Question about Baumatic Refrigerators
Lemair wine fridge SWC200K . On the display is blinking error message E2 fridge is still working ok.
SOURCE: Chigo Wine Fridge Error
I have a Chigo that displays error code E2.1 alternating at times with E8. The unit runs intermittently. My dealer and I agree the control circuit board is faulty and should be changed at a cost of $125. It is likely due to a failure of the control circuit board, but more specifically the circuitry on the control board related to the upper temperature sensor. The connectors for the sensors and the connector between the compressor and the control and relay boards are also flakey, and this could be the cause, but I could not isolate a bad connection, so will change the control board and hope that fixes the problem.
Posted on Mar 05, 2010
SOURCE: HOTPOINT MISTRAL plus 8596 fridge E2 code
Go to this site: http://www.ukwhitegoods.co.uk/modules.php?name=Forums&file=viewforum&f=35
Type "Mistral Thermistor" into the search and help will be availible. You have a very common problem which is an easy fix in most cases. Good luck.
Posted on Jul 21, 2010
  • 4 Answers
SOURCE: Hi Our Lemair wine cooler
it may be too close to the wall, too much dust on the back, or both. if the freon is out,dont bother trying to get it fixed,its probably cheaper in the long runto just get a new one
Posted on Dec 19, 2010
SOURCE: Hello, I have BW40 wine
There are 2 sensors in this wine cooler. Malfunction of each leads to E1 or E2 fault codes. One is easily accessible inside the fridge (small white torpedo sensor with pair of wires attached). The second but identical sensor is buried within the foam on the rear of the cooler. Unplug from mains, take of the electrics from back of cooler, take off sheet metal back and the sensor will be deep in the foam and can be replaced easily after digging out some foam. When replaced make sure the sensor is in the same place it stops the cooler icing up. Use gap-fill foam to keep insulation good. Dr_Nicholas
Posted on Mar 06, 2011
ginko
  • 19396 Answers
SOURCE: lemair wine fridge not holding
Hi.
If the unit looks like it is working regularly, but it does not keep the regular 14C temperature, then the problem is either defrost system or need for gas recharge.
Disconnect power and perform a full defrost leaving the unit off overnight. If the problem disappear, then the fault was the defrost system in the unit. If the problem comes back in a couple of days, then the defrost thermostat must be replaced.
If the problem comes back immediately after defrost, then you need a gas recharge. When problem is the compressor you hear clicking and humming, or motor does not start at all.
If you need recharge, parts or repair contact Lemair. Here their website. Contact page link is at the top.
Regards.
Ginko
Posted on May 17, 2011
Kelvinator beverage cooler E2 error code
Temperature sensor error code.
Login'Contact Us Appliance Appliance Repair Questions? Ask a Technician for Answers ASAP
Ask an Expert Home Improvement Questions Appliance Technician
How JustAnswer Works:
  • Ask an Expert
  • Get a Professional Answer
  • 100% Satisfaction Guarantee
Ask Daniel Your Own Question
Daniel, Home Appliance Technician
Category: Appliance
Satisfied Customers: 16124
Experience: 20+ yrs. experience in white goods repair. NVQ Level 2 electronics manufacturers training courses. Type Your Appliance Question Here... Daniel is online now Hi, I have a BWE40 Wine Cooler and an E2 Error Message.
Resolved Question:
Hi, I have a BWE40 Wine Cooler and an E2 Error Message. What does this mean please?
Submitted: 3 years ago.
Category: Appliance Share this conversation
Expert: Daniel replied 3 years ago.
Hi
E2 error code is a temperature sensor error code.
Remove the plastic black cover on the back and you will see the control board.
On the board you will see a wiring block with 4 thin wires going to it.
Test the 2 wires on the left and the 2 wires on the right with a multi meter. The reading in Kohms (kiloohms) should be the same.
If any are faulty then they will need to be replaced.
If the readings are the same, replace a faulty control board to be rid of the E2 error and your problem.
Feb 12, 2014 | Marvel 61AR Compact Refrigerator
Avanti error code e2 wine chiller, what is the problem?
Display flashes Error message "E2" - Defrost sensor (Coil Sensor) failure.
Contact the Avanti Service Department - 1-800-220-5570
Hope helps.
Jun 03, 2011 | Avanti WC42 Wine Cooler
Lemair wine fridge not holding temp.sounds to be going ok but not cooling.temp keeps rising????.will not hold temp you press on digital readout.thks in advance
Hi.
Regards.
Ginko
May 17, 2011 | Refrigerators
Hi Our Lemair wine cooler doesn't stay on the required temp. Sounds like everything is working ok
Dec 19, 2010 | Refrigerators
Hello, I have BW40 wine cooler. On the display is blinking error message "E2". I have tried to switch off and switch on, but it doesn't helped. Thanks for you support in advance. br, Zoltan
Sep 28, 2010 | Baumatic BWE40 Wine Cooler
MC wine cooler MCWC44DZ error code e3
I had an E3 on the upper zone. This fix was simple. Unscrew the 2 screws for the middle tray. Pull tray out as far as you can. Check the wires in the back, those are the wires for the fans in the back. The connectors over time corrode, and break off... All I did was connected the 2 wires that had broken off of their connector directly to eachother. E3 went away and the cooler is working as it should now.in
Jan 04, 2009 | Refrigerators
Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
Jan 20, 2008 | Haier BC112G Wine Cooler
Code E2 showing in temparature display
I contacted the technical team at www.baumatic.co.uk and here is the reply I got.
-----Original Message-----
From: Samantha.Codd@baumatic.co.uk [mailto:Samantha.Codd@baumatic.co.uk] On Behalf Of Technical@baumatic.co.uk
Sent: 25 January 2008 13:02
To: Taline Bedrossian
Subject: Re: BWE40 wine cooler
Good Morning.
Thank you for your e-mail.
This error code means that your appliance has experienced a defrost sensor
fault. Please contact our service team on 01189 336 911 to arrange a
suitable time for an Engineer to visit you.
Kind Regards
Quality and Technical Department
Baumatic Ltd
www.baumatic.co.uk
Jan 19, 2008 | Baumatic BWE40 Wine Cooler
Refrigerators Logo
148 people viewed this question
Top Baumatic Refrigerators Experts
Sal DeAngelo
Colin Stickland
Colin Stickland
Electric Dime
Electric Dime
Are you a Baumatic Refrigerator Expert? Answer questions, earn points and help others
