Question about Compaq P4-M, 2.0GHz Pentium 4-M (303282001) Retail Processor Upgrade
Changing a cpu on a compaq 5000T/REM
It has a 1.6 P4 cpu in it and I have a 2.4 cpu to put in it. When I changed it and I look in control panel under system it shows up as a 2.4 but it shows it running at 1.79. I have Windows XP.
Hey, I had that same issue with the exact same specs and stuff you have to update the BIOS. Click on or copy and paste the link that leads to the download page.http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00007682&cc=us&lc=en&dlc=en&product=92873 - Scroll down until you see a link that says Drivers and Downloads. Follow the instructions and download the file. Run the setup and install on a formatted floppy disk. (it has to be formatted as a MS-DOS startup disk). After that put it in and the setup should start automatically when you start the computer. Just install it and follow instructions and it should fix your problem.
Posted on Apr 30, 2009
    Scholar:
  • 40 Answers
I've located this description when installing the pentium 4 processor on Windows XP. If you have not performed these steps this may be the cause of what you are experiencing. To save you time I've pasted the section below--> Operating System Support
Nearly all modern operating systems designed for the Intel Architecture have support for the Pentium 4 processor, although some may require specific versions or processor support files. Many Microsoft operating systems like Windows* 98 SE, Windows NT* 4 with Service Pack 5, Windows* 2000, Windows* ME, and Windows* XP support the Pentium 4 processor. Linux* distributions based on the Linux* 2.4 core support the processor. Also, many other vendors have support for the Pentium 4 Processor in their operating systems. System integrators should verify that the operating system they have selected supports the Pentium 4 processor.
Note: Windows XP or certain versions of Linux are required for Hyper-Threading Technology2 support for the Pentium 4 processor. For additional information on integrating systems based on the Pentium 4 processor supporting Hyper-Threading Technology, refer to the Integration Overview for Systems Based on the Intel Pentium 4 Processor Supporting Hyper-Threading Technology.
All operating systems that support the SSE instructions that were first introduced with the Intel® Pentium III processor will also support the SSE2 instructions introduced with the Pentium 4 processor. To experience the power of the SSE2 instructions, it is critical that system integrators install drivers and software that have been optimized for the Pentium 4 processor's SSE2 instructions. For example, for maximum system performance, system integrators using Microsoft operating systems that support DirectX* should load DirectX 8 (or higher).
Software Optimization
With specific drivers that use the SSE2 instructions, graphics accelerators, audio hardware and software, and other system resources can experience substantial performance gain. It is critical that systems also use APIs that use SSE2 instructions to achieve maximum performance. Two examples are Microsoft's DirectX 8 (or higher) and Open GL 1.2 (or higher). Most major graphics accelerator vendors have optimized drivers that use the SSE2 instructions. Graphics card vendors typically highlight support changes with new driver releases. Download and install the latest drivers (dated later than October 2000) from the vendor's Web site. Also, verify that the driver version contains optimization for the Pentium 4 processor.
Many applications also use the SSE2 instructions to experience the breakthrough performance of the Pentium 4 processor. System integrators should contact software vendors to verify support and determine version information.
System performance is greatly affected by proper operating system and driver installation processes. For example, it is important to install the latest Intel® Chipset Software Installation Utility immediately after installing most Microsoft operating systems to ensure proper drivers for the chipset are installed prior to installation of other drivers. System integrators should confirm boxed Intel Pentium 4 processor-based systems are optimally configured and integrated.
Conclusion
Boxed Intel Pentium 4 processor-based systems require proper integration. System integrators that follow the guidelines in this document will experience higher customer satisfaction by providing higher quality systems.
Please let me know if you have success with this.
Thank You, Raph30
Posted on Jan 25, 2009
How to increase virtuall memory
For Win XP;
1.Click Start, and then click Control Panel.
2.Click Performance and Maintenance, and then click System.
3.On the Advanced tab, under Performance, click Settings.
4.On the Advanced tab, under Virtual memory, click Change.
5.Under Drive [Volume Label], click the drive that contains the paging file that you want to change.
6.Under Paging file size for selected drive, click to Custom size check box. You can enter the amount of memory you would like to reserve for Virtual memory by entering the initial and maximum size.
7.Click Set
When you are prompted to restart the computer, click Yes.
Special Note: You should choose the same amount for the initial size and maximum size. This will Stop your CPU from constantly changing the paging file.
Aug 10, 2010 | Computers & Internet
How can I increase the memory for this computer
In Windows XP
7.Click Set
In Vista
1. Click Start button Picture of the Start button
2. Click Control Panel
3. Choose System and Maintenance and then click System.
4. In the left pane, click Advanced system settings.
5.On the Advanced tab, under Performance, click Settings.
6. Click the Advanced tab, and then, under Virtual memory, choose Change.
7. Click Custom to change the Initial size (MB) and Maximum size. See the hot tip above.
Remember to choose the drive you would like to use to increase the virtual memory. In most cases it usually your C: Drive. You can set the initial size and maximum size after clicking the Custom size check box.Remember its better to keep the Virtual memory values the same.
Also having enough available space is absolutely necessary for your virtual memory and RAM to function properly.
Jun 11, 2010 | Compaq Presario 700 470024-192 Notebook
Do you know anyone that can tell me how to change my screen configuration to 1024x768 on a compaq, with windows vista
Hi, I hope that you have the proper driver for your video card before you try the step provided.
1. Click the start button
2. Click on Control Panel or Control
3. Click Appearance and Personalization
4. Click Personalization
5. Click on Display Settings
6. Under Resolution, move the slider to the desired resolution you want (1024, 768)
7. then click apply.
Hope this helps.
Jan 12, 2010 | Compaq Presario 5000 PC Desktop
Can"t change LCD display panel from REM status--
turn to rem off then you can change temp if not bad display board
Dec 29, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
How to play .rem music
Mr Dinesh
REM file extension appears when media files are saved to device memory and are not removed when the media file is transferred to a computer.
You cant change this..after transferring the media file to the computer, rename the file to remove the .rem extension.
I hope this info help full for you
Nov 11, 2009 | RIM BlackBerry Curve 8310 Smartphone
Recently my TV2 connection has become an issue: I get the Press Select to watch TV on the screen, but the remote will not work. (This is a UHF remote) I've even replaced the remote - and yes it's a Dish...
Check your UHF antanae on the back of the reciver to make sure it is standing straight up. you can also see if the tv 2 remote works at the tv 1 location to check for interference. if you have a dvr check to make sure shared view is disabled by pressing menu option 6 then option 2 and the disable. if this option is greyed out, put your reciever into single mode by pressing the mode button and try again. if none of this works, If your tv 2 remote still does not work at tv 1 ( ie: changes chan at tv 2 location at rec but not at tv 2. then readdress your remote by pressing menu, opt 6, opt 1 and opt 3, this will be system info. do this at tv 1 location, then with tv 2 rem in hand, press the sat key till all buttons light up at top, then release, enter any number 1-15 that is different from rem 1 add. then press pound. then press record 3 times to see if number changes for rem add. 2. if not then you have a defective rec. call 1-800-333-3474 for technical assistance.
Nov 10, 2009 | DISH Network IR Remote Control
How do you put a password into a windows 98 compaq laptop?
Go to your control panel then to user accts. then you can set up passwords.
Oct 08, 2009 | Computers & Internet
Multiple remote control problems
take 1 of your tv 2 remotes to is designated recvr., press the menu button on tv 1 rem and then 6-1-3, this will enter sys info one. look at the remote add. in box i for tv 1 and box j for tv 2 change the tv 2 to a differnt number than tv 1 by pressing the SAT button till all mode light light up then release, enter a number between 1- 15 but other than tv 1 rem addr. and the the pound key below number 9. then press record 3 times if successful the number you entered will display and tv 2 rem addr. the problem is that both tv 2 remotes are on teh same rem addr number. by changing one of them it will resolve your issue.
Sep 28, 2009 | DISH Network IR Remote Control
Very loud fan on my HP Compaq 6715b.
How long have you owned the computer? Did you clean up the inside after you ever since after you bought it? If not, the heatsink might be covered in dust, blocking the airways. If you need instructions on how to open the computer and such, just contact me.
Jul 09, 2009 | HP Computers & Internet
Computers & Internet Logo
205 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
