Question about kawasaki PVS-10921 Portable DVD Player
ALBA TVD3406 SET IS FIXED ON PAL I, I NEED TO USE PAL B/G, CHANGED MERMORY IC CAN NOW CHANGE SOUND SYSTEM BUT SET IS NOT KEEPING MERMORY HAVE TO RETUNE EACH TIME I POWER ON.
Hi i need a the dvd part i have probleams reading dvds and music cd ahhh
Posted on Oct 31, 2008
    Genius:
  • 1,074 Answers
Eprom could be bad or the microchip have a tech check your set.good luck
Posted on Jul 22, 2007
Hello, my Alba TV randomly changes channel and it makes a *pop* noise whilst it's doing it. Any ideas?
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Jan 12, 2017 | Alba Televison & Video
Change ntsc to pal
The manual seems to indicate that the TV will automatically detect what signal type is present, so PAL should be recognized. There is, however the possibility that the "Color System" setting under the system menu may not be set to "AUTO", but NTSC. This would cause a conflict when detecting PAL input and affect picture. Check the "Color System" and either select PAL or AUTO and see if that helps.
Sep 18, 2014 | Televison & Video
How do i change the system of bush btv180tsil tv/vhs pal I to pal BG
Just go to its menu option first. There you can change the sound system to PAL B/G, NTSC, andso on. Select the system to PAL B/G first. Then make an auto tune function, All the channels sorted by the TV will automatically tuned and stored in memory with PAL B/G only.
google.com/+GopakumarGopalan
Nov 26, 2013 | Televison & Video
Picture but no sound on Alba ALCD 1 5TV
on the remote you should have a button wth system if not go into the menu and look for system and change to auto or change to PAL I
SAVE AND EXIT
Jun 24, 2013 | Televison & Video
Alba alcd15tv. Speakers have stopped working! any ideas how to fix them? Thanks
I have an audio problem with one of these.....No audio and cant change the system setting from BK to I. I is the required setting for the UK which should then bring back the sound. Grandad H
Jan 12, 2011 | Alba Televison & Video
Alba tv plays xbox 360 games in black and white
This is an easy fix.
Within the xbox, goto system settings, and chnage the display output ot pal 50.
Problem solved!
Feb 11, 2008 | Televison & Video
Alba 3406 tvd
Connect pin 1 & 5 together (momentarily with a small switch), on the remote control handset. with the tv already switched on, This will put the set into the engineering set up mode. You can step between the various options by using the -/-- button. the Mute button invites you to save your changes which I believe is saved when you next press the -/-- button. there are 18 different service pages in all, be very careful not to change things which should be left alone, as this menu controls the way this set operates. The menu button exits the service menu. I believe menu 13 should be the AV-SND options menu, you can select either DK-I-BG or M sound systems. only set one system to "on"at any one time. You may also need to check 14, the C- SYSTEM options Menu. Good Luck, A D.
May 05, 2007 | Alba DVD-513 DVD Player
No sound
Go into the TV Menu and access the sound settings, for the UK it would normally be set to I. This MAY need to be changed to a different setting. Try the options that are listed. Might fix it!!
Jul 28, 2006 | Sanyo C40N
Dvd player split screen
Could be that some combination of the progressive scan and the line input is confusing your system. Sometimes the line doubler on the TV set causes this when recieving a 480p input. If this effect doesn't reproduce on another set, then there you have it. Try turning progressive scan off, or change between the analog(yellow) video, the component(RGB), and the S video(fat one with pins). Good luck
May 20, 2006 | Samsung SV-DVD3E DVD Player/VCR
kawasaki PVS-10921 Portable DVD Player Logo
109 people viewed this question
Top kawasaki Televison & Video Experts
Damen Wong
Damen Wong
Jaime Hernandez
Are you a kawasaki Televison and Video Expert? Answer questions, earn points and help others
