Question about Bosch Washing Machines
My Bosch Nexxt DLX series has an E:04 error code
    Sergeant:
  • 291 Answers
The E04 code is a blocked pump code.
You will need to remove the round door on the bottom right hand corner of the front panel. Behind that door is a cleanout handle on the pump. You will need to unscrew that and clean it out. When you take the cleanout off there will be some water in the washer so put a pan under it OR have some towels handy. Or better yet a shop vac with the paper filter removed. You can loosen the cap about a full turn and another quarter turn before water will start to slowly flow from it. With a shop vac you can suck the water up while controlling the flow with the cap. Easy peasy. Once the water stops unscrew the cap all the way and pull the basket out. If it\'s really full it can kind of act like it\'s jambed in there but it will come. Dump the crud and don\'t forget to check the hose that goes from the tub to pump for debris. Also make sure the impeller inside pump will move and doesn\'t feel cocked to one side. If you have it put a little petrolium jelly around the threads and o-ring of the basket cap before reinstalling it. It will make removal easier the next time you clean it. If you have trouble let me know.
Posted on Jan 13, 2013
SOURCE: Bosch Nexxt 100 Series washer
Bosch Nexxt series 100 place clothes in machine start add detergent as always machine begins to add water for about 30 seconds then stops , sometimes stops and sounds like it is trying to drain sometimes just stops and won't unlock door even if you turn machine off. Sometimes if you switch from hot to cold washer will work just fine for a couple of days then back to just stopping.
Posted on Sep 23, 2008
  • 38 Answers
SOURCE: error code 02 on a newly installed Bosch Nexxt Washing machine
This is a trouble code for a fill that is taking to long. Make sure that both the hot and cold water valves are turned on. Hope this helps.
Posted on Jul 28, 2009
  • 228 Answers
SOURCE: Hello! My Bosch Nexxt series 300 washing machine
e 13 is a door lock error if you are lucky you may have a manual release check where filter is for a red pull release this mechanically activates the door to retrieve trapped washing,if not lock will need replacing engineer visit unfortunately.
Posted on Aug 05, 2009
  • 10 Answers
SOURCE: My brand new Bosch is not draining and is showing E:13 error code
Put the washer on cold and run "TWO" cycles. There is too much soap or fabric softner.
Posted on Nov 27, 2009
barkencoa
  • 3463 Answers
SOURCE: bosch 100 series will not drain
You need to check and clean the pump filter if you have not already done so.
This is located at the bottom front right of washer.
Unscrew anti-clockwise to remove and clean.
Posted on Mar 15, 2010
My Bosch Nexxt DLX Dryer is not getting hot
you need to reset the high temp sensor. its in the back next to the vent. you might be able to use a long screw driver and push it in. Mine is just about an inch above vent and on the right side. Use a flashlight to look in and you should be able to see it.
Mar 23, 2013 | Bosch Nexxt DLX WFMC4301UC
Replacement part
Bosch Nexxt DLX WFMC4301UC door seal replacement
parts
This video will show you how to change a door seal on this Bosch front loader washing machine and the best
places to buy parts.
we have all
bosch repairs in our channel
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 11, 2010 | Bosch Nexxt DLX WFMC4301UC
Bosch Nexxt 500 Series Front Loading Washer
The only way is to disonnect the device from the controller board.
Sep 12, 2009 | Bosch Classixx WVF 2402 Front Load...
Mar 28, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Bosch Nexxt 500 Series Washer Will Not Add Water
during a normal wash cycle the washer stopped and gave an e;4 error code
Dec 21, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Washing Machines Logo
71 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
