Question about Crown CTS600 2-Channel Amplifier
No power just cleick when pushed the power button.
I am work in my job in one Crown, it jus click but no light. My boss don't have schematic makin hard to fix it. I did tests on transistor all lik fine. I don't know what do with out schematic. If someone know please I need help. Thanks.
  • Josias Aleixo
    Josias Aleixo Jul 19, 2007
    Thank you for you help. I have to ask my boss for the manual. I have 2 this set with some problem. My boss don't like buy manual, but I'll ask he again.
    President:
  • 3,130 Answers
On a crown amp you will need a service manual man. That's like working on a Rolls Royce and trying to work on it with Toyota tools. Get the manual or do not wist your time, you will be spending loads of time on this if you don't. If you know where the diff. transistors are, check them out of circuit on high resistance.
Posted on Jul 06, 2007
How do I change the time on hugo boss watch
This is what I found.
The date is usually set by pulling the crown out by a single click. You can then rotate it anticlockwise to change the date one day at a time. If your watch features a day display as well, this is usually changed by rotating the crown clockwise. To set the time you should pull the crown out fully.
Dec 02, 2017 | Hugo Boss Watches
How do I change the day, date etc on a GENEVA 7391 watch
read the instruction manual, Geneva Watches with Two or Three Hands
  1. Pull the crown out until you feel a click.
  2. Turn the crown counterclockwise until you have the correct time.
  3. Push the crown back in to set the time.
Geneva Watches with Two or Three Hands and a Date Window
  1. Pull the crown out until you feel two clicks. This second click position allows you to set the time.
  2. Turn the crown counter clockwise until you have the correct time. Push the crown all the way in to set the time.
  3. Pull the crown out until you feel one click. This first click position allows you to set the date.
  4. Turn the crown counterclockwise until you have the correct date. Push the crown back in to set the date.
Multi-Function Geneva Watches
  1. Pull the crown out until you feel two clicks. This second click position allows you to set the day.
  2. Rotate the crown counter clockwise until you have the correct day. Push the crown in to set the day.
  3. Pull the crown out until you feel a second click to set the time or the 24-hour hand.
  4. Turn the crown clockwise until you have the correct time, then push the crown in to set it.
  5. Pull the crown out just one click to set the date. Turn the crown clockwise until you have the correct date, then push the crown in to set it.
Geneva Chronograph Watches
  1. Pull the crown out two clicks. This second click position allows you to set the time.
  2. Turn the crown clockwise until you have the correct time, then push the crown in to set it.
  3. Pull the crown out just one click to set the date. Turn the crown clockwise until you have the correct date, then push the crown in to set it.
  4. Stop and start the chronograph by pressing the PA button, located above the crown.
  5. Reset the chronograph by pressing the PB button just below the crown. The PB button returns the chronograph second and minute hands to their original positions of zero.
Automatic Geneva Watches
  1. Wind the mainspring by turning the crown 15 to 20 times clockwise.
  2. Pull the crown out until it clicks.
  3. Turn the crown counterclockwise until you have the correct time, then push the crown in to set the time.
Tips & Warnings
  • Do not set the date or time between 8 p.m. and 3 a.m. to avoid damage to your Geneva watch. The gears sit too close together during these times.
  • If your Geneva watch becomes wet, wipe it dry as soon as possible. Keep your watch away from saunas and hot tubs, as the extreme heat diminishes the watch's water resistance.
Read more : http://www.ehow.com/how_6134550_set-date-time-geneva-watch.html
Jul 13, 2015 | Geneva Watches
Brake Lights don't work on my 2008 Ford Crown Victoria
Have you checked the brake light switch to see if you have power going in and out ?
Jan 22, 2013 | 1991 Ford LTD Crown Victoria
How do I set and turn on/off the alarm function?
Hugo Boss Watches have a MOVADO watch movement the PDF Manual accessed via the URL below contains information on how to set the alarm.
URL http://www.movado.com/media/manuals/pdfs/hugo-boss/MDE_internet_EN_120514en.pdf
Nov 24, 2012 | Hugo Boss 1512657 Watch
Looking for instructions for a Seiko digital alarm chronograph solar powered back has 8n1913 the 8 could be a B. Thanks
seiko chronograph set the alarm etc pull the crown out 2 clicks.... set the alarm the same as your current time on your watch..... push the crown in 2 clicks..... than pull the crown out 1 click ..... set the alarm at the desired time with the lower button..... than push the crown in 1 click .... the alarm is ON
or go to this address http://caliber.seikowatches.com/ select the desired language than - alarm chronograph and play the alarm option on your right
May 14, 2010 | Watches
Stop watch hand
You have to reset your watch. Pull out crown to first click and try to move stop watch hand by pressing one of the pushbuttons. If this do not work, push the crown back in. Now pull out crown fully tto the second click and try to manipulate with pushbuttons again.
After resetting stop watch hand to 0 push the crown in completely.
Job done.
Nov 28, 2008 | Watches
Crown CTS600 2-Channel Amplifier Logo
213 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
