How do i reset a sony HCD-EC909iP 530w stereo that says "PROTECT" when i plug it in?
When the stereo gets plugged in it says "PROTECT" and wont do anything so i cant use it.
    Sergeant:
  • 316 Answers
Look on the back of the unit to see if you can find a reset button. If not then you may have blown an internal fuse.
Posted on Jan 13, 2013
Happens to us, too. We do what the manual specifies: disconnect from the electrical outlet and connect it again. Works even though it is a consistent and annoying problem this equipment has.
Posted on Mar 12, 2016
  • 4234 Answers
SOURCE: Protect
The protect message indicates that there is a problem with the output amplifier section. Verify that the speaker wires are not shorted together. If they are fine, there is an internal problem that is usually the output transistors. Your specific model I believe uses an amplifier pac (STK411-230). It should be replaced. It is available from tritronicsinc.com using part number VHISTK4113E-1 at a cost of $83.04.
Dan
Posted on Jul 21, 2008
dutchman05
  • 487 Answers
SOURCE: Protect screen on my sharp cd-ba150
that is your movement protection. In your manual it says how to get rid of it. mostelikely you have to push power and open button at same time
Posted on Jul 08, 2008
SOURCE: my lbt-xgrs sony full remot
Always be the audio amplifier IC fried need to be replaced
Posted on Feb 11, 2009
  • 6 Answers
SOURCE: Sony hcd gx450 blinking problem
your speaker are hooked up wrong.or there may be dust in or on the terminals.i used a q-tip with rubbing alcohol and wiped them down.hook up the speaker cords properly and try this again.if this does not work then unplug the stereo and let it sit overnight and try again.
Posted on Nov 16, 2009
  • 436 Answers
SOURCE: HCD-XG500 it says push power protect
Power protect tends to mean the main power amp chip has "blown" and needs to be replaced. It only costs about 20 dollars (10GBP). If you are handy with a soldering iron it is easy to do (after you get the thing to bits !) It is the big black thing on the big heatsink inside. The Sony part number is STK442 - 130. Seems a waste to throw the whole thing away for the sake of 10 pounds !. Hope this helps. Nik Howell (nh@totalise.co.uk)
Posted on Jun 16, 2007
Sony hcd-ec99i i have no sound from the speakers at all. I am not getting the protect message. please help
Check the simple stuff first
Is it muted?
Is the source selected sending signal (radio staion broadcasting, cd playing, ipod all the way ect)
Try doing some basic troubleshooting like,
see if all sources available yield the same result (TV, Radio, CD, Ipod, Aux jack)
When you turn the volume all the way up, do you hear an audible hiss from the speakers?(or use a test tone) If so, your amp is working and the problem is, your unit is not sending any signal to it.
If possible hook up your speakers to another system to rule them out, however I doubt that is your problem.
Here is sony's recommendation and a review video
Let me know what you get
SONY eSupport How to troubleshoot if there is no sound or intermittent...
Feb 03, 2014 | Audio Players & Recorders
Sony stereo protect mode
If "PROTECT" appears on the display: Immediately unplug the power cord, and check if anything blocking the ventilation holes on the back of the system after "PROTECT" disappears. After you have checked the ventilation holes and found to be all right, reconnect the power cord, and turn on the system. If the issue persists, contact your nearest Sony dealer.
The above is from the manual at http://www.docs.sony.com/release/MHCEC909IP.pdf
May 24, 2013 | Sony Mhcec909ip Mhc-ec909ip Mini Hi-fi...
My Sony HCD-EC909iP receiver won't turn on and the
Usually that is caused by a bad amp IC. Normally on this model, you would just replace the entire main pcb.
May 02, 2013 | Audio Players & Recorders
I cant get "PROTECT" off my Sony MHC-EC909iP Mini Hi-Fi System.
Disconnect the speaker wires from the unit. If it still says protect when you turn it on, then the amp ic has been shorted and needs to be replaced.
Feb 12, 2013 | Audio Players & Recorders
How do i reset my sony HCD-E909iP?
the amp is probably shorted and needs to be repaired. A reset will not fix this.
Jan 13, 2013 | Audio Players & Recorders
It wont turn on, it shows 'push power protect' when you turn it on, or disconnect it and reconnect, i already attempted to disconnect the Sony Stereo MCH-EC909iP Mini Hi-Fi and it shows 'Push Power, P
The only thing I can think of is its goin into protection mode like an amplifier would, you maxed the volume out and it's protecting your speakers or you don't have the right voltage going to it, I can see you don't have it on a straight 120v plug and you might have the wiring wrong on the speakers to it might be too low of a ohm or too high
Nov 22, 2012 | Audio Players & Recorders
"Protect" Blinking on Sony Stereo
may i see a diagram showing where the ic goes?
Nov 03, 2012 | Sony Mhcec909ip Mhc-ec909ip Mini Hi-fi...
Sony HCD-BC150 As soon as I turn it on, it shuts
Change the audio amplifier IC are on short circuit and that´s the cause your device goes to protect mode
Aug 11, 2009 | Sony DAV-BC150 System
Apr 27, 2007 | Sony LBT-XG500 Shelf System
2,774 people viewed this question
 Grubhead
Grubhead
