Question about HP Pavilion Slimline s3600f Desktop PC
Stuck on blue hp screen
Computer stuck on blue hp screen and will not recognized any keys on the keyboard
  • Anonymous Mar 01, 2009
    My computer is only a few months old ..was working fine and all of a sudden I got a blue screen instead of my desktop...it has a few options ...boot, recovey but the mouse wont even move and nothing can be highlighted. I unplugged everything and plugged it back in. Still the same. I hope someone can help me. Thanks
    Genius:
  • HP Master
  • 1,102 Answers
Have you added anything like memory or did win upgrade
make sure keyboard is securely plugged in
Posted on Jan 22, 2009
How do I get past the blue screen? Computer has been stuck on this for weeks. It has been rebooted, restarted, unplugged, still doesn't get past blue screen.
First unplug your machine and plug it back in and turn it on while its booting up you should see a message to press the F2 key to enter the BIOS. press that key, you will only have a couple of seconds to press it. Look for an option called First Boot Device, Boot Sequence, or something similar; press the arrow keys on your keyboard to select this field and then press Enter (You may have to select Advanced Options or another submenu to find it.) In the resulting screen, select CDROM/DVD and then press the Esc key until you return to the main BIOS screen. Follow the onscreen instructions to save your new settings and exit BIOS setup. Insert the installation disc (you need an installation disc of the operating system, if you dont have one you can find one on amazon, but if you needed to buy one you should consider upgrading to windows 7(more like vista) or Windows 8 (not really like vista)) once the disc is inserted restart the computer and follow the on-screen instructions
Nov 07, 2014 | HP Pavilion Computers & Internet
My HP Pavilion is stuck on the blue screen
While your system is still booting from start, keep hitting F11 to get past that point then proceed with the system recovery.
Nov 12, 2013 | HP Pavilion a6110n PC Desktop
I turned on my modem, an all that is displayed on my monitor is the blue hp screen. In the botton left hand corner it says <F10=Setup> and <Esc = Boot Menu> and in the right bottom corner, it...
what modem, who's and where, ?
or is modem , monitor?
which blue HP screen there are many,
you left out what it says...
i can not watch you boot, and what is displayed, is key to the cause.
NO OS stated, is this XP?
when you boot, it always prompts in text ,hit ESC key to enter setup"
this is the BIOS hot key prompt that some times shows
a cute small HP icon this too is BIOS created.
then the PC boots and goes to OS, there many OS offered
Windows is XP is one? is it?
or Vista.,w7,/8/10 or PS/2 or linux. HP has many offered OS.
as do Refurb companies endless.
if windows?, the windows log in screen is next.
so my guess is the PC goes to BLUE screen that, before that.
stating (presenting)
startup file failed?
or , HP recover failed.?
or any of 50 other windows blue screens of *****.?
why not post a photo of the screen?
one screen is the XP BSOD , crash screen.
seen here.
one other blue screen is "windows is doing updates" so let it??
one modern HP W10 screen 1 of 50
this is most times below a bad video card driver used on PC.
not matching card to OS. and bam crash.
Aug 28, 2017 | HP Hewlett Packard Pavilion Slimline...
I can`t get any upper case functions to work on hp 2011 keyboard what key do i press
1.Make sure the "Caps Lock" key is not on. Though this will be obvious to most people, if your keyboard is typing in only upper-case letters it can't hurt to check. Look at the "Caps Lock" indicator light on the top right corner of your HP keyboard. If the light is on, strike the "Caps Lock" key on the left side of your keyboard. This will turn the "Caps Lock" off, allowing you to type in lower case letters again.
2.Make sure the "SHIFT" keys on your HP keyboard are not stuck. Dust and dirt can build up on a keyboard over time, which can cause certain keys to stick. If either of your keyboard's "SHIFT" keys get stuck, your computer will type in only capital letters. Use a toothpick or cotton swab to remove the gunk from the key, which should help it return to its normal position.
3.Unplug your HP keyboard and then plug it back it. This will remove the device from your operating system and then automatically add it back in. This can have the same effect, essentially, as restarting your computer. If your keyboard was typing in capital letters due to an error being stored in your operating system's memory, that error will now be cleared and the HP keyboard will function as normal again.
4.Update your HP keyboard driver. Click "Start" and then right click on "Computer." Click "Properties" and then "Device Manager." Right click on the listing for your keyboard and then click "Update Driver." This will update the computer software that is associated with your HP keyboard. If your keyboard was typing in all capital letters as a result of an error with this driver, the error will now be fixed and you can use your keyboard normally again
Mar 01, 2011 | HP D8597A Keyboard
Keys on left side of keyboard are not recognized -- some ((#5, x) nothing happens. Others do another function -- R will minimize the screen.
Thins to try
1. Reboot your computer.
2. Reseat the Keyboard( disconnect it from the motherboard and reconnect it)
3. Go to Ebay and order your self a new keyboard. >$20
Dec 16, 2010 | HP Pavilion dv73180us (WA718UA) PC...
My keyboard will not work
Keyboard Is Dirty:
Keyboards should be cleaned with "spray-n-wipe" cleaner and a cloth or tissue on a monthly basis. Ensure that computer is not powered up while cleaning the keyboard. Compressed air can also be used to clean between the keyboard keys. Another tip: clean the keys with a cotton swab dipped in alcohol.
"Keyboard Not Found" Message:
Your keyboard is not plugged into the computer securely. Unplug it and plug it back in and the problem should go away. If this doesn't work, follow procedure: "Computer isn't taking inputs from keyboard" (below).
Key Is Stuck:
1. If a key does not work or is stuck in the down position, you may try to remove it with a CPU "chip puller" tool. These simple "L" shaped tools are great at pulling out keys. Once you've pulled out the stuck key, you can try to stretch the spring to "reanimate" its action.
Computer Isn't Taking Inputs From Keyboard
1. Is keyboard connected to computer? Ensure that the keyboard is plugged into the keyboard jack and not into the mouse jack. If the keyboard was unplugged, plug it back in and reboot the computer.
2. If the keyboard still doesn't work on boot-up, power down the computer and try to borrow a friend's known-good keyboard for troubleshooting. Plug the new keyboard up and boot up the computer. If the new keyboard works, the old keyboard is bad and needs to be replaced.
3. If the known-good keyboard doesn't work, check your BIOS to make sure it sees the keyboard. It should say, "installed." If the BIOS recognizes the keyboard, then you probably have a bad keyboard port.
I Plugged Keyboard Into Mouse Port
1. Many mice and keyboards today use a PS/2 connector
. If you plugged your keyboard into the mouse port (or viceversa), follow steps 2 and 3.
2. Shut down the computer and plug the keyboard into the keyboard port. The keyboard port is usually marked with a "keyboard" symbol. Plug the mouse into the mouse port (usually marked with a mouse symbol).
3. Reboot the computer; the keyboard should work now. If keyboard doesn't work, check your BIOS to make sure the BIOS recognizes the keyboard. You should see the words, "installed" or "enabled" under the keyboard.
4. If the BIOS recognizes the keyboard but it still doesn't work, you may have a bad keyboard port.
I Spilled a drink on my keyboard!
1. If you spill any liquid in the keyboard, turn it upside down ASAP. Drain all the water out of the keyboard, shaking it if necessary. If you've spilled water into the keyboard, just let it dry. You may use a hair dryer to dry out area under the keys (remember, too much heat and you could damage the electrical components).
2. If you've spilled a soda into the keyboard, completely rinse it in warm water. No soap please! You may use a hair dryer at this point or just let it dry for 2 days. Ensure the keyboard is perfectly DRY before you attempt to use it again. Don't plug a wet keyboard into electrical equipment. Think safety.
5. If the keyboard still doesn't work, replace the keyboard.
Nov 13, 2010 | Dell Computers & Internet
Turn computer on, oes to the hp screen with the f-key options, when I press any of the f-keys no responce, not even from the esc key option which is boot menu. Looks like keyboard is recognized as my...
It is possible that the bios is set to not support legacy usb devices. if this is the case you may have to get a ps2 style keyboard to go in and check it. Otherwise your keyboard could be bad. check it on another computer.
Or your USB drivers could be no good or faulty. reinstall motherboard drivers from the manufacturer.
Mar 09, 2010 | HP Pavilion Slimline s3700y Desktop,...
My compute (slimline s7520n) will show the blue hp invent screen then atomatically send me to phoenix - AwardBIOS CMOS setup utility
You may have a stuck Function key on your keyboard or Escape key. Make sure these aren't stuck and try a reboot.
Feb 28, 2010 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
My wireless is stuck on disable. HP Pavilion dv7
Well there is 2 things you can do. One is the QuickPad at the top of the laptop, there is a blue antenna figure at the top right and if it is on blue, then it is on, if orange, then off. Run your finger across it and it should turn on. Another way is on the taskbar at the bottom, you will see a computer monitor with a globe in front of it. Click on that and connections and the ability to turn on your wi-fi will be all there.
Nov 16, 2009 | HP Pavilion dv7-1130us laptop
Keyboard doesn't work
If you have droped any kind of liquid on the keyboard get it replaced
Apr 17, 2009 | Computers & Internet
HP Pavilion Slimline s3600f Desktop PC Logo
615 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
