Question about Classic Design Concepts 105117: Shaker Hood Systems
Brand of my rangehood is CDC. we can not find that brand anywhere in melbourne. i want to find a fan for that. please help me. i am desperate.
Where can i purchase a complete filter tray for my rangehood made by Parmco
http://www.axial.co.nz/onlineshop/Rangehoods/rh-Parmco
Sep 18, 2014 | Refrigerators
Why baumatic rangehood BABT83.2AL stop working
Remove the filters and see if you can see the fan blade. Try turning the fan blade by hand. If its jammed up or tight, you may need a new motor. If it spins freely, turn on the rangehood and give the fan blade a spin . BE CAREFULL when doing this, if the motor starts up and runs properly after spinning it, it could be the start capacitor has failed. If it still wont run or if the fan is tight, you may need a new motor. Spare Parts should be available. You will have to trawl the internet looking for Baumatic parts suppliers in your area.
Jun 27, 2014 | Kitchen Ranges
Lights not working in Technika Rangehood (900m Model - D8900HASS)
TECHNIKA Pty. Ltd. 77 FILLO DRIVE, SOMERTON, VICTORIA 3062 PH 03 9948 4500 TOLL FREE
ABN 38 069 686 326 PO BOX 543, SOMERTON, VICTORIA 3062 FA X 03 9948 4555 1800 649 969
Online customer care contact for support: http://www.technika.com.au/contact
Dec 05, 2013 | Dryers
My rangehood fan won't turn off. Please help!!!
plug it out from the current socket probably the switch is sticking.service the switch by spraying contact cleaner if that does not help replace the switch.that means its bad and have a short.
Sep 13, 2011 | Microwave Ovens
Hi I have a WRF600 rangehood. It as stopped working, both the lights and the fan. Where are the fuses located?
Sorry to read about your problem, I hope this helps you out.
their are no fuses, check ckt braker
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Electrolux Kitchen Ranges
Service manual for rangehood
I asked a electician, it caused by start up capacitor fail.
Jan 14, 2010 | Frigidaire PLHV42P8CC Kitchen Hood
Some air blows downwards from rangehood
clog? or the shutter on the end wont open.
Nov 25, 2008 | Kitchen Ranges
Classic Design Concepts 105117: Shaker Hood Systems Logo
27 people viewed this question
Top Classic Design Concepts Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Classic Design Concepts Kitchen Range Expert? Answer questions, earn points and help others
