Question about Canon Pixma iP4500 InkJet Printer
Printer flashing orange green orange green 8 times
SOURCE: canon i250 flashing orange / green light
turn the printer off by the socket. hold down the on button and keep held down whilst turning on the socket switch. Then press the button next to the on (i don't know what it is called) , so it goes onto orange then again to get to green. now it should stay on green and print. i hope this i useful
Posted on Apr 24, 2009
SOURCE: Canon iP1800 printer,flashing orange light under the green 'on'
Orange light is flashing 7 times and I get msgs that say cartridge not installed properly and cartridge cannot be recognized. I have refilled my cartridges more than once it worked fine for awhile. This is what Canon said.
Subject: Re: Response from Canon - SWSS Web Escalation (KMM10132386V40822L0KM)
> Dear Mike M:
> Thank you for your reply.
> We appreciate your response with the information for your iP1800
> printer.
> The ink cartridges are not designed to be refilled, and this would
> indicate the cause for the issue you are having. each cartridge
> maintain track of the amount of ink used in order to provide status
> information on the level of the ink in the cartridge. Wen refilling an
> ink cartridge, the status information is not updated, and will cause an
> issue such as this.
> The refilled ink cartridges should be replaced with new Canon ink
> cartridges and the printer will resume printing and working properly.
Posted on Aug 30, 2009
envision507
  • 30 Answers
SOURCE: The printer flashes orange light five times, and green once
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
This also applies to the i550, i560, i950, i960
Posted on Sep 07, 2009
pineworks
  • 4041 Answers
SOURCE: five flashes of orange followed by one green flesh
  1. Turn off Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the printer should turn off, if not, press the Power button once more.
  8. Your Canon i550, i560, i850, i860, i865, i9100, i9950 Printers should respond as normal.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
SOURCE: flashing orange light 5 times followed by green
I am also having this problem, would love someone to give us a solution before I through it out the window.....
Posted on May 30, 2010
Reset. Orange light blinks several times. Then Green. Then orange several times, then... on and on. Cannot reset. All ink cartridges have ink.
count the number of orange flashes in between the green light. two flashes = out of paper, 3=paper jam, 4=empty ink tank, 6=print head not installed, 7=print head defective, 8=waste ink tank is almost full
Jun 08, 2010 | Canon i850 InkJet Photo Printer
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    When I switch on my i550, The green light comes on , immediately changes to orange which flashes 8 times, reurns to green, flashes orange again. This process repeats ad nauseambut the thing will not print
    8 times says the ink absorber is almost full and should print if you press the resume button. If it's too full it won't print until the absorber is changed and the counter reset thru the service mode.
    Oct 01, 2009 | Canon BubbleJet i550 InkJet Printer
    My printer flash green then oranfe and again and
    5 times says the feed roller is not turning properly, sometimes the gears break and other times something falls in the back and stops the roller from turning. It's a different error if the orange flashes 5 times, or if it flashes orange and green 5 times.
    Sep 01, 2009 | Canon BubbleJet i560 InkJet Printer
    Canon i560 Ink jet Error Code 5C00
    1. Turn off printer
    8. Your printer should respond as normal.
    May 05, 2008 | Canon BubbleJet i550 InkJet Printer
    Canon BJC 8500 WASTE INK FULL
    How to Reset Waste Ink Protection Counter Canon Pixma IP8500 Printer
    Instructions:
    Resetting Waste Ink Counter Canon Pixma IP6000, Canon MP450, Canon Pixma IP8500
    1. Turn off the printer.
    2. Whilst pressing Resume button also press on POWER.
    3. Then Press RESUME button and release POWER.
    4. Then Press RESUME button again .
    5. Then release all buttons.
    6. Led Indicator should be green and stay green.
    7. Click RESUME button 4 times if you wish to try again.
    Then See Table Below:
    Orange - Service test print ONCE - Orange - Service test print.
    Green - EEPROM information TWICE - Green - EEPROM information print.
    Orange - EEPROM initialization 3 TIMES - Orange - EEPROM initialization.
    Green - Waste ink counter resetting 4 TIMES - Green - Waste ink counter resetting
    Orange - Destination setting (Press Power then Press Resume 3x) 5 times - Orange - Destination setting (Press Power Press Resume 3x)
    Green - Print head deep cleaning 6 TIMES - Green - Print head deep cleaning.
    Orange - Green, Orange - Return to menu selection 11-13 TIMES - Orange, Green, Orange - Return to menu selection.
    Green - Left margin correction 14 TIMES - Green - Left margin correction.
    8. Turn off printer.
    9. Restart Printer.
    Good Luck!
    Tinteiros - Magic Inkjet Flush (Ebay)
    Nov 07, 2007 | Canon BJC 8500 InkJet Printer
    Printer Problem
    This was not the sollution for my pinter..
    My Magneta is half full and my error led is also blinking 15 times
    I found this service manual for the IP4200 but this methode also doen not solve my error led..
    Is their someone who has the sollution for this strange error?
    1) With the printer power turned off, while pressing
    the Resume/Cancel button, press and hold the Power
    button. (DO NOT release the buttons. The Power LED
    lights in green to indicate that a function is
    selectable.)
    2) While holding the Power button, release the
    resume/Cancel button. (DO NOT release the Power
    button.)
    3) While holding the Power button, press the
    Resume/Cancel button 2 times, and then release both
    the Power and Resume/Cancel buttons. (Each time the
    Resume/Cancel button is pressed, the Alarm and
    Power
    LEDs light alternately, Alarm in orange and Power
    in
    green, starting with Alarm LED.)
    4) When the Power LED lights in green, press the
    Resume/Cancel button the specified number of
    time(s)
    setting) (THEN HIT THE POWER BUTTON >AFTER THIS< TO SET).
    Time(s) LED indication Function Remarks
    0 times Green (Power) Power off When the print head is
    not installed, the carriage returns and locks in the
    home position capped.
    1 time Orange (Alarm) Service test print .
    2 times Green (Power) EEPROM information print
    3 times Orange (Alarm) EEPROM initialization
    >>>>>>>>THIS ONE
    4 times Green (Power) Waste ink counter resetting<<<<<<<<<<<<
    5 times Orange (Alarm) Destination settings After
    entering the destination settings mode, press the
    Resume/Cancel button the specified number of time(s)
    to select the destination. For detail, see
    "Destination settings procedures" below.
    6 times Green (Power) Print head deep cleaning
    (Cleaning of both black and color)
    7 times Orange (Alarm) Reserved
    8 times Green (Power) CD / DVD check pattern
    9 times Orange (Alarm) CD / DVD print position
    correction (horizontal: X direction)
    10 times Green (Power) CD / DVD print position
    correction (vertical: Y direction)
    11 to 13 times Orange, Green, Orange(Alarm,
    Power,Alarm) Return to the menu selection
    14 times Green (Power) Left margin correction Not used
    in servicing.
    15 times Orange (Alarm) Return to the menu selection
    Time(s) LED indication Destination CD / DVD print
    0 times Green (Power) No change of the destination
    1 time Orange (Alarm) Japan Supported
    2 times Green (Power) Korea Not supported
    3 times Orange (Alarm) US Not supported
    4 times Green (Power) Europe Supported
    5 times Orange (Alarm) Australia Supported
    Oct 30, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
    Canon Pixma iP4500 InkJet Printer Logo
    37 people viewed this question
    old marine
    old marine
