Question about Samsung WA5471ABW 27" Top-Load Washer with 4.7 cu. ft. Capacity, 13 Wash Cycles, Eco Cold Wash Cycle, 6 Options, 1,100 RPM Spin Speed and PowerFoam Technology: White
My Samsung WA5471ABW top- load washer is leaking from underneath. Is there Nything that I can do to self-repair?
  • Oreata Banks Jan 14, 2013
    Thanks, we tried everything that you suggested and they all check out ok. Any other suggestions? The water is definitely coming from underneath.
  • joe smith Sep 19, 2013
    yes. the drain pump is held on by 3 plastic attachments. Most likely they have cracked, pulling the hose away from tub.
    Sergeant:
  • 291 Answers
You bet there is. But first let's double check some common causes of leaks that may not be located under the machine. Step one is to check the drain hose behind the machine. If a machine gets pushed back too far it can kink or bind that hose and that can cause water to leak from underneath. If that looks okay check that the end of that hose is not inserted into the drain more than about 4 - 5." If it is poked down into the standpipe more than that it can cause a syphoning situation that can also cause leaking underneath. While you are back there check the hoses that lead up to the machine. Make sure the connections are dry. I can't tell you how many under machine leaks i have fixed that originated right there. Just run a finger under each hose connection. If finger gets wet the connection may need tightened ever so slightly with pliers. If all those check out fine let me know. We'll go deeper.
Posted on Jan 13, 2013
Why is my samsung vrt steam washer leaking from the bottem right model #WF331ANW/XAA
Locating And Repairing A Mystery Leak In A Front-Loading ...
? 3:55
www.youtube.com/watch?v=3D5q1ynWb-U
Jul 28, 2012 - Uploaded by SamuraiRepairman ... source of a leak in a front-loading washing machine and then mercilessly repairs it. ... LG Washer Repair & Diagnostic -Leaking Water from front & bottom ... Samsung Front-LoadWasher Disassembly - Washing Machine ...
Samsung vrt steam washer leaking - Fixya
www.fixya.com/support/t13638559-samsung_vrt_steam_washer_leaking
Jul 15, 2012 - Samsung vrt steam washer leaking - Samsung WF338AAB 4.0 cu. ft. ... I have a vrt ... I hope this helps.... Take of that little door on the front. Have a ...
Oct 29, 2015 | Samsung Washing Machines
My top load hotpoint washer leaks in the bottom
You will have to look underneath to locate the point of the leak. If the washer is very old the tub may be rusted through or a hose or clamp could be the problem or a seal is gone.
Oct 04, 2014 | Hotpoint Hot Point HTWP1000MWW Top Load...
Why does it not drain?
It "should drain automatically. If yours does not, please make sure the washer is properly leveled both front to back and side to side, make sure the drain hose is not inserted too far into the drain pipe and that there are no bends or kinks in the drain hose that might cause a blockage. Samsung also recommends cleaning the debris filter on a regular basis (at least once per month). To avoid spillage when cleaning the debris filter, it's important to first empty the rubber drain tube located next to the debris filter into a container. For more information, please refer to the User Manual."
Source: http://answers.us.samsung.com/answers/7463/product/WF330ANB_XAA/samsung-4-3-cu-ft-washer-questions-answers/questions.htm
You can download the "User Manual" and "Troubleshooting Guide" from here:
http://www.samsung.com/us/support/owners/product/WA5471ABW/XAA
I hope that helps you!
Jun 21, 2014 | Samsung WA5471AB 4.7 Cu. Ft. Top Load...
Water pours out from washer underneath
The most common leak for those washers is from the drain pump a really easy and inexpensive repair. It is located underneath toward the front. To diagnose turn on water to tub fill 1/4 the way, pull out machine about 2 feet, tilt backward,you can use a mirror, I just poke my head under. is should be clearly evident where the leak is. The tools to change the pump it requires a screwdriver and pliers. There are two clips and to hose clamps,remove and replace in reverse order.
Mar 13, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer is leaking even when water in waher but washer off
check out you tube search whirpool washer repair, easy to see how to remoe the panel, most likely a bad pump is cause of leak. will be quite evident!! yo can even just tip unit back the underneath is open
Feb 18, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Samsung WA5471ABW 27" Top-Load Washer with 4.7 cu. ft. Capacity, 13 Wash Cycles, Eco Cold Wash Cycle, 6 Options, 1,100 RPM Spin Speed and PowerFoam Technology: White Logo
293 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
