Question about Whirlpool AD50USL Dehumidifier
How much water do I put in water bucket on this thing?
I do not have a manual on this model . I know nothing about them. I need to know how much water to put in water container and what other solutions I can use in it.
    President:
  • 2,976 Answers
You don"t put anything into the bucket. A dehumidifier will fill the bucket for you.
Posted on Jan 18, 2013
I HAVE A ge 40 pint dehumidifier it wont run because it says the container is full and there is nothing in it
i did have one of a simmiliar model do just this same thing it turns out i hit the sensor float inside removable bucket part and knocked it out of its little hole it fits in , hence the it no longer connects with other part of overfill sensor thats buryed inside machine, so it allways says its full , i put the little float back in it's hole and now it works ok
Oct 20, 2014 | GE Dehumidifier With 40 Pint Capacity
Leaking for no apparent reason.
2 things are generally the culprit. The water collection bucket is improperly installed or is cracked or the water tubing that drains into the bucket is clogged.
Check the bucket for proper installation and cracks and if that produces nothing move on to the clogged drain tubing below.
Turn the unit OFF & Unplug it, before preceding any further.
Remove the water collection bucket and look up inside the bucket holder cavity. You will see either a drain hole or small tubing that drains the water into the bucket. Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hole or tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reinstall the bucket, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor it for any leakage.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers
Hope I was able to help you troubleshoot and solve the problem. Please let me know. Thanks.
Jul 20, 2011 | DeLonghi DE650P Dehumidifier
One day, smelled like burning, then we check, no water in bucket, we know it wont work? so what we should do?
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jun 29, 2011 | Whirlpool AD50USS Dehumidifier
My dehumid is model # DH404Ey6. I plug it in and it reads 70% on the front setting. The power on/off button does not work. Or, at least, it doesn't react when I push the button. I put the bucket...
heatman101
Apr 25, 2011 | Goldstar Dehumidifiers
Model 501D(had the wrong model number before) When I turn the unit on where the humidity is set there is a code CO 01. Unable to find my manual. the unit starts then turns off.
I will advice you check the water bucket to see if it is full and empty the bucket in a sink if needed. GE dehumidifiers have a safety feature that shuts down the device when the water in the bucket reaches a certain level.
Install the bucket correctly in the unit by hooking the slots on the bucket on the posts on the back of the device. The dehumidifier will not run if the bucket is not properly setup in the device.
Take care.
Aug 30, 2010 | Comfort-Aire BHD-501 Dehumidifier
Are you supposed to put water in the bucket of the dehumidifier or is the water that is in the bucket now from using the dehumidifier? Dumb question I am sure. But I am renting and have never used one...
The dehumidifier condenses the water on its coils and then it drips into the bucket. Dump out all of the water when the bucket is full. This model has a light that tells you when it is full. If the dehumidifier gets ice on the coils, it needs repair (low refrigerant).
I hope this helps.
Aug 10, 2009 | Kenmore 54701 Dehumidifier
Extra cup in my water bucket??
that is just a float for the water when it fulls to that level it pushes the float up and that shuts the unit off it is the bucket float lever control
Jan 22, 2009 | Haier 45-Pint Dehumidifier
Dehumdifier won't drain
You just need to get the water flowing and start the siphoning process by taking out the water bucket while it's full of water and raising it up high enough to start the water flowing. Once the water starts flowing, you can put the bucket back and the water will keep flowing (by capillary action). If the bucket empties completely, you may have to do it again periodically to get the water flowing again.
Sep 17, 2008 | Kenmore 54701 Dehumidifier
Fdk45p1 dehumidifier
Has anyone figured out how to get a 25-pint Frigidaire dehumidifier (model FDD25S1) to put water out the drain hose for continuous draining instead of into the bucket? It appears to be impossible to connect the hose in a way to avoid water leaking into the bucket.
Jun 06, 2008 | Frigidaire FDL45P1 Dehumidifier
Ghd30y7 goldstar dehumidifier
We came home to this problem the other day, water all over the basement, leaking out the bottom left side, nothing in the collection basin but plenty would spill out if I tipped the unit forward. After searching the web and these forums I theorized that the coils were frozen. I let the unit thaw. No luck. I removed the faceplate and discovered thick, wet silt had filled the internal collection plate and was clogging the drain. I stuck a pipe-cleaner through the drain and the problem was fixed. Took some paper towels and cleaned the whole thing. Works like new. I assume the unit will need to be cleaned regularly to keep it going. To remove the faceplate, unscrew the two phillips' head screws under the faceplate along the sides, then take a flat head screwdriver and pop the tabs holding the face on, one tabe along each side. There are also two tabs on top, but you don't need to mess with those, as they simply act against gravity. Whole thing just clips back together after cleaning. I have no idea if this voids the warranty.
May 21, 2008 | Goldstar DH304 Dehumidifier
Whirlpool AD50USL Dehumidifier Logo
109 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Mike Squire
Mike
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
