doesn't matter who gets on, we all weigh 150.1 pounds. How can I reset this? I put in a new battery also. Thanks
Wexem,,,, thank you. Your instructions worked like a charm. Sad that the manual doesn't mention or contain reset instructions.
Feb 04, 2012 | Health & Beauty
Avery H500/L200 Avery Weighing Scales For ForkliftTruck When scales powered on, screen displaying ''balance limit''. Scales will not function.
The zero capture is out of the 2percent tolerance so the cell is either faulty or requires zeroing. Open the unit and press the micros itch on the left of the board. The display flashes s. Press the zero key to change to flashing E. Press store to scroll to zero balance. Press semi auto tare. This captures zero without clearing the span calibration. The display will scroll around for a short period when complete press store.. Release the micro switch and scale will go thru warm up routine then display zero. Hope this helps, regs Darren.
Sep 28, 2011 | Health & Beauty
Need instruction manual. When weighing a container....how to set the weight so you do not have to subtract container weight
You have provided very little information and your question ended up in the vacuum cleaners category. I know your question is related to a scale so I will take a stab at a solution. If there is a "Tare" button, put your container on the scal and press the tare button, you should now see zero for the container and the scale will begin measuring the weight when you add something to the container.
Jun 27, 2011 | Vacuums
Can get burners to light but there is no presser.cleaned and blew out all parts, replaced regulator with no luck. what should i try next
Try turning off the tank, disconnecting it, then reconnecting it. Then very slowly turn the gas tank back on. Also make sure your tank isn't almost empty! The empty weight of your tank is stamped on the collar as T.W. (tare weight). 1 gal of propane weighs 4.25 lbs. Put it on a bathroom scale and see if it weighs less than the tare weight + 4.25 lbs. Let me know if that solves it. If not, we'll dig deeper. Douglas
Jul 13, 2010 | Weber Grilling
Royal Postal Scale Gray Logo
154 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
