Question about kawasaki Full Suspension Mountain Bike Men
05 750 brute force missing badly
I have a 05 kawasaki brute force it started just missing a little now it is bad unless i choke it then it does fine but as soon as i flip the choke it misses it will idle but soon as i give it some gas it spits and sputters and then it dies i sprayed carb cleaner down the carbs drained the gas line put new plugs in and it is still doing it
Just had same problem. Take carbs off and clean all jets and bowl. Be carful front and rear carb have different sized jets. When you put quad back together put entire airbox together even the cover. This quad will backfire unless air box is complete. I bet you anything your carb is full of trash.
Posted on Jan 22, 2009
To be honest with you i have the same quad and its the same age, ive just had to spend a fortune on it because the engine seized solid for no reason, i had a honda 350 before this kawasaki and im going back to honda. im NEVER going to buy another kawasaki, its been nothing but trouble from day one!
Posted on Oct 27, 2009
  • 65 Answers
KAWASAKI V-TWIN ATV CARBS GET DIRT IN THEM ALL THE TIME AND THE AIR JETS GET CLOGGED. CLEAN CARBS PILOT JETS ARE CLOGGED
Posted on Apr 30, 2009
Valve adjustement and carb syncronization will help your problem, make sure that the carbs are sitting properlly in the carb boots, and tighten the clamps properlly.
Posted on Apr 12, 2009
I have a 2005 brute force 750 won't start with electric start it will start when I pull start it will run.when it's running the lites and display are flickering .
Sounds like your battery is about dead... replace the battery and clean the connectors/wires/terminals.. and a little waterproof grease will stop the corrosion. Make sure the new connections are tight!
Jan 25, 2017 | kawasaki 2005 Brute Force 750 4x4i
Hit the start button and nothing happens 2008 750 brute force
Check your starter solenoid. You can trace it by following the power wire from the battery to the small solenoid block that contains a 30 amp fuse. You can bridge the posts on the solenoid by using needle nose pliers or whatever else you may have. If it starts up or you hear the starter run, you have a bad starter solenoid.
Feb 02, 2016 | kawasaki 2008 Brute Force 750 NRA OUTDOORS
My 06 Kawasaki 4 wheeler. Backfires when light switch is on going down highway. Is it battery related ?
Problem with Brute Force, please save my 4-wheeler from shop ...
www.kawieriders.com > ... > Kawasaki Brute Force/Prairie/Bayou
Nov 16, 2011 - Problem with Brute Force, please save my 4-wheeler from shop! ....2007 kawasaki 750 4 wheeler backfire problem ... should I save for my brute force 750? moe, Kawasaki Brute Force/Prairie/Bayou, 3, 10-18-2010 06:55 PM. Backfire thru exhaust
Feb 24, 2011
Low RPM Backfire Through Carb
May 24, 2010
four wheeler keeps backfiring
May 9, 2010
06 brute force 750 poping and backfire
Feb 18, 2010
More results from www.kawieriders.com
Oct 08, 2015 | kawasaki Motorcycles
05 kawasaki bf 750...battery was low......put a new one in..........now backfires out the exhaust.......tried the belt reset.....didnt help......suggestions.?.....
Brute force backfire problem - YouTube
? 1:06
www.youtube.com/watch?v=VFxGBYoVFqk
May 5, 2013 - Uploaded by gubba1957
I bought this 2006 750 it had a backfire problem when I bought it so I cleaned ... 2005 Kawasaki Brute Force 750 - Stock Exhaust Modification ...
Oct 03, 2015 | kawasaki 2005 Brute Force 750 4x4i
Why does my 650 brute force pa pa at low speed or down hill
Sounds like bad gas or water in the gas. Could be needing rebuild in the carbs. Start by trying some sea foam in your gas tank.
May 28, 2014 | kawasaki 2008 Brute Force 650 4x4i
I have a 2005 brute 750. It will start and idle fine, but when you give it gas it begins to miss and backfire through the carbs and tail pipe. I just took the carbs off and cleaned the jets, new plugs and...
If it just crossed the 100hr mark the Check Belt function of the ECU will be activated. Perform the Belt Light Reset if is crossing a 100hr mark on the odo
Jan 20, 2018 | kawasaki 2005 Brute Force 750 4x4i
Electric start cliking, lights flicker when running
if you have a volt meter, check the battery cables for voltage when its running. if you read above 12 volts, then your charging system is fine - replace the battery. if less than 12 volts, then you have a bad stator winding and will need to have the charging portion of the stator replaced. probably about a $300 part.
Nov 22, 2009 | 2006 kawasaki ZZR 1400
kawasaki Full Suspension Mountain Bike Men Logo
1,560 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
michael
michael
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
