Question about Toshiba 40BV702B 40 inch full hd lcd tv 1080p freeview usb 4 x hd
My Toshiba 40" LCD TV Has High Pitch Buzzing Noise
Been like this since I bought it, I turn it on and theres like a whistling noise (imagine having tinnitus - that sorta noise), Can hear it on low volume but I turn the volume up to try and drown out the noise. I'm ringing toshiba next week, just wondering if theres any fixes before I ring them and get a service charge! Thanks
  • newstart_200
    newstart_200 Jan 13, 2013
    Also, The noise is still there when I change to different HDMI ports & When I mute it.
SOURCE: Toshiba Plasma clicking noise
Check the fan, it may be dust or a bad bearing.
Posted on Oct 10, 2007
IFIXALL
  • 868 Answers
SOURCE: no audio brand new toshiba 42xv540u
speakers are muted.
Posted on Jun 10, 2008
  • 223 Answers
SOURCE: Toshiba 50hp66
I think that the pop you heard was an electrolytic capacitor blowing its top on the picture frame board. If you are able to check this for yourself by looking on the board for the one/s with a bulging top or are a brownish/black colour like something has caught fire. And also in this situation smell can be of great help as it will smell burnt out but PLEASE before putting your nose or anything else in the tv take all necessary precautions against electric shock and discharge any electrolytic capacitors in the vicinity. If you are not able to do this yourself find a competant technician. Hope this helps.
Posted on Oct 07, 2008
  • 140 Answers
SOURCE: toshiba 37av502u hum noise
It sounds like you have a quiet cooling fan problem. Those particular types of tvs are notorious for that kind of a problem after a couple of years. You can take the back cover off and remove the fan. Pretty straightforward and go to an electronics supply house and ge a matching one. That is your best bet of fixing the problem for yourself. God bless you.
Posted on Jan 12, 2009
dsacco86
  • 1077 Answers
SOURCE: problem with TOSHIBA LCD 26AV500A
Only advice I have is use the Warranty. Take it back to the store.
Sorry I can't help more.
Good luck
Posted on Feb 04, 2009
Tv just started making a very high pitched noise, although picture and sound are fine?
Barb, noise may be from a power supply/ transformer on it's way out.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
HELP what is that high pitched noise when tv is on
Is your LCD making buzzing or high pitch noise
Mar 04, 2016 | Sanyo Dp55441 TV
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ā€Ž5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ā€Ž7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ā€Ž12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
Norcent buzzing noise
Check its back-light inverter board. The transformer's core of it can make this high pitch noise; like a whistle; if it is loosely fitted. Gopakumar Gopalan Google
May 25, 2014 | Televison & Video
Vizio high pitch noise while watching
It sounds like the speaker wire it not grounded good. It sounds like a high pitch whistle or crackle.
May 05, 2012 | Vizio E470VL 47 in. HD-Ready LCD TV
Buzzing/fizzing noise from back of sony flat screen tv
Below is an image of rear side of your TV, Sony KDL-40W5500
Top right corner is marked there and possible cause of noise seems back light inverter board, there are high voltage going to CCFL inside LCD panel and seems high voltage leakage causing that buzzing/ fuzzing noise.
Replace back light inverter board upon voltage leakage confirmation.
Thanks.
Oct 23, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Loud humming or high pitch buzzing noise coming from my rca dlp tv 50 inch
I have a very high pitched sound and when I move the tv it will stop for a second or two and then start again. The sound sometimes stops all together. But very high pitch sound.
Aug 08, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
TV screen wont turn on but just a loud noise coming from the tv
I think maybe the G-board needs to be replaced. A TV shop will have to repair it. They normally start around $200.00
Jul 02, 2007 | Panasonic CT-32G23 32" TV
High Pitch buzz noise when plugged in and it doesn't turn on
The tv has a shorted component and that is why is making the noise,call a qualified technician to find it and dont try to use it anymore.Is not a fuse.
Sep 12, 2006 | RCA F25649 25" TV
Toshiba 40BV702B 40 inch full hd lcd tv 1080p freeview usb 4 x hd Logo
142 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
