HI I HAVE BOUGHT A SITCOM 4 PORT CABLE ROUTER AND CANT SEEM TO FIND THE INTERNET SITE OR MY IP ADDRESS TO INSTALL THE WIZARD
  • 85 Answers
Open ur web browser then enter ur router default ip adress and configure ur router then it will work
Posted on Jan 26, 2009
How do i install and set router ip so it cant work
power on the router
1) plug rj45 (ethernet) cable into router, plug other end into laptop or pc
depending on how many ports this router has and how many cables you have (ethernet)
if you only have one ethernet cable. follow phase 1
open up internet explorer
insert the ip address of the router: 192.168.1.1
uername: admin / administrator
password is usally:admin / pass /password or sometimes just blank
once logged in, follow the wizard, which will be pretty simple to complete
let me know how you get on
Mar 08, 2011 | Linksys EtherFast Cable/DSL Router
Need hook up instruction
1.To hook up a router plug the internet cable into the port marked internet. If there is no port marked internet then plug it into whichever port is separated from the other bank of ports. If the ports are contiguous then plug it into the port marked 1.
2.Plug your other Ethernet cables into the remaining ports.
3. Follow the manufacturers instructions to install any necessary drivers. If you cant do that for some reason then you should go to http://compnetworking.about.com/od/workingwithipaddresses/f/getrouteripaddr.htm to figure out your routers IP address, then go to that address using your internet browser and follow whatever instructions/basic setup wizard it has.
Oct 16, 2010 | Computers & Internet
Cant find IP on hardwired PS3
is that modem setup to a computer before hand? you need it to be programed with a computer then after you access the internet, then hook up the modem to the ps3,
if you bought a new modem then you need to call your provider and have them program it
Jan 30, 2010 | Sony Playstation 3 (PS3) Console
My belkin router won't connect to internet, I set it up as the install wizard tells me but when it tries to connect to internet, it takes 10 tries and there is an error, it was a used router we bought so...
First, turn-off the DSL-modem (or the cable-modem).
Then, turn it on.
Check that you have a "straight-through" Ethernet cable -- all 8 coloured wires at one end must be in the SAME order at the other end. Do not use a "cross-over" Ethernet cable.
Check that the Ethernet cable from the modem is connected to the 'WAN' port on the router, not to one of the 'LAN' ports.
Turn the router off.
Turn the router on.
Reconnect to the router's web-interface, and see if the 'WAN' side of the router has obtained an IP-address from your ISP (Internet Service Provider).
Some ISPs require that you "register" the MAC (Media Acquisition Control) Address of each device that you connect to their service. So, browse through the router's web-interface, and find the "MAC-address" of the router, which will be different than the MAC-address of the network-adapter inside your computer, and telephone the ISP, and get them to "authorize" the MAC-address of the router.
Telephone your ISP -- they can "troubleshoot" your cable-modem from their end.
Nov 26, 2009 | Belkin (F5D7230-4) Router (587009)
Hi, i have wnr2000 and am trying to set it up. i'm at the setup wizard which says that i already have a valid internet connection. what does this mean and what do i do next?
Basically you need to sign up with an Internet Service Provider in your area. The ISP will advise you the type in modem/Internet connection you need for their service (ie. DSL or cable) and advise you or provide you with a compatible DSL or cable modem. The ISP will provide an installation disc or instructions to configure the modem so it connects with their Internet server.
The modem is then connected to the wnr2000 router's Internet/WAN port with a LAN cable.
If you have already configured the modem and connected it to the wrn2000 router and the setup wizard has detected that you already have a valid Internet connection (it has detected your TCP/IP address which your Internet Service Provider has given you - this IP address is your unique network address - it is similar to your house address in your street, in your suburb, in your state, and in your country). Just click OK and continue with the setup.
Oct 30, 2009 | NetGear WNR2000 Wireless Router
I cant install my wireless router. i moved and
we ll start with the physical connections.
1.take ethernet cable n connect one end of the cable to the modem and the other end to the isolated port on the router(internet port) and then connect the computer and your router with other cable(any lan port).refer the chart on the router to distinguish the internet and lan port.
2.check the light status on the modem and router.
router lite status-power,alphabet i lite,wireless lite(lollipop lite) and the number light lit up(depends on the port eg port no:1 connected number 1 light lit up).
3.check the ip address and default gateway address.
steps:In windows(xp,2000 etc),click on start->click on run->in the search tab type cmd->dos prompt window opens,type ipconfig and u ll get ip address and default gateway address(192.168.1.1 or 192.168.0.1).note it
In vista,start->in the search tab type cmd->dos prompt window type ipconfig->u ll get the address as specified earlier.
4.open the browser,type the default gateway address in the address bar and press enter.The login window ll ask for username and password. username-admin
password-password.
5.You ll enter the netgear smart wizard page.Run the setup wizard at the left side (blue screen).select yes and detect the type of connection.
6.If it is a cable modem-dynamic ip detected and click next.check whether the dns address is given automatically from isp and click apply.Then click on basic settings under setup menu and in that window in the router mac address select "use computer mac address "option and click on apply.Now click on router status under maintenance menu and check the ip address in internet port(it should not be 0.0.0.0) and in lan port(eg 192.168.1.2 or 192.168.0.2).
7.If its a dsl modem-the type of connection ll be detected as pppoe.click next.configure your router with the username and password provided by the isp and click on apply.The router ll save the settings and then check the internet port and lan port
address as given in the previous step.
8.Now we have to configure the router for wireless settings(both modems same configuration).
*click wireless settings under set up menu.
*In that page enter
name(ssid):netgear2
region:us
channel:11
. mode:g and b
In security options select wep and key1 give your telephone number so that you wont forget the password.CLICK APPLY.we have secured the n/w.
9.scan and connect to the network.
For windows vista-start->connect to->select the network name(netgear2)and click connect->it ll ask for password,enter it(telephone no).you ll successfully connected.Now disconnect the cable and try going online wirelessly.
For xp-start->control panel->network connections->right click on wireless network connection->select the network and configure.
10.you ll be able to go online wirelessly if there is any problem delete the preferred networks.
I have given you all the steps with examples to help you configure the router.hope you ll fix the issue and further assisstance im ready to help u but pls give details about your operating system,type of modem and no of computers so that it ll easy for me to troubleshoot.rate me if i have helped you.Thank you. Have a good day
Sep 25, 2009 | NetGear Computers & Internet
NetGear WGR614 -Installation Problem on Windows Vista PC
Please make sure that you have the NIC enabled and on the computer and set to automatic settings for IP address. Now follow the steps below to reset and reconfigure the router:
Reset:
At the back of the router you will find a small tiny hole (which has a small button inside it). Press the button with the help of a paper clip. and hold it down for 30 seconds. After 30 seconds, please release the button and power off the device for 5 seconds.
CONNECTIONS:
1. Connect a Ethernet cable from the modem to the WAN port of the router(isolated port).
2. Connect the computer to the router using any one of the 4 available ports. Please make sure that THERE IS NO DIRECT CONNECTION BETWEEN THE MODEM AND THE COMPUTERS (either using Ethernet cable or USB cable).
3. Power off the modem and the router after making the connections.
4. Power on the modem and wait for the lights, then power on the router.
RECONFIGURE:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router, usually with http://192.168.1.1 or http://www.routerlogin.com.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the username and password is case sensitive).
4. Click on 'Basic settings' from the left menu and select 'Use Computers MAC Address' from 'router MAC Address' section.
5. Click Apply.
6. Once it updates the settings then power off the modem and the router. Power on the modem and wait for the lights, then power on the router.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Jul 18, 2009 | NetGear WGR614 Router
Installation manual for router RP614v4 lost. need help in setting up router or manual.
To configure the router follow the steps below:
1. Connect a ethernet cable from the Modem to the WAN port of the router(isolated port).
3. Open the browser(Internet Explorer or Mozilla Firefox).
4. Access the router settings with the address: www.routerlogin.com/basicsetting.htm
5. Whenever prompted for username and password please enter User Name as 'admin' and Password as 'password'.
6. Click 'setup wizard'(at the top of list) from left menu.
7. Select yes and Click next.
8. In case you get the message: 'You already have a valid internet connection do you still want to continue', click 'YES'.
9. It should give you either a "Dynamic IP Detected" or "PPPoE detected".
10. If you get "Dynamic IP Detected" click on 'Next'. On the next page select 'Use Computer MAC Address' under Router MAC Address' and click 'Apply'.
11. If you get "PPPoE detected" click on 'Next'. Enter the login name and password provided by the ISP. Click Apply.
12. From the left menu go to 'Router Status' and check if you get the internet port ip address.
13. Click on 'Logout' (at the bottom of the list) from left menu.
14. Open up another browser window and try to access internet.
OR download the manual frm here:
http://kb.netgear.com/app/answers/detail/a_id/2153
Jul 03, 2009 | Computers & Internet
Router question
If your talking about configuring it. Go to http://192.168.1.1 that is your routers configuration page. (By default)
Jun 09, 2008 | NetGear RangeMax WPN824 Wireless Router...
How to use this unit as a Access Point for an existing Wireless Home Network
set the second router through the web menus to a different ip address, cant have 2 devices on the same (default) 192.168.0.1 address, try 192.168.0.2 (example only) to stop data collisions
connect by cable secondary router lan port 1 to the primary router lan port 4 (any lan port to any lan port),
drag secondary router upstairs on its cable and install it wherever you want
set two routers on different channels.
set all wep settings on both routers the same.
set all pcs to 'auto channel' select
wireless adaptors in pcs will then select strongest signal at any point and transmit thru that router
Feb 15, 2008 | D-Link AirPlus DI-614+ Wireless Router
Open Questions:
Toshiba Laptop doesn't start up. Black screen [Solved] -Dataalign If you are facing any kind of issues in Toshiba laptops or other products related to Toshiba brand, then you have come to the right place, as this article is an overview of where you can find the right kind of services, required for proper working of the gadgets by any tech savvy person, in particular the ones using Toshiba products. Another beneficial thing about using Toshiba products is its reliable Toshiba Customer Service , which can be reached any time for assistance with guaranteed satisfactory results. Toshiba customer care services are provided by highly efficient and knowledgeable tech support technicians having years of working experience in the field of providing dependable services to the customers of Toshiba. Toshiba support services provided by Dataalign are the best in class for their consistent services and highly advanced way of resolving tech issues faced by the customers. Dataalign tech support team comprises of expert technicians and they make use of high class technology for fixing the issues in Toshiba laptops and other devices as they have proper knowledge of all kind of issues with their perfect resolution. Dataalign technicians can be reached easily anytime from anywhere through the toll free helpline number +1888784-9316. Dataalign assistance providing Toshiba Tech support engineers are selected through a rigorous process of selection which makes them efficient for providing right support in minimum time with high accuracy. Technicians of Dataalign assist the customers in the most polite way with the assurance of providing highly accurate solution for every issue. For the answer of any kind of query related to Dataalign or for help regarding tech issues contact Toshiba support on their toll free helpline number.
Jun 21, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
