Question about Poulan Garden
Inspect and replace gas lines - Poulan Garden
  • 169 Answers
My nissan armada 08 se has 104000 and i would like to know what parts do I need to do a regular tune up?
Service due at 105,000 Miles
Action: Description Rotate Wheels & tires Replace Crankcase Oil Filter Change fluid Crankcase Inspect fluid level Transfer case Inspect fluid level Rear differential Inspect fluid level Front differential Inspect Driveshaft(s) Inspect Drive Belt(s) Inspect Constant Velocity Joint Boots Replace Cabin air filter Inspect Brake Friction Material Inspect Brake lines & hoses Inspect Brake rotors Inspect fluid level Automatic transmission/transaxle Replace Spark plugs
Jan 29, 2015 | GAS Motorcycles
Gas fumes from maytag range
"The professional gas installer has been here several times to check the. Gas lines." Ask the professional gas installer to do a leakage test and inspect for a cracked gas line.
Jul 29, 2017 | Maytag 30" Self-Cleaning Slide-In Gas...
I have a fuel smell and I have cleaned the throttle body replaced the gas cap code kept showing P0449 don't know what to do. Friend said to replace the canister purge valve is that right
Smells Like Change Symptom: Gas Fumes Change When: Driving Change Where: Passenger Compartment Change -->lg-bl.jpg lg-br.jpg
Priority Action Part Type Cause 1 Inspect Fuel Line Assembly Loose or Damaged Fuel Line or Connector. 2 Inspect Fuel Filter Leaking Fuel Filter. 3 Inspect Fuel Tank PUNCTURED or Damaged Fuel Tank. 4 Inspect Canister Purge Valve Faulty Canister Purge Valve is Leaking. 5 Inspect Carburetor Dirty and Improperly FunctioningCarburetor. 6 Inspect Fuel Injector Dirty or Worn Fuel Injectors.
Jan 08, 2013 | Cars & Trucks
Husky Chain Saw 4.1 Model 18 in Bar
Sounds like a gummed up carb. Inspect and clean carburetor. Particles of broken fuel line or resin of old gas maybe restricting fuel jets.
May 19, 2012 | Husqvarna Garden
25cc Gas Line Trimmer- both gas lines have disolved and the fuel filter is just rolling around inside the tank. I have replacement fuel line. Do I need to replace the fuel filter?
It is never a bad idea to do so. If the unit has some years on it, I would say yes. Inspect it, and if it is still nice and white, keep it. If it isn't, I would replace it.
Aug 14, 2011 | Craftsman 25cc Gas Line Trimmer
How do you repair gas lines?
Find the best spot that is not rotted or rusted.Cut the line there and either you can buy a line flaring tool and replace the bad area.The easiest and cheapest way it to replac it with rubber line and clamps.Make sure that you purchase the High Pressure fuel line or it will not pass inspection.
Apr 21, 2010 | 1993 Chevrolet Lumina
For code#po442
evap system leak small most of the time this code comes from forgetting or properly replace their gas cap--others are gas cap not sealing replace cap-or a small leak in the fuel vapor lines -check cap and reset code if comes back check seal arund cap repair or replace if damaged -if good inspect the fuel lines and hoses for small cracks or damage repair or replace if necessary
Jan 20, 2010 | 1999 Volvo S80
Have an old T27 the gas cannot be sent from the tank to the bulb and into the carburetor.
Just a thought, either your fuel filter is clogged, your gas line is collapsed, or there is an air leak in the system between tank and bulb. Obviously you've inspected the gas lines and the bulb for wear (cracks) and you haven't recently replaced gas lines where it might have been possible to switch in / out lines....the only reason I ask is that is what I did when swapping parts from one model trimmer to another..my bad, but I finally figured it out.....Please let me know.
Oct 24, 2009 | Husqvarna 28cc Gas Line Trimmer
Home Inspector detected gas leak coming from inside Dryer
The main valve in the burner may be leaking a little--if so, the valve assembly will need to be replaced. Did the repairman detect any gas as the home inspector did? Make sure the machine is level and does not rock in any direction that might fracture or loosen the incoming gas line. Have the gas supply company check for leak.
Aug 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Fuel leaking from top of gas tank
sounds like you are going to have to drop the tank out to inspect and fix. with luck it will be leaking from the fuel pump seal or the return line.
Bad luck would be if the tank is rusted out and needs to be replaced.
Syphon as much gas out of the tank as you can before you drop it , gas is heavy.
May 08, 2009 | 1991 Toyota Pickup
Garden Logo
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
