Question about Sony Cyber-Shot DSC-S40 Digital Camera
Sony Tv KV-36FV16 Big screen jus on horizontal
My Sony KV-36FV16 is working fine jus it has gig screen. I mim, horizontal size is large, the vertical size is fine. I have it 3 months but I can't finde the problem. I tryed on Sevice Ajustment Mode, but some comand does not work. I need helpe. Thanks
  • 2 more comments
  • Josias Aleixo
    Josias Aleixo Jul 07, 2007
    I meam 3 month trying fixing it. Thanks for you answer
  • Josias Aleixo
    Josias Aleixo Jul 12, 2007
    Take loock on cross-hatch picture, it has 13 colun, but supost the picture have 19 colun on picture, and one more pincushion problem. ( I think the picushion problem for the horizontal to larg )
    Loock on color bar, it hide those colors gray on left side and black on right side. The tv don?t has any vertical problem. This is the tv's problem. Apreciat for your patience. I'm sorry for my English, may be you are undestending now. Thank you. Loock the picture
  • Josias Aleixo
    One more picture. I tri send the secund picture but I can't send
  • Josias Aleixo
    I tri send ane other pictire but I can't sent to shou you the cross-hatch. I will tri on nex time. Thank you
    Genius:
  • 2,985 Answers
If it is only three months old then send it back to the seller or Tell Sony Tech support team This is a warranty job.
Posted on Jul 06, 2007
  • john ash
    john ash Jul 07, 2007
    Aleixo-
    Tell us what it is you are trying to fix
    Your description is not very clear.
  • john ash
    john ash Jul 12, 2007
    Pin cushion is a common fault, in digital optics
    due to small size of the CCD capturing the image and the large enlargement when displayed.
    Most Image Editor programs have facilities to correct this.
    Do you 'work' you images in the computer with an image editor?
    Whether the issue us extra to normal in you case I cann not say.
    Refer this question to the Sony Technical Support Team and they will advise furher
SOURCE:
Picture is too large to show on screen
Check its "Pin-cushion" section circuit for the fault. An IC is used there to control the pin cushion distortion. If this IC has got faulty, this type of fault can occur. This is actually a skilled work. If you are not ahndy, seek any technicians' support.
Jun 18, 2012 | Sony KV-36XBR400 36" TV
6 horizontal lines
I would look for a Vertical circuit failure. Most likely is the vertical output IC and or open resistor off the hv transformer. Definitely look for any loose solder connections around the Vertical output IC.
Hope this helps,
Skyassoc
Jun 16, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Image too large for the screen
you need to replace filter capacitor from vertical section area and horizontal section area. i already encounter tha kind of problem and fix replacing vertical section capacitor.
Apr 19, 2009 | Sony KV-13M42 13" TV
Picture and text extend beyond screen
Your tv needs to be put into service mode with the original Sony remote control and then set the vertical\horizontal size parameter to the correct values and then burn the new settings to memory
Google " sony tv service mode " and you should find the procedure. Good Luck! Write back if you have problems.
barneyluc
Oct 06, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-27S10
is it vertical problem or retrace lines can you tell
Aug 06, 2008 | Sony KV-27S10 27" TV
Kv-36xbr800
Hiii...
My version is :
For safety reason you should replaced them ( Horizontal ic,Vertical ic, Deflection ic) and olso all the big capasitor nearest the ic....that's my version....if you have big budget for it....he..he....
Thank's
[Vrya]
Dec 27, 2007 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Picture broken and shrinking
You need to change your vertical IC, along with some capacitors around the vertical IC. Capacitor with value 220UF, 10uf, 470uf and finally 1000uf. Doing this will fix the set. Total cost under $40
Best regards
Circuitcity
Nov 29, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
No Power on Sony TV
Be sure to use an ORIGINAL Sony transistor and be sure to resolder the pins of the small horizontal driver transformer and all parts connected to and around it, and your set should be fine.
Aug 17, 2007 | Sony FD Trinitron WEGA KV-20FS120 20" TV
FUSE SPEC FOR SONY KV-36FV16
The rear panel nameplate will state the unit power requirements. Look for number of amps draw. Let's say you read "2 A". Now, depending on where in the circuit this fuse is, your fuse size will be no more than two amperes (sometimes slightly greater if slow-blow fuse spec'ed). So, if your fuse is located immediately near the line-cord entrance to circuit board, start with a 1.0A fuse. If that immediately blows, then increase to a 1.5A fuse. Repeat until 2 A fuse is reached. If still blowing, then there is a problem with the set, either power supply or tube.
Jul 17, 2007 | Sony KV-36FV16 36" TV
Sony Cyber-Shot DSC-S40 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
 Russ Hill
Russ Hill
Are you a Sony Camera Expert? Answer questions, earn points and help others
