Question about Microsoft Xbox 360 Console
Open tray error on benq drive for xbox 360
It wont spin disc up and after while says open tray?? Can you please help as far as what to do to repair it. Thanks
  • 16 Answers
Your xbox will not read a game and says open tray with some grinding noise? I got your fix right here! I had this same problem and with a few hours of googling and watching a few videos on youtube i was able to fix my console. the open tray error started happening all the sudden and gradually got worse over the course of a week. I read a comment on one of the videos and decided to try it. it is a simple laser adjustment and anyone who can use a screwdriver can do it. it works for me and many others that tried this with success. do this only if your console is out of warranty!
all you need is a set of jewelers screwdrivers. Phillips screwdriver, knife for slicing through the warranty tape and a 10 torqs bit for removing screws once the xbox is open.
1. open the xbox (search youtube for videos showing how to open it up)
2. lift out the DVD drive and flip over
3. remove the 4 screws holding the top and bottom plate on
4. make sure the dvd drive is right side up and look directly behind the lens. you will see 2 gold/yellow screws. these screws dont look like screws so be aware of this. there is a slot cut in these screws for turning them using a flat head screwdriver. once you have located these move to step 5.
5. once you have located the 2 screws that are side by side, turn the LEFT screw from the 12 o'clock position to the 11 o'clock. you only need to adjust the left screw slightly counter clockwise to the 11 o'clock position. this aligns the laser. if you do it too much you might mess things up.
6. set the drive back in the console and replace only the top cover with the black circle on the dvd drive. you need to put this back on to test it and so the disc doesn't fly off. hook up the console to the tv and power it up. insert a game. viola! the game will now work and no more open tray errors. if there is still an error try adjusting that screw to the 10 o'clock position and try again.
7. use electronics canned air to clean out the console before reassembly.
8. reassemble the console and game your arse off!
enjoy!
Posted on Jul 07, 2009
  • 1 more comment
  • darkwolf361 Dec 30, 2010
    I turned it to the 11 O'clock position and now it works perfectly!
  • nmtwilliams Jan 19, 2011
    I did the same and mine is perfect, u da man!!!!!!
  • wezzal02 Mar 10, 2012
    You are the man it fixed mine
    Novelist:
  • 174 Answers
This can be a laser fault, it may need stripping down and the laser cleaning with a cotton bud and a bit of spit. Alcohol leaves a very thin layer on the laser sometimes so i never use that anymore. The laser also could need re-aligning or the power turning up. you can do this by slightly adjusting the left hand 'pot' to no less than 282. we can fix this type of error if you get stuck and we offer £5 discount for all fixya members www.fixmyconsole.co.uk
Posted on Jan 26, 2009
When I put my xbox360 games in, my console says Open Tray, then it wont read the games. It will say Reading for a second, but then it says open tray
Your drive has gone bad. Either the laser or the drive motor that moves the laser had burned out. You can either send it to Microsoft who will charge $100 to fix it or contact someone local who can either repair the drive or replace it. If you replace it you must buy the same drive type (lite-on, benq, samsung, or hitachi) and have the firmware from the old drive flashed to the new drive. Also if you happen to have a modded xbox 360 with old firmware the new ap2.5 checks also cause you and open tray error and a flag for ban.
Mar 07, 2011 | Microsoft Xbox 360 Console
Tray won't close
Use the following steps to close the disc tray on an original Xbox 360 console.
Step 1: Remove the disc from the tray Step 2: Make sure the faceplate is on correctly
The faceplate is the plastic piece on the front of your console.
  • Press firmly around the edges of your faceplate to snap it into place (make sure it is flush with the rest of the console). If the faceplate is not on correctly, the disc tray won't close.
  • If you find that the faceplate is the problem, please contact Xbox Support to order a replacement faceplate.
If this does not resolve your issue, please try step 3. Step 3: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray successfully closes, open the tray and insert a disc. Now try opening and closing the tray with a disc in the tray.
Note Make sure that the disc isn't sticky and doesn't have any labels that could prevent the tray from closing.
If your disc drive still will not close, please try step 4. Step 4: Move the disc drive tray
  1. Gently move the tray up and down, and then from side to side.
  2. Press the eject button on your Xbox 360 console.If your disc drive still will not close, you need to have your console repaired.
  3. Step 5: Request a repair If the disc tray still won't close properly, your Xbox 360 console needs to be repaired.
Xbox 360 S consoleUse the following steps to close the disc tray on an Xbox 360 S console. Step 1: Remove disc from the trayIf there is a disc in the disc tray, remove the disc. Step 2: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray closes successfully, open the tray and insert a disc. Now, try opening and closing the tray with a disc in the tray.
If the disc tray still will not close, please try step 3. Step 3: Move the disc drive tray
  2. Press the eject button on your Xbox S 360 console.
If the disc tray still will not close, you need to have your console repaired. Step 4: Request a repairIf the disc tray will not close, you need to have your console repaired.
Dec 16, 2010 | Microsoft Xbox 360 Console
How do i fix the disk drive on an xbox 360
http://www.pakgamers.com/forums/xbox-hardware-faq-guides/6157-how-fix-open-tray-error-another-solution.html
ezinearticles.com/?How-to-Fix-Xbox-360...Red...Error&id... -
forums.xbox-scene.com/index.php?showtopic=484726&st... -
OK use those links above i am sure you will find help there.
Mar 25, 2010 | Microsoft Xbox 360 Console
XBOX 360 Elite won't play disc; says "reading" then "open tray".
If the console has never been opened to change the dvd drive then eather your laser lens or one of the 2 motors in the drive needs to be changed. 90% of the time its the laser lens. You cant just use any laser for the xbox 360. There are 3 different drives. Toshiba, BenQ, Samsung, so you have to see what drive model you have before you try to order one yourself. I repair these often with 99% success.
Jan 24, 2010 | Microsoft Xbox 360 Elite Console - Black
Xbox 360 wont load any disc and have tried 7 steps of repair on your websitse and it still wont work
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this mayhappen:
1.Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser.The laser is the part that actually reads the disc. The reality is...with all the hours and hours of game play, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
http://store.richspsxparts.com/xb360ac.html
3.Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything,including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock.The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
XBox 360 parts: http://store.richspsxparts.com/xb360ac.html
DVD Drive Swap Info: http://store.richspsxparts.com/imnooninxb36.html
Jan 15, 2010 | Microsoft Xbox 360 Console
Benq drive on xbox 360 has open tray error
Yes first check the hub motor if it's stiff you will
need a new drive . This is kinda rare . 80% of
the time it's the laser . Go to Rich PSX buy
a laser for a benq drive ,thay cost 20.00 or so
when you get the laser remove the anti static solder
dot with a soldering iron and find a tutorial on how
to install , It's not that hard.
If you need more info ask
Rob
Dec 29, 2009 | Microsoft Xbox 360 Console
Open tray error
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
1. Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser. The laser is the part that actually reads the disc. The reality is... with all the hours and hours of gameplay, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
3. Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything, including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock. The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
Nov 11, 2009 | Microsoft Xbox 360 Console
Xbox 360 open tray error
sounds like the whole assembly is off track or ruined. here is a great site that you can use to order the complete assembly and replace this malfunctioning one. Click here.
Mar 11, 2009 | Microsoft Xbox 360 Halo 3 Special Edition...
My xbox 360 disc tray driver wont open
This is a common fault on SAMSUNG dvd drives in the xbox and xbox 360. you need to strip down the machine and replace the belt which is connected to a motor and the drive wheels. this happens when the belt has worn to a point its stretched too far and slips when the drive is trying to open.
Jan 31, 2009 | Microsoft Xbox 360 Console
Open tray error
Your problem is that your Xbox 360 cd drive, the ray inside it is scratched, get a cd drive cleaner and it will be fixed.
May 27, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
8,579 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Mike Neath
Mike Neath
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
