Question about Leupold VXR 3-9x40mm FireDot 4 - 110687
I have a leuopold vxr 3x9 duplex firedot when dot goes off after motionless for 15 minutes the dot only comes up to orignal setting by pushing side button
Red dot will not come back to orignal setting after setting motionless for 15 minutes
How do I set the clock
If there is an "H" and "M" marking on the right side of the radio panel, push the little dot beneath each, with a ball point pen to advance the hour and minute.
Dec 05, 2014 | 2002 Dodge Caravan
I have no power going to the climate control unit. No fans, no digital temp setting, no air direction control..nothing. 2005 Dodge Caravan. Can't find any blown fuses. Where does the power orignate...
it only takes 2 things to fix power.
a voltmeter
and alldata dot com.
(a road map we call it)
see power distribution page. its all there. no guessing.
will cost you $15, 1/10 of 1hour shop labor, really its free.
here is discounted link,
http://www.scantool.net/software/alldata-diy-1-month-subscription.html
Oct 02, 2013 | 2000 Chrysler Town & Country
Sharp ARM237 crooked prints and jams w/double sided printing only.?????????
this will be an issue with the duplex rollers check where it is jamming is it in the duplex unit if yes then check the duplex rollers for wear worn rollers will cause scews also check there is no torn pieces of paper stuck in the guides of the duplex
a good thing to do is to get a thin piece of card stock slide it into the duplex manually and frred it where the paper path goes on the duplex from beginning to end and it will push out any thing in the path
Jan 20, 2011 | Sharp AR-M237 Digital Copier
Need to reset to orignal settings
to reset un-plug for 15 minutes
Oct 17, 2009 | Microwave Ovens
Canon IR1018 forces duplexing
Go to service mode MENU and #, clear all and ok,
after that machine goes to factory sett., reenter your sett. it should work
Jul 08, 2009 | Canon Duplex Automatic Document Feeder
I have a Lanier 5245. I am getting an error when
Your duplex is the big box on the right side of the machine push the back side shut against the machine and try again
May 08, 2009 | Lanier 5235 Printer
Xerox Phaser 8560 Not Duplexing
Check to make sure that "Plain Paper" is selected as the paper type for tray 2 in the printer's internal setup. If it's not set as the default then the printer may think you have labels or some other special media loaded that can't be printed in duplex.
1. Go to the printer.
2. Use the up and down arrow keys to hilight "Paper Tray Setup" on the main menu and push "OK".
3. Use the up and down arrow keys to hilight "Tray 2 Paper Type" and push "OK".
4. Hilight "Plain Paper" and push "OK".
5. Press the return button (the one with the little rounded arrow symbol) to return to the main menu.
That should solve it.
GOOD LUCK!!!!!!
Feb 13, 2009 | Xerox Phaser 8560DN Laser Printer
HP LASERJET 4250 DUPLEX ISSUE
only problem ive had with the earlier model not doing duplex was a sheet of paper in the duplexer bin . This is hard to find but if you pull out the paper tray and look in the space where the tray goes up above theres a lever which you can push and it releases the hidden duplex bin which stores the paper at half way through the double pass and if there is any paper in there then the printer will not duplex.
Oct 02, 2008 | HP LaserJet 4250n Printer
Problem in Canon Laser Shot LBP 3300
Their is Button in the rear of the printer a Blue jack push it inside for duplexing LGL /LTR size paper and pull outside for duplexing A4 size its easy
Dec 01, 2007 | Canon LASER SHOT LBP 3300 Printer
Leupold VXR 3-9x40mm FireDot 4 - 110687 Logo
47 people viewed this question
Top Leupold Optics Experts
ray gallant
Bill Boyd
Are you a Leupold Optic Expert? Answer questions, earn points and help others
