Picture is blur and after adjusting the contrast and tint and color it stays the same
  • 1,238 Answers
I think that is DLP TV right? if so you possibly have color wheel problem, You are not able to fixed it through adjustment, you need to replace it in order to working fine again.
Posted on Jan 14, 2013
  • 4234 Answers
SOURCE: color issue
What you are seeing is the degradation of hte "light engine". This is normal with extended use. You can try blowing out the area with compressed air to clean out any dust. But any LCD based projection system is subject to this breakdown over time. Can you further describe what you mean by overall picture quality? Is it out of focus? do you see separate colors (convergence problem)?
Dan
Posted on Mar 26, 2008
  • 4234 Answers
SOURCE: 50v720 Color Issue / Reply w additional details
I'll check on your specific model, but this problem is usually caused by degradation of the LCD light engine. Hopefully we can work around it for the short term. I'll update this with the model specific info in a day or so (I'm traveling at the moment).
Dan
Posted on Apr 01, 2008
  • 9 Answers
SOURCE: fINE TUNING tv PICTURE
try calling the Insignia help line at 877-467-4289
Posted on May 14, 2008
  • 11 Answers
SOURCE: Picture settings
The settings is on the remote (menu)
Posted on Jul 31, 2008
  • 11 Answers
SOURCE: hitachi 50v500a high definition tv
I had whole redish/pinkish screen on my 50v500 starting a few days ago, then I read through each of the threads on this site for the samilar problems on my model. I found TVtechmaniac's solution (pasted below) solved my problem. Thank you TVtechmaniac!
Enter the I2C Service Menu, be sure the power is OFF.
1. On the front control panel, press and hold the INPUT button.
2. Then press the POWER button for two seconds.
3. You may keep the INPUT button depressed until you see the OSD with the Service Menu displayed.
4. If you don't see the service menu, please repeat Process making sure you wait until the Power blinking LED stops.
5. Execute the Memory Initialize operation after the adjustment values have been written on a sheet of paper. Highlight “MEMORY INTI”, arrow to the right and hold the button to the right (approx 5 sec.) until a check mark appears in the box. This activates the Memory Initialization.
6. After the Memory initialize operation has finished (10~15 sec, the channel will revert to CH 3.) the pink image symptom should be fixed.
7. Write back the adjustment values from your notes to their respective adjustment parameters in the adjustment mode. (In other words, set the Data Values back to the the Data values written down before the Memory Initialization procedure). NOTE: Make sure the SELECT Button is pressed on remote after every change to the values. Failure to do so will result in the data values not being changed.
8. Exit I2C menu. Press exit repeatedly until you go back to the normal picture.
9. Turn the set off-on and Confirm the picture remains in a good condition.
BE SURE TO COPY DOWN DATA SETTINGS BEFORE INITIALIZING I2C SETTINGS
Posted on Aug 31, 2008
The picture is very cloudy and the colors are washed out.
try adjusting the contrast and tint settings.. or restore the factory settings you should refer to your manual to find the proper procedure for it...
but basically its in the settings, display / video, and you will find the contrast and tint and brightness there.
Dec 29, 2012 | Televison & Video
The TV picture shows a double image like "ghosting"?
Ghosting or blurring vision happens due to a faulty video processing board. It may be due to faulty T-con board (BN81-01308A) or a main board ( BN94-01199B ). However, you'll need to check the wiring on both of these boards. Before this I'll suggest you to callibrate the TV by following these settings--
Contrast: 85
Brightness: 46
Color: 56
Tint: G50 / R50
Sharpness: 15
Backlight: 5
Black Adjust: low
Dynamic Contrast: low
Gamma: 1
If this doesn't resolve the issue then turn off and unplug the TV for 4-5 hours and check.
Jun 10, 2011 | Televison & Video
LOOKING FOR PICTURE SETTING SAMSUNG MO.NO.LN-T5265F
This may help you...you can also get an owners manual free on line.
English - 23
Using Automatic Picture Settings
Your TV has Three automatic picture settings ("Dynamic", "Standard", "Movie") that are preset at the factory.
You can activate either Dynamic, Standard, Movie by making a selection from the menu.
1. Press the MENU button to display the menu.
Press the ENTER button, to select "Picture".
2. Press the ENTER button to select "Mode".
Press the ??² or ??¼ buttons to select the "Dynamic", "Standard", "Movie" picture
setting. Press the ENTER button.
?³ Choose Dynamic to increase the clarity and sharpness of the picture.
?³ Choose Standard for the standard factory settings.
?³ Choose Movie for a natural Image without picture enhancements.
3. Press the ??² or ??¼ buttons to select "Contrast", "Brightness", "Sharpness",
"Color", or "Tint(G/R)", then press the ENTER button.
4. Press the ??? or ??? buttons to decrease or increase the value of a particular item.
For example, if you select "Contrast", pressing the ??? button increases it.
Press the EXIT button to exit.
• When you make changes to Contrast, Brightness, Sharpness, Color, Tint(G/R)
the OSD will be adjusted accordingly.
• When in PC mode, Tint, Sharpness, and Color are not available.
Press the P.MODE button on the remote control repeatedly to select the desired
picture mode.
Picture Control
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 00
??¼More
TV Picture
Move Enter Return
Mode : Dynamic
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
Dynamic
Standard
Movie
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
50
??² Con trast ??¼
Move Adjust Return
English - 24
Adjusting the Color Tone
You can change the color of the entire screen according to your preference.
Press the ENTER button to select "Picture".
2. Press the ??² or ??¼ button to select "Color Tone", then press the ENT ER button.
3. Press the ??² or ??¼ button to select "Cool2", "Cool1", "Normal", "Warm1",
or "Warm2".
When the picture mode is set to Dynamic or Standard, Warm1 and Warm2
cannot be selected. Movie mode is only available.
Move Enter Return
??²More
Color Tone : Cool2 ???
Detailed settings ???
Size : 16 : 9 ???
Digital NR : Low ???
Active Color : On ???
DNle : On ???
Reset : OK ???
TV Picture
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : On
Reset : OK
TV Picture
Cool2
Cool1
Normal
Warm1
Warm2
Activating Backlight
You can adjust the screen brightness by adjusting the LCD backlight brightness. (0~10)
2. Press the ??² or ??¼ button to select "Backlight", then press the ENTER button.
3. Press the ??? or ??? button to decrease or increase the valueof the backlight
brightness.
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balcklight 1 0
??¼More
TV Picture
5
??² Balcklight
??¼
Move Adjust Return
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : Off
Reset : OK
TV Picture
OK
Cancel
Resetting the Picture Settings to the Factory Defaults
1. Press the ??² or ??¼ button to select "Reset", then press the ENTER button.
Press the ??² or ??¼ button to select "Cancel" or "OK" then press the ENTER button.
Each mode can be reset.
Feb 04, 2011 | Televison & Video
Is there a way to access the tint function on the Apex4088? It is not accessable when we go into the picture setup menu. It appears to be locked.
Hello
The Tint function can be accesed by the following steps.
The PICTURE menu offers options to enhance and refine the picture displayed on your TV based on ambient room light and personal preferences. Adjustment options include contrast, brightness, color, sharpness and color temperature
Press the MENU button on the remote control. Navigate using t u arrow buttons to select PICTURE. Press the down q arrow button to highlight PICTURE MODE, then press the u arrow button to select your viewing preference from 4 factory options:
STANDARD > DYNAMIC > MOVIE > PERSONAL. The STANDARD setting is recommended for most viewing environments. Depending on the ambient light level in the room, you may find one of the other options more pleasing.
To make more critical adjustments based on your own preferences in PERSONAL:
• Use down q arrow button to highlight Contrast. Navigate using the
t u arrow buttons to increase or decrease contrast intensity.
• Use down q arrow button to highlight Brightness. Navigate using the t u arrow buttons to increase or decrease overall brightness.
• Use down q arrow button to highlight Color. Navigate using the
t u arrow buttons to increase or decrease color intensity.
• Use down q arrow button to highlight Tint. Navigate using the
t u arrow buttons to adjust colors toward green or reddish tint.
• Use down q arrow button to highlight Sharpness. Navigate using the t u arrow buttons to soften or view crisper edges in the picture.
• Use down q arrow button to highlight Color Temperature. Navigate using the t u arrow buttons to select COOL (more bluish tone), NORMAL or WARM. The default setting is NORMAL. WARM mode will provide color that is calibrated to D6500° Kelvin, the standard color that broadcast stations and the Motion Picture industry consider as the most accurate to view programming.
Note: When adjustments are completed, you may select another menu by pressing the Menu button.
OK
Jan 14, 2011 | Apex Digital LD4088 LCD TV
Yellow tint no color red.
you can adjust in color mode. please balance the tint, color,brightness, contrast, & sharpness.
Aug 30, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I need to know the picture settingd 60" magnavox.
Tries these settings the contrast full to the max setting.Set the backlight to the full max too.The rest sets it to the middle or to ur disire.
Because the contrast and backlight the most important in settings in colors adjusting.
Aug 30, 2009 | Philips Magnavox 51MP392H Rear Projection...
Yellow tint in photoshop
Try adjusting the brightness on the monitor
Feb 27, 2009 | Adobe Photoshop® CS3 Extended Full Version...
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
OR....
2POINT IRE
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
Sep 15, 2008 | LG 42LG50 42 in. LCD HDTV
Hi, I have just purchased the Samsung LE37A559 tv. I have been trying to get the best colour settings brightness colour contrast tint backlight etc. Is there a optimum setting for all of these ? I am...
The problem is that everyone has a different "taste" when it comes to these settings. I like to turn the color all the way down to start with. You should (if the set is factory adjusted correctly) have a black and white picture. If it's not B&W, then there's something inside the set that needs adjusted and you should get a service call. Then I adjust brightness and contrast to get the best B&W picture. Then I turn the color up until I'm happy with the color level, then I adust tint.
Hope that helps
Geno
Jul 29, 2008 | Samsung Televison & Video
Green tint I can't seem to fix
Hopefully someone on here has a manual and can tell you exactly where the tint controls are. Also need to try adjusting the color level, turn it clear down so you have a black and white picture.
Is the picture still green over the screen with the color control
set clear down to black and white? If it does, you might
have an issue with the green gun going out or problem in the
circuitry to it.
By the way, the best way to adjust the picture settings on a
tv are to first turn the color control clear down, then adjust
brightness and contrast for best black and white picture, then
bring up the color level to where it should be and adjust the
tint for best red/green ratio.
May 20, 2008 | Mitsubishi CS-27205 TV
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
