Question about Mitac Mio C310 GPS Receiver
Mio C 310 GPS lost signal
I bought Mio C310 GPS a year before and it was working good and last week my cousin bought Mio C520 and I used his SD card in my GPS device had some Mio C520 maps and it made my GPS useless by not having GPS signal at all. And my GPS now can not recognise the location.
How to get it fixed?
  • gerry bissi May 11, 2010
    try rebooting your gps/ On C220, you hold the onoff button down for 10 seconds whcih shuts down the system. Then hold button down for 10 seconds again to restart. Repeat as necessary till it comes back on/
    Look at your c/d to see if the same for your model.
  • 4,369 Answers
Try rebooting by turning off switch on back and turning back on.
Call mio support for additional help. they are good.
Posted on Jun 03, 2009
CRTN
  • 716 Answers
SOURCE: mio c520 second hand
Here You Go Enjoy. Click Here
Sincerely,
Michael Scott
Posted on Feb 20, 2009
SOURCE: mio gps fatal application error.
I have the same problem to my mio. exe has performed and illegal operation. Can you please help I use this very much for my work.
Posted on May 05, 2009
rylee_smith
  • 8619 Answers
SOURCE: replace battery on mio C310 gps
Hi
Thanks for using FixYa. The battery replacement in Mio C310 Gps is fairly easy. You can perform the repairs if you have the following equipments--
Tools required: -precision screwdriver set -wire (24 gauge or smaller) -shrink wrap or electrical tape -wire cutters/stripper -multi-meter -sharp utility knife
Please follow these steps--
  • Remove the rubber caps and two Phillips head screws at the bottom of the unit (don’t lose the screws!) Gently pry the back off starting at the bottom and then work your way up the sides. If you hear the sound of crunching plastic please re-read the first word in the above sentence.
  • Once the back is loose you can pull it down and then away from the main body. Be aware that the speaker wire will prevent complete removal of the units back.
  • Disconnect the speaker wire plug from the main board and set the back of the unit aside. The only thing holding the circuit board in place is the USB port. Simply pry the bottom of the case slightly and lift out the circuit board. There is a ribbon cable attaching the circuit board to the display so be gentle with this.
  • Six clips (three on top and three on bottom) hold the screen in place. Pry the top clips back slightly and remove the screen. Now you’ll be able to remove the batteryu and install a new one.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Oct 12, 2009
  • 68 Answers
SOURCE: Mio C310 maps are out of date
from mio online or from mio distributors - harvey norman etc. Your software will be updated to miomap2008 also (which is the same as the navman software).
Posted on Feb 20, 2010
SOURCE: Install igo8 on Mio C520 device
Shane080,
how do you unlock c520?
please advice...
Posted on Jun 06, 2010
How can i update my mio digi walker c520??
The Users Manual and Support for MIO DigiWalker C520 is here.
I noticed this thread had been read 66000 times there:
onepixel.gif onepixel.gif Question: Is there a map update available for my C-series device?
Answer: We are working on newer map updates with Mio More Express software for C-series devices: C220/S, C320, C520, C720t. The products are in DVD media because the big size is not practical for download. Pleasse check back with Mio support later while slight USB driver issue is under investigation.
Oct 07, 2009 | Digi Mio Walker C520 Car GPS Receiver
Mitac Mio C210 Update maps...
go to Mio Support and see if the C210 can even accept US maps. ALso, check ebay for cd with map restore or "Transmit Map' to blank 2 GB sd card.
Call Mio too.
Jul 06, 2009 | Mitac Mio C210 GPS Receiver
No signal at all.
make sure the battery is fully charged its searching mode and the battery on GPS may be too low
also make sure you are operating in an area the gps internal arial can see the sky
Jun 22, 2009 | Mitac Mio C310 GPS Receiver
I bought my Kodak Easyshare C310 a few years ago and has been working fine. I bought a new SD card as lost my old one, and when I inserted into the camera it said the memory card was full (wasnt as brand...
Hi there
Check to make sure the cards write protect is off, take the card out of the camera, face the card towards you, look for a small white tab on the left hand side of the card, to unlock it push the tab down, it will be at the side of the card like this 59a6de4.jpg . Put it back in the camera and use the menu to format the card.
If the format fails then its a possibility that you will need a new card.
Good luck and thanks for choosing FixYa!!
Jun 08, 2009 | Kodak EasyShare C310 Digital Camera
Mio c520 update problems
it always just shows a computer on the screen like it is downloading info but it is only plug into my outlet
May 17, 2009 | Digi Mio Walker C520 Car GPS Receiver
Mio gps fatal application error.
Mar 26, 2009 | SNK Mio C520 Car GPS Receiver
Mio c520 second hand
Sincerely,
Michael Scott
Feb 20, 2009 | SNK Mio C520 Car GPS Receiver
I have a Mio C220 that does not power on even though battery is charged. Will not work off of battery or plugged into cigarette lighter. Bought it in Nov. 07 but have lost box, receipt, software, and all...
Mio wants people to know, especially the folks who recently bought the Mio C220, that you need to put the SD card in the unit for it to work. The Mio C220 has the maps on the SD Card, and it seems that not everyone knows to put the SD card in the unit before firing it up. No SD card means no working GPS.
Mio Says:
1. Before you power on your C220, insert the SD Card firmly into the slot on the right side of the device
2. Once the SD card has been inserted into the device, power on your C220 by pressing and holding the power button for 10 seconds.
For More information check out the Mio GPS Page on the SD Card for Mio C220
Jun 21, 2008 | GPS
Mitac Mio  C310 GPS Receiver Logo
466 people viewed this question
Top Mitac GPS Experts
Ed Mac
Greg Cann
Greg Cann
Are you a Mitac GPS Expert? Answer questions, earn points and help others
