Question about Bosch HBL 455 Stainless Steel Electric Double Oven
Self cleaning lock stuck in locked position on my bosch hbl455auc
  • w johnson Jan 13, 2013
    Just changed the upper door right hinge and door now closes although the right side is 1/8 inch lower than left. Next I cleaned the oven in the clean cycle but the light showing the door is locked turned off mid cycle and after it completed the oven lights remained on and the door is locked in the closed position with the two oven lights turned on after 4 hours it is cool and still locked. How can I open the door?
Try unplugging it and letting it sit for a few minutes and then plug it back in. That worked when I Maytag did the exact same thing.
Posted on Jan 13, 2013
Used self cleaning process on my oven yesterday and today the oven will not turn on, we keep getting message to unlock the oven door even though it is. What can we do?
The oven gets extremely hot during the self-cleaning mode... the door switch might have got stuck in locked position, or broken in locked position (to be replaced), let's hope it's just stuck...which you'll need to work the mechanical lock-unlock latching back and forth to hopefully unstick....and if that doesn't work just re-run self-cleaning process but this time let the oven cool completely before unlocking the door. Hope this helps.
May 11, 2014 | GE Ovens
Self cleaning
Set back on self clean, then after about a minute, switch off. The lock should disengage.
Apr 25, 2013 | Bosch HBN 442 / HBN446 Electric Single...
After changing the right door hinge on my bosch hbl455auc the door closes but the upper oven door is 1/8 lower at right top than left. How can I realign the door to level?
There are adjustment screws or bolts on the hinge attachments to the oven. Loosen them and adjust the door using wedges to hold the door in place.
Jan 12, 2013 | Bosch HBL 455 Stainless Steel Electric...
I have a whirlpool Super Capacity 465 self cleaning oven with accubake. About a month ago after using the oven to bake dinner the keypad button(s) became stuck (i figured this out after researching the...
Hello Michelle!
Crazy to hear, but this is actually a touchpad failure.
Luckily, we at FixYourboard.com have a solution.
Read more about the cause and fix in our blog! F5 E1 Error Code Whirlpool Built In Double Wall Oven
Feel free to contact us if you have any questions. info@fixyourboard.com
Mar 20, 2017 | Whirlpool 30" Self-Cleaning Freestanding...
Door lock light blinking ,oven wont work on a older gibson self cleaning oven.
It sounds to me that the door lock switch itself is stuck in the "on" position. If you don't use the self-cleaning feature, I would suggest simply disconnecting the switch. If you DO use the self-cleaning feature, you may want to consider replacing the switch or inspect it to make sure there isn't debris, grease, etc., stuck in it, making it stuck on all the time.
I hope this helps! :) Please let me know if you need any further assistance in this matter and I'll be more than happy to help!
Feb 21, 2010 | Ovens
Bosch Double oven - top oven will not open - seems like it is locked
i am not aware of a bosch oven that locks the top door usually only main oven will lock if self clean pyro oven,the small oven never has this feature sounds more like a hinge problem check nothing is fouling the lower part of the oven door.
Dec 30, 2009 | Bosch HBL 755 Stainless Steel Electric...
Door locked after cancelling self clean option
Open the door. In the upper left corner, press and hold the door switch (the one that controls the inside light). Start a self clean cycle and wait for lock motor to engage. When the lock stops moving it should be in the unlocked position. Press cancel to stop the self clean.
If you need more assistance let me know.
Mar 29, 2009 | Ovens
Jenn Aire lock for self clean in locked position
The LOCK INDICATOR light must be OFF. This can take up to one hour!!!
Do NOT force the door.
Leave the SELECTION and TEMPERATURE knob alone. The Temperature knob MUST be set to CLEAN
Indicator Light OFF, knobs set to CLEAN - OPEN the slide lever.
Lever open, set the knobs to OFF and away you go
Oct 26, 2008 | Jenn-Air Ovens
Locked latch on the self cleaning oven
try wiggling the door latch to get it open if not try the cleaning process, if that works, and see if the door comes unlatched and the light goes off. if not the lock light switch is stuck and it will need to be taken apart and cleaned
Oct 13, 2008 | GE JKP15 Electric Single Oven
Oven Door Locked
is it locked in the up or down position?
May 08, 2007 | Hotpoint SY21 Style Line Gas Single Oven
Bosch HBL 455 Stainless Steel Electric Double Oven Logo
106 people viewed this question
Top Bosch Ovens Experts
ashburton
paulcarew
Are you a Bosch Oven Expert? Answer questions, earn points and help others
