Question about Goodman GMS90703BXA Heater
Goodman furnise 3 flashes on new board no 24vac at preasure switch why
    Genius:
  • Goodman Master
  • 1,033 Answers
Is the inducer motor running?
Posted on Jan 15, 2013
4 Suggested Answers
gear001
  • 59 Answers
SOURCE: I have a Goodman GMP075-3. Worked OK on A/C.
I come across this one a lot. You need to switch the wires at power cord.
  1. Pull power out
  2. follow the cord* back to the furnace
  3. Open the front door
  4. There should be a small metal box where the cord leads to inside the furnace
  5. Open that up
  6. Take the electrical tape off
  7. Pay attention to which wire goes where
  8. Switch the two wires around
If you still got problems ill walk you through it over the phone www.fastacservice.com
Posted on Oct 12, 2009
  • 9 Answers
SOURCE: Goodman GMPN060-3 Furnace will not stay lit.has
possible faulty gas valve if all fail safes stay closed. make sure flue is clear for pressure switch to stay closed.
Posted on Dec 16, 2009
heatman101
  • 43501 Answers
SOURCE: my goodman GMS90703BXA gave an error message (3
Here is a tip that will help you try to figure out why your furnace is notworking.
Basic Furnace or Heating System Troubleshooting
heatman101
Posted on Jan 06, 2011
My goodman GMVC95 furnace circuit board is flashing On 6 I replaced the flame sensor but it's still flashing. Does it have to be manually reset?
Alright, have you checked the low voltage fuse on the circuit board in the blower compartment? Make sure you check the roll out switches as well. If all of these issue appear to be fine then you may have a bad circuit board. There has been a bad batch of circuit boards going around many of the popular furnace brands this winter. Trane Gas Furnaces and Goodman Gas Furnaces have been effected. We sell both brands and have had to replace many circuit boards on new furnaces. Trane Gas Furnaces Installed Goodman Gas Furnace Installation Gaithersburg
Feb 03, 2018 | Goodman Heating & Cooling
Goodman GSC130421ab has no voltage to contact after washing coils....it worked just before powering off unit at diconnect to clean the condenser coils
very posisble.check the fuse on the board on the indor unit. replace with equal size fuse (not bigger probably 3 amp). if the indoor unit comes on then the fuse is fine and i would suspect the coil on the contactor has shorted
Oct 02, 2012 | Goodman CKL36AR36 Air Conditioner
I have a Goodman heat pump and the condenser fan and compressor will not switch on. The board green light says improperly grounded or flame sensor not sensing flame (both are incorrect). The AUX heat (gas)...
Does the indoor fan run? Place the fan switch in run. If it doesn't run then the transformer could be bad. Also, there could possibly be some high and low pressure switches that would keep you from getting the 24vac to the contactor. First rule out the thermostat by removing the face and installing a jumper wire between the R and Y terminals. This should make the outside unit run. If it does then your thermostat is not passing 24vac to the unit and should be replaced. If it doesn't run with the jumper in, then your problem is in the outside unit. Trace out the yellow wire from the thermostat in the outside unit and check the components that the wire goes through (high and low pressure switches). Let me know what you find so I can offer more help if needed.
Sep 15, 2010 | Goodman Heating & Cooling
  1. Pull power out
  5. Open that up
Oct 12, 2009 | Goodman Heating & Cooling
Goodman forced air gas furnace not firing
if your power vent moter is not running you should not have have glowing ignitor.Frist the vent moter must close an air prove switch in series with the idnitor .seems you have a stuck air prove switch.Its the one with a hose attached
Apr 04, 2009 | Heating & Cooling
Goodman a/c blower fan will not shut off
Unhook the thermostat wires on the furnace. If the blower shuts off then your problem is either the thermostat or the thermostat wires. If it contiues to run check you high limit switches next. If all else fails you most likely have a bad blower relay. On most modern furnaces the blower relay is part of the circuit board.
Good luck
Mar 29, 2009 | Goodman CLQ36AR49 Air Conditioner
Gmp075-3 Indicator still flashing 1 after circuit board replaced
Replace the gas valve. If you getting 24vac at the gas valve and it fails to open. Firist check all wiring connectors.
Feb 01, 2009 | Heating & Cooling
Goodman GMS90703BXA Heater Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
