Question about Jenn-Air JCD2389G Side by Side Refrigerator
Refrigerator noises I have a Whirlpool side by side model, I am just wondering what it is supposed to sound like on a normal basis. I can hear the fan blowing sometimes and a humming sound, but then it seems to shut off. My items are not thawing out but sometimes there is no sound at all. Is that normal or should I hear the fan running all the time when I open the freezer door?
  • 410 Answers
Your refrig will have "normal" off cycles for when the temp control is satisified and when it goes into defrost cycle. normal run time for most units is 60-80%. main thing though is that your temps are normal. thx peyton
Posted on Jan 22, 2009
I have a Whirlpool refrigerator (model # ET2AHTXLT00). It intermittently makes a loud clicking noise that comes from the left side of the refrigerator (when youre facing it). It still is cold inside both...
What you are hearing is the fresh food damper. It sounds like it stuck open or stripped. You should have a tech look at it. It could stick closed and make the fresh food section too warm. Ihope this helps.
Aug 25, 2011 | Whirlpool GC5SHEXNS Side by Side...
Light bulbs are flashing with constant pulsing noise
It sounds like you have a lose connection for the lighting. It may be at the light bulb socket or even at the door switch. It also could be a lose wire going to or from these items. with a little detective work you should be able the bad connection.
I hope this helps :)
Apr 21, 2010 | Whirlpool GD5SHAX Side by Side...
My Whirlpool Gold side-by-side refrigerator GS6NVEXSL00 wont give me the ice out the door. It makes ice, but when I press the button on the door nothing happens. Seems like the button went out. HELP!
Does the water dispenser work? Is there a light at the dispenser panel, does it light? Do you hear any noises or motors running when you actuate ice dispenser? You could have a power issue for the dispenser. Some newer whirlpool models have an issue with the wiring leading into the door at bottom being so securley fastened to frame, the lack of movement forces the wires to bend, and in time break, with door usage. If water dispenser works, and you hear no sounds when the ice lever is actuated, then you have a problem with the dispenser panel circuit board. if water works and you hear some sounds when ice lever is actuated, such as a loud popping noise, then you have a bad ice dispenser auger motor, not churning the ice out of the bucket.
Mar 18, 2010 | Whirlpool GS6NVEXSL Side by Side...
Whirlpool refrigerator side by side freezer won't freeze
your over-load/contactor is defective, un plug it from compressor and shake it if it rattles its bad
Oct 28, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Have a whirlpool side by side refriferator estate model. Freezer won't get cold. Cleaned off underneath,fan is turning, Unplugged for awhile and plugged back in. Keep hearing clicking noise coming from...
Plastic box you're referring to contains the start components for the compressor. The clicking sound sound you hear is the protective overload shutting the compressor off because it won't start.
Two possibilities
1. The components inside the plastic box (cover) are defective and need replaced. You can remove them, by snapping off the cover and pulling them straight off. Most appliance parts houses will be happy to test them.
2. The compressor has failed internally.
Note: In my personal experience when dealing with whirlpool Estate models, 99% of the time it has been a failed compressor.
Oct 28, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
No ice
sound like u have ice blocking the icemaker from moving..thaw with hairdryer. are the cubes a bit small?
Jun 09, 2009 | Whirlpool GS6NBEXR Side by Side...
Lights out inside refrigerarator and making noises
bad door switch unplug and pry out switch and replace the sound you are hearing are wires burning
Apr 13, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool gold makes banging noise
If the refrigerator is working fine the banging noise you hear is the isulation inside the refrigeratior walls that exand and cotract with the change of temperatures. you don t have to worried about it.
Apr 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool refrigator side by side(2 doors side by side)
This sounds like the curcuit board has failed. No repair is able to be made to the board. Just replace the board and all should be fine..
Nov 06, 2008 | Whirlpool GB9SHKXL Bottom Freezer...
My refrigerator is not functioning
Sounds like your compressor is overheated. this could be caused from one or more of these things since you have already cleaned out the condenser.
  • low on refrigerant
  • compressor burning out
  • start components for compressor are bad( start relay,or run capacitor)
Jan 27, 2008 | Whirlpool 21.7 cu. ft. Side-by-Side...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
97 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
