My cooker is beeping and flashing E1
SOURCE: hamilton beach 20 cup rice cooker
The rice cooker should have markings on the side of the pot. This indicates the water level for a given amount of rice. For instance, if you add 4 cups of rice, you add water until it is level with the 4 mark.
SOURCE: Rice cooker stopped working
Sounds like the Thermal Fuse inside is blown unscrew the 2 screws on bottom of the cooker you should see a small 2.5 inch insulation wrapped wire leaving a ceramic mounting block to one of the element poles. Now you take off the nut and unscrew it from the pole. Cut off the insulation and underneath will be a Thermal Fuse. If you have a Ohm Meter or a continuity tester attach each lead to either side and it probably will test negative. Part # is written on the Thermal Fuse. Probably a
SEFUSE
SF188E
192C
10A
250V
They are for sale on ebay for $9.99
I'm trying to get mine cheaper elsewhere
SOURCE: I bought a Hamilton Beach
yes, for a mediun grain rice , standard is 2 cup rice/3 cups water yield is about 6 cups cook rice
SOURCE: I am curious to know if this cooker can be used in India
You will need an adapter for the plug so that 110 volts and also is a plug converter
SOURCE: How much does a Hamilton Beach chrome slow cooker cost?
These slow cookers come in a variety of sizes and prices. The price range is $20-$50. You may be able to find one on amazon.com for cheaper; however department stores such as Sears sell a wide variety of slow cookers at reasonable prices.
Here is a tip that I wrote
that will help you with using your rice cooker to steam
your veggies...
How
to Steam Vegetables in your Rice Cooker
heatman101
