Question about Refrigerators
My mini fridge is set at 5 and it freezes then defreezes
I bought an Emerson Compact Refrigerator C276BE a couple months ago. The problem is if I set it to 4 it keeps everything cool but the freezing compartment does not work. When I set the temperature to 5 or higher, the freezing compartment has ice buildup and it occasionally defrosts itself. Its a cycle, it freezes then defrosts on its on when its set on 5. Is something wrong with it? Because I would come home to a puddle beside it. In addition, I considered checking the back and the black round object in the back is really hot. If there is a huge problem, is it fixable? And how can I fix it?
dididsaythat
  • 291 Answers
SOURCE: Refrigerator freezes contents
Get a new cold control for it
Posted on Sep 02, 2007
  • 1122 Answers
SOURCE: Refrigerator freezes up
PLEASE DISREGUARD GUEST FIXYA SOLUTION,FREEZER PROBLEM PROCEDURE IF NOT DEGITAL,FIRST CHECK IF ICE ON BACK FREEZER WALL. STEPS-FIND DEFROST TIMER,BOTTOM FRONT ,BOTTOM BACK, INSIDE FRIG.ON CONSOLE,LISTEN TO SEE IF FAN IS RUNNING IF SO TURN THE DEFROST TIMER CLOCKWISE TILL YOU HEAR A CLICK SEE IF FAN TURNED OFF IF SO YOUR FREEZER IS IN DEFROST,FREEZER WILL COME OUT OF DEFROST IN 20-30 MINUTES IF IT DOES AND THE FAN COMES ON YOU HAVE ELIMINATED DEFROST TIMER&FAN,NEXT REMOVE BACK PANEL TO FREEZER IF THERE IS ICE FORMING REMOVE BOTH LEADS TO HEAT AND CHECK WITH VOLT METER ON OMES,IF YOU GET ANY READING THE HEATER IS GOOD,IF NO READING REPLACE HEATER AND CLIPON TEMINATOR,IF HEATER IS GOOD DEFROST COILS WITH HAIR DRYER TOP TO BOTTOM AND THIS WILL ALSO CLEAR THE DRAIN,IF EVERYTHING CHECK OUT GOOD DEFROST TIMER ,FAN ,HEATER, DRAIN, YOU NEED ONLY TO REPLACE THE LITTLE ROUND CLIP ON TERMANATOR,LET ME KNOW-MIKE
Posted on Jun 17, 2008
22yooper
  • 828 Answers
SOURCE: Frigidaire is freezing everything
Make sure the light is going off when the door is in the closed position. Find the switch that the door makes contact with when it closes. If the light is not going out the heat from the light being on could cause such a problem.
Posted on Aug 25, 2008
SOURCE: Everything freezing in vegetable and Custom Cool compartment
them you have a broken damper that lets the air in and closes when temp has reach you need call a tech if you dont know how to repl the damper
Posted on Nov 01, 2008
  • 219 Answers
SOURCE: Defrost Timer?
depending on model thats either your timer or cold control would be about 200
Posted on Mar 19, 2009
My refrigerator has intermittent cooling/freezing and moaning. The moaning is from the freezer and has been consistent since I bought the fridge used about two months ago but it just recently started with...
The unit is according to your description is only a couple of monthes old and parts should be covered under factory warranty. Call the toll free number that comes with your refrigerator to have them get a factory trained repairman to come out and see what is the matter. There is a minimal charge for the repairman typically under $100.
Hope this helps,
PS waiting for proper repair causes most problems to get worst, so time is of the essence.
Sep 25, 2014 | Refrigerators
Fridge Freezes Everything
there is a motor with a flapper that opens and closes to keep your temp correct in the refrigerator side most likely the motor is bad and stuck open so your air from the freezer has constant flow to the refr side. the flapper is in the back of the refr behind a cover where the air flows in.
Apr 16, 2014 | Emerson Cr180 1. Cu. Ft Compact...
My mini fridge will turn on, but will not stay on. It turns off after 1-5 hours
If it's new it is under warranty, if not it sounds like a thermostat or timer problem.
Nov 18, 2013 | Emerson 2.8 Cu. Ft. Refrigerator - Silver
Black and decker mini refridge freezes food on lowest setting
The lower the setting the colder the fridge should be, the dial should be turned to the right. A refrigerator should be kept around 35-36 degrees F
Jan 03, 2012 | Food Processors
Mini Fridge freezing everything
Yes, thermostat and when they go bad they eiter sop , keepgetting colder or out of calibration, I will see if I can find one, Really any small two wired refrigerator thermostat wil be fine, Sea Breeze
Mar 18, 2010 | GE SMR03BASWW Compact Refrigerator With...
My daughter's Emerson CR500 compact refrigerator completely stopped getting cold about four months after we purchased it. It would cost me $57 to ship it to CA to have it fixed, so I'm wondering if it...
My husband and I bought this same refrigerator around 11/2009 and it doesn't work now either. We too bought this refrigerator at a local target. Yikes. We bought ours for our daughters dorm room and it didn't stay working even one year. Is that how Emerson told you to handle it - by shipping that stupid thing to CA. Thats ridiculous.
Aug 17, 2009 | Emerson Refrigerators
Kenmore Side by Side Refrigerator too cold
On a fridge freezer only the fridge temperature is monitored. In a cold location the fridge might not even need cooling and the freezer would get too warm but the thing won't care.
If the fridge sensor sees it as too warm then it will keep the motor running and the first thing to get really cold is the freezer.
Remember the freezing part is not temperature controlled ion a fridgefreezer.
Apr 28, 2017 | Refrigerators
Koolatron Mini Fridge Overheating
Check the condensor fan behind the fridge which is designed to cool the compressor/gas line by blowing air over the condensor. When this fan motor seizes or stops running, the gas gets very hot and because it is skin cooled too, the outside of the fridge also gets very hot. You can overcome the problem temporarily by putting a standing fan behind the fridge, blowing onto the compressor and under the fridge untill you can have the problem rectified.
Nov 03, 2007 | Koolatron Mini Fridge Compact Refrigerator
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
