Replace the baffle - Washing Machines
    Sergeant:
  • 291 Answers
There are several vids on YouTube that will show you how to do it. You can go general by typing this into search bar:
" front load washer rubber boot " or try this instead: " Whirlpool washer rubber boot " if you have a whirlpool machine for example.
Good luck. Let me know if those prove useless.
Posted on Jan 13, 2013
Kenmore elite steam dryer replacing a baffle
Remove the top and you will be able to see the side of the drum- rotate it until you expose the screws to the loose baffle.(tighten them all while you are in there) Drum Baffle WPW10112972
Jul 09, 2016 | Kenmore Dryers
How to replace baffle inside tumbler
some baffles have a screw at the far end inside the drum. remove screw and push baffle to remove. If you dont have that type of baffle then you would have to open the top cover and tilt back. You will be able to see the screws that hold the baffles. some tops have screws in the back to remove top. Some have clips in the front that would need to be push in with a small spatula. Good luck. I dont know if your able to post pictures with your question, it would really help.
Nov 18, 2015 | Bosch Dryers
How to remove baffles
Step 1 - Remove Exhaust Remove the whole exhaust from the bike.
Step 2 - Drill Out the Baffle With a ½" hole saw and a handheld drill, insert them into a hole in the exhaust's outlet. The handheld drill will not go further inside the exhaust once you hit the baffle. Drill through the 1st baffle and then each remaining baffle until they are are drilled. Remove the baffle pieces.
Step 3 - Replace Exhaust Reinstall back the exhaust system onto your bike.
Jul 12, 2015 | Motorcycles
Coins in my baffle
Usually not but if you get a thin blade screw driver, in the center of the baffle gently pry up the edge and wedge it under creating a gap to get the coins out. But be carefully because most of the times you can't get replacement baffles !!
Jun 01, 2014 | Whirlpool LHW0050PQ Front Load Washer
Valkyrie baffles missing
I found an article and a video for your source on how to replace motorcycle baffles. By following the instructions in the article I am sure that you can now replace the baffles on your motorcycle.
-Phanter
Continental Motorcycle Tires
Mar 25, 2013 | 2000 Honda Valkyrie Interstate
Need to replace a baffle that broke off . MED9800TKo model baffle broke off insde on the dryer drum
Remove the top panel to access the outside of the drum where the baffle securing screws are found. Remove the three hex-head screws from the rear flange of the dryer's top cover the lift the rear of the cover and slide it back so the tabs clear the catches on the bracket and remove the cover from the unit.
Turn the drum until the baffle screws are on top then remove the screws and the baffles. Install the new baffles then the top cover. Make sure that the tabs slide under the bracket catches when you reinstall the top cover. The top cover screws have nylon flat washers on them. Be sure to use these screws when you reinstall the top cover.
Jul 18, 2011 | Maytag MED9800T / MED9800TQ / MED9800TK...
Change one baffle only or do you need to replace all three?
No as long as the baffles are screwed in properly and no other damage is present it is not important at all.
Sep 30, 2009 | Kenmore Elite 45986 Front Load Washer
Replacing the drum baffle in kenmore elite he3t front loading washers
The baffle basket, I ordered from sears for my Kenmore Elite he3t washer was a "new" design but the screw holes lined up. My baffle basket did not come with the screw either. I took out the screw from an existing baffle basket and found something close. Test it in the baffle basket before you try to install it. Be careful not to drop the screw or bit.
To replace the baffle basket. Remove top of washer using a screwdriver with a T20 torque bit. There are three screws at the rear. The top slides back about an inch and lift up. Place aside. Then you will see a hose going into the drum. Ignore the clamp, just squeeze the end going into the drum and work it out. Now you need to insert the baffle basket in the drum through the front door. It is easiest to rotate the drum so you are inserting it on the bottom. It slides in with the small end toward you and you must pull it forward. Hold the drum for leverage. Now rotate the drum so the new baffle is on top. You need to line up the screw hole and screw in a small screw. Replace the hose and top of washer.
Good Luck...
Aug 09, 2008 | Washing Machines
Baffle broke off
Hi, one of our baffles broke recently and I ordered a replacement kit from http://www.appliancepartspros.com/
Here is the link that will take you directly to the page:
http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Baffle-kit--3-pack-item-number-AP3769371.aspx
Dec 30, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
