Question about Lowrance Eagle Hs Ws Skimmer Transducer Transom Mount
Where do all wiring go on Lowrance HDS SONAR PORT
    Genius:
  • 1,669 Answers
I have sent you the complete guide:
primus.lowrance.com/icr/units/HDS%20Installation%20Guide.pdf
Posted on Jan 13, 2013
3 Suggested Answers
fishdoctorfi
  • 178 Answers
SOURCE: Can I use my existing transducer(1000 watt tilted
As long as the connection is the same.....maybe. The difference will be the angle of beam from boat to bottom. May not cover the same area...or you could loose zoom etc. something will be different.
Posted on Dec 27, 2009
Editor925
  • 285 Answers
SOURCE: How does my Lowrance HDS-5
To connect a LRA 2400 to a Lowrance HDS-5 sounder/chartplotter, you can run an ethernet RJ45 cable from your Radar Processing box to the HDS-5 unit. You will need an adaptor cable for the RJ 45 cable to hook into the HDS-5 head unit. This is part no 000-0127-56.
As for the different transducer pinouts, I am not sure what transducer you have now so I cannot say if there is any kind of converter plug available, however, the HDS-5 units do seem to run best using the transducers that are made for them. Your best option may be to buy the transducer that is made for them, and this will directly connect to the display unit.
Hope that helps!
Posted on Mar 11, 2011
I need a map chip & onwers manual for a Lowrance HDS 5 like insight. Serial no. 102574610. Where can I get them?
here is the manual
HDS-5, HDS-7, HDS-5m & HDS-7m - Lowrance
https://www.lowrance.com/.../Lowrance.../HDS-5-7-5M-7M_OM_EN_988-10041-00...Sonar references do not apply to the HDS-5m and HDS-7m GPS only units. Manual Conventions. When you are instructed to press a button in this manual, the ..
Software Upgrades here
Lowrance HDS 5 Software Google Search
and finally Mapping
mapping for Lowrance HDS 5 Google Search
and specifically, INSIGHT
Insight Genesis - Download free Lake, River and Coastal Maps
https://gofreemarine.com/insight-genesis/Make your own maps and download free maps from the community. Insight Genesis' cloud-based software does all the work, automatically processing ... with sonar signals from your existing Lowrance, Simrad or B&G transducer. ... The cloud automatically backs up all your data, protecting against lost or damaged SD cards.
Jun 26, 2017 | Lowrance Boating
Wire a lowrance elite 5
Lowrance has started using the same power cord on their Elite units and their HDS units. The yellow wire on the power cable is an accessory wake up wire designed to be used in conjunction with the structure scan modules for the HDS.
You can simply tape this wire off during your installation ND ignore it.
Feb 21, 2015 | Lowrance Boating
How do I turn on fish alarm on hds5x lowrance fish finder
If you turn on the "fish I.D. mode" in your sonar options then you will be able to turn on the fish alarm as well. Lowrance HDS 5x Gen2 Fishfinder
This a link to a pic file for your owners manual.
Go to page 67 to, see how to access and enable/disable alarms for your unit.
Nov 30, 2014 | Lowrance HDS5x Fishfinders
How do i find water depth
Water depth should show automatically on your sonar page.
if it does not then either you have selected "stop sonar" under your sonar options or you have opted to turn off the depth displayou so the numbers don't show up.
if you areally viewing your GPS or split screen sonar/GPS page, sometimes the depth display is not visible on these pages unless you specifically instruct the unit to display it.
Lowrance HDS 5 Gen2 Fishfinder GPS Chartplotter
Here is a link to Lowrance where you can download a pic version of the operators manual.
Go to page 11 "overlay data" this will give you a step by step of how to add data or readouts to different screens.
Aug 27, 2014 | Lowrance HDS 5 Fishfinder GPS Chart...
Can not get my HDS-5x and structure scan to interface
ooooooooook click menu button twice go to functions scroll down to structure scan see if the circle beside it is high lighted if not click on it to turn it on do this to both units
Mar 25, 2013 | Lowrance LSS1 StructureScan Sonar (Lss1...
Lowrance HDS 5 Sonar faulty
You realise we are FIXYA, we are not Lowrance?
Is this when you are moving, or when you are stationary? If it is stationary, then the transducer or the wiring to it, or the plug into the head is faulty.
If it is only when you are moving, the transducer is not sitting at the correct angle and you are getting a disrupted water flow over it.
The other possibility is that you have the sensitivity set too high, which shows more activity on the screen. Set the head back to Defaults.
Feb 11, 2018 | Lowrance Hds-5 GPS Receiver
Got a HDS 5 and im getting bad or false on my sonar when traveling showing fish and structure.When trying to hold ground and im backing up it doesn't even read?i have it on auto sensitivity
Check the mounting and cable connection of the transducer on the stern. If loose will tilt during movement, in reverse wakes from the prop. CAREFULLY check unit during these conditions. The transducer needs to be completely submerged. Good Luck.
Jan 13, 2012 | Lowrance HDS 5 X Sonar ()
Somehow I have split the screen into two pictures of the same sonar reading. How do I get it back to only being shown on the one screen instead of being split into two.
Hi, press pages, then use the arrow up key to select sonar only page(it will show in upper left of screen the page you have selected.) Then press enter. Hope this helps, regards Phil.
Jul 20, 2011 | Lowrance HDS 5x Fishfinders HDS 5x...
I own a lowrance hds 7 and it doesn't power on. Have any ideas what to do? Where to send for repair?
Test your Lowrance HDS 7 on different power sources e.g. on another motorboat to find out whether this is the problem of the boat's power supply or the HDS 7 itself - this advice will only help you to determine whether to call the boat-repairman or the lowrance hds 7 seller warranty service.
Jan 08, 2011 | Lowrance HDS-8 GPS Receiver
Lowrance Eagle Hs Ws Skimmer Transducer Transom Mount Logo
114 people viewed this question
Top Lowrance Boating Experts
dduncan54
dduncan54
Level 1 Expert
Phil Walker
Phil Walker
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
