Question about Hartke A35 35-Watt A Series Combo Bass Amplifier
I have a hartke a35 bass amp and i wanna use it with a headphone. could you advice one or two spesific headphone models for me?
I am using my amp with overdrive effect.
3 Suggested Answers
  • 5603 Answers
SOURCE: Hartke Ha2500 250watt Bass Amplifier Head sound
This sounds like the thermal protection is activating. Make sure the vents and heatsinks have FREE AIRFLOW. If the sound cycles on and off, it could be a failure of the heater in the one vacuum tube in the unit. The heater could cooll and reconnect and then heat and disconnect.
Posted on Nov 03, 2010
  • 5603 Answers
SOURCE: looking to buy used bass
Connecting the CD player should NOT have caused any damage if they were power from the same receptacle and both had grounded plugs OR a walkman type was used which had no external power to it. Power transformers RARELY fail. Check if it has a fuse that has blown BUT do not replace the fuse until the cause of it blowing is found. Switches on a lot of these are POOR and they do fail.
Posted on Mar 12, 2011
Hartke vx115 lost significant volume
If you've tried different heads with the same result, the most likely problem is a blown speaker. Check it with an ohm meter, and if it's blown, you can either replace it or get it re-coned.
Apr 24, 2015 | Hartke VX115 - 1 x 15 Bass Guitar Cabinet...
Where can i find a hartke a70 schematic?
The schematic is here. http://music-electronics-forum.com/attachments/6771d1256866984-a70_sch.pdf
Jan 11, 2015 | Hartke A70 70 Watt Bass Amplifier Combo...
The amp cut off and is not coming back on
Sounds like you burned out the sub channel usually due to having a sub the draws more watts than the system can push, effectively blowing a capacitor or node within the internal motherboard of the AMP.
Oct 09, 2013 | Hartke Refurbished B Series B150 15 Watt...
Trying to find the right fuse for a eden World Tour 800 bass amp
Well, hope this helps you.
Fuse Requirements:
USA @ 120 Volts /60 HZ - 10 Amps, 5 x 20 mm GMC/T/slow blow
Europe @ 240 Volts/50 Hz - 5 Amps, 5 x 20 mm GMC/T/slow blow
Japan @ 100 Volts/60 Hz - 12 Amps, 5 x 20 mm GMC/T/slow blow
Mar 10, 2013 | Hartke HyDrive HX410 4x10 Bass Cabinet...
I have a new ( 2 weeks old) Hartke 5210C combo bass amp. I plugged it in and turned it on, and after about three seconds, I heard a louder click than usual. I plugged my bass in and hit about three notes,...
There is an internal problem with the amplifier circuit. Since the unit is only 2 weeks old, it is clearly under a warranty. Return the unit and request a replacement. Given the short time, the store should not give you a hard time with your request. DO NOT under any circumstances open up the unit as that will void the warranty.
If the store is reluctant to exchange the unit, speak with a manager. Should that fail, contact Hartke directly.
Dan
Aug 24, 2011 | Hartke Audio Players & Recorders
My Hartke A100 has a problem, no power, the problem is transformer. what is the exact volt of transformer A100 hartke? than you
Transformers don't often fail. I have heard that some of these have a thermal fuse in them and they sometimes open. If you can get to the fuse in the windings, you can replace it and save the transformer. The fuses look like a silver tube about 5/8 inch long and 3/16 inch diameter with a lead out each end, They are marked with the temp they open and are a one-shot thing that have to be replaced.
May 30, 2011 | Hartke A100 Combo Bass Amp
This problem has to do with a Hartke 3500 bass amp. I recently purchased a replacement UCISC (the part with the female plug and fuse box) and replaced it. I tried to be very careful putting all of the...
Easiest way to check is to measure the resistance between the ground pin of your cord and the chasis of the unit. It should be very low. That is the only critical one... Look at a receptacle. See one bllade is wide? That is the neutral. The other one is the HOT side. The HOT SIDE should go to either the fuse or the switch first in your unit. If you have those right the third wire will be right.
When powering up an amp there often is a noise until the amplifiers balance out. Very high quality and high power amps have a relay that disconnects the speaker until balance is reached... but the smaller amps do noot have this feature.
May 02, 2011 | Hartke Bass Amplifier Half Stack with...
Amplifier head is working but no sound from speakers. Head tested with external speakers and is OK.
A simple test is to connect internal speakers across an AA battery (for about half a second) & listen for a click as battery is connected & another as battery is disconnected.
If this does not happen, check the internal jack plug connection & its connection to the speakers.
If OK, then you can test each speaker individually using the same battery across each in turn.
If this advice is helpful, I would appreciate a rating.
Apr 10, 2011 | Hartke VX3500 Bass Guitar Combo Amplifier
My amp has output but no sound from the speaker.
If you have tested with other speakers, you may have blown the ones that are not working. Test the speaker(s) on another source. I am not sure how you have tested your amp that it "has output"... indicators mean NOTHING on the amps as far as actual power going out.
Jan 29, 2011 | Hartke Ha2500 250watt Bass Amplifier Head
Amps in a seires
I'm not sure what this will do, but electrically you can hook these up. Using the line output from the swx, connect it to the line level input. I think that that would be the active input. When you connect a guitar(without a battery powered pickup) to the hartke, it goes to the passive input right? If so, then connect the line out of the swx to the active input. Reverse if the behavior is opposite of what I described.
Realise that with these two connected to each other, you will be using both pre-amp sections and the amp section of the hartke.
Dan
Mar 01, 2010 | Music
Hartke A35 35-Watt A Series Combo Bass Amplifier Logo
21 people viewed this question
Top Hartke Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Hartke Audio Player and Recorder Expert? Answer questions, earn points and help others
