Question about Casio Wave Ceptor WVA430A-1AV Wrist Watch
Why do i get a G in the time zone on casio watch
When adjusting the time zone I get down to 0.0 the get a G come up. Why is it
  • 65 Answers
G in combination with 0.0 is the GMT (Greenwich Mean Time) or UTC.
Posted on Feb 06, 2014
skyreacher36
  • 74 Answers
SOURCE: Lost the manual. Son reset watch. I've reset the
go to www.casio.co.uk go to support(methinks??) click on watches and put in the model number (the one you posted) and download the PDF manual relating to your watch (you will need adobe reader free download to read PDFs), this will be the full manual, once you figure it out DST will have to be on, as its summertime of course. ( i bought a wave ceptor for a fiver because the guy who had it didnt know how to recalibrate it after a battery change), a quick gander at the online manual put it right, there shouldnt be a problem setting it up again, good luck
Posted on Aug 05, 2009
  • 12 Answers
SOURCE: Adjust-a-Casio-S-1087DY-Watch-Band
On most brands, there are pins that form hinges for the links of strap. You need to push them out to remove links. Usually you would find arrows marked from inside of the metal bracelet which show you the direction in which to remove the pins. You can remove it if you have a small watch maker's screwdriver but you have to be careful. or get one of these ..
http://www.amazon.co.uk/Watch-bracelet-link-adjuster-remover/dp/B001ZKIL2S/ref=sr_1_1?ie=UTF8&s=watch&qid=1254695541&sr=8-1
which should help you to remove the link pins safely without scratching.
Posted on Oct 04, 2009
SOURCE: battery replacement for casio wave ceptor wvq-200hu WATCH
Download abridged instructions from casio @ http://world.casio.com/wat/download/en/manual
Posted on Jan 01, 2010
  • 2501 Answers
SOURCE: i have a casio (phys) sports cant adjust it
You can download a set of instructions from the Casio web site.
Go to "casio.com" and select "support", then click on "manuals", choose "watches" from the list, agree terms and conditions.
On the next page fill in the details off the watch back and click on search.
You can then choose your manual and download.
Posted on Jan 26, 2010
SOURCE: casio pathfinder SPF 70-s titanium band adjustment
I purchased a Casio Pathfinder solar/atomic watch, with compass, altimeter, barometer, thermometer, model 1200T-7WC (titanium).
Has the titanium band - on this particular band each link is somewhat waveshaped {i.e., there are 2 "arms" from the link making contact with the middle part of the link above (above meaning towards the watch body), and 1 arm fitting between the 2 arms of the next link down). Unlike described in the first solution, the pin is not split, but solid (doesn't look like a slotted screw on 1 end, so the solution at http://www.wikihow.com/Adjust-a-Casio-S-935L-Watch-Band is no help). Here's what to do if you have this band:
1. Note: before you start, be advised there is a tiny loose 1/8" part (sleeve) that will fall out as you pull the links apart, so work over an appropriate surface to "catch" it. Push pin (from the upper "arrow end) of one of the removeable links (those with the arrows on the backside) out of its hole with a fine poker (I used a 1/32" jeweler's screwdriver, an unbent paperclip would also work, just more likely to bend as you push pin out). This takes some force to do - in my case, after pushing, the pin projected out about 1/2 of it's length, I used needle-nosed pliers to gently pull it out the rest of the way). CAREFUL - once pin is removed and you pull the link away from the one above, a small (1/8") constriction sleeve should fall out of the center arm of the link above. SAVE THIS SLEEVE!
2. Using the same procedure, remove the pin from the bottom end of the link you're removing. again, SAVE THE SLEEVE.
3. to rejoin the band once the link is removed, look at the single/middle "arm" of the upper link, looking for the hole where the pin goes through. One side of the hole should be noticeably larger/wider than the other side - this is where you will place the SLEEVE - I used tweezers, or needle-nosed pliers will work - it will drop into hole. Keep this upright so that sleeve doesn't fall out, and slide the 2 arms of the lower link in place around the center arm.
4. Slide the pin you removed into one of the outer link arm holes - I found it easier if I started from below, pushing it into the center arm - it will stop when it reaches that 1/8" constriction sleeve. I set the extruded end on the pin on a magazine (i.e., slightly padded surface) and then pushed the top side of the band down, forcing the pin through the constriction sleeve and up into the upper arm hole, and Voila, your band is reconnected. The sleeve is important (without the sleeve in place, the pin will simply fall back out).
Posted on Mar 07, 2010
When I set my casio wave ceptor to my timezone and set the time correctly, the hands move to a different time. Both hours and mins. are off. When I set to zone 0, both hours and mins are correct. I am...
If your watch is exactly an hour out, then you need to set the daylight saving time (DST) via the mode button.
If this is not the case, then I cannot help you.
~Good luck
Mar 31, 2011 | Casio Watches
How do I set my Casio G-Shock watch?
This depends if you want to use the autoreceive mode or not. If you're within an area that you can pick up the signal, it should set itself automatically at 3AM, 4AM and 5AM. You can force it to try and calibrate to the broadcast signal by holding down the receive button while in the "normal" time mode. For best results, put it near a window that faces Colorado (assuming you're in the states) with the top of the watch facing the window.
To turn on or off the autoreceive mode:
From the time mode, hold down the Adjust button until the watch beeps and your time zone is flashing at the bottom. Press the Mode button twice so [ON/OFF] Auto is flashing. Press Receive to toggle the mode, then press Adjust twice to set.
If, for whatever reason, you're unable or don't want to use autoset, to manually set:
From the time mode, hold down the Adjust button until the watch beeps and your time zone is flashing at the bottom. Press the Adjust button again and 12H/24H will be flashing at the bottom. Press mode again and seconds will be flashing. Mode once more and the hours will be flashing. Use Time Memo/Receive to set it to what you want. Press mode again and minutes flash. Again, use Time Memo/Receive to set it to what you want. Repeat for year, month & day. Press Adjust to finish chaning the time.
Mar 16, 2011 | Casio G-Shock GW500A-1V Wrist Watch
How do i get my g shock out of military time
From the main time display, hold down the adjust button until it beeps and your time zone is flashing on the bottom of the display. Then press adjust again. 12H or 24H will be flashing at the bottome. Use the receive button to cycle the mode. When it's what you want, press adjust.
Mar 14, 2011 | Casio G-Shock GW500A-1V Wrist Watch
How do you set the time to dst.
From the main time display, hold down the adjust button until it beeps and your time zone is flashing on the bottom of the display. Then press the mode button once. [AUTO/ON/OFF] DST will be flashing on the bottom. Use the Time Memo and/or Receive buttons to cycle the mode. When it's what you want, press adjust twice.
Mar 13, 2011 | Casio G-Shock GW500A-1V Wrist Watch
On my Casio G-shock GW500A, the time is off. i dont want it on 24time and its an hour ahead
Sounds like you're set for the wrong time zone, and your 12h/24h setting is off.
To change time zone: Hold down the adjust button until it beeps. Your time zone will be flashing at the bottom of the display. Use the Time Memo and/or Receive buttons to change it to the correct time zone. Then... To change to 12H mode: Press adjust again. 12H or 24H will be flashing at the bottom. Use the receive button to cycle the mode. When it's what you want, press adjust once more.
Feb 26, 2011 | Casio G-Shock GW500A-1V Wrist Watch
How do i change the time setting from 24 hour to your average 12
For all those who lost their Casio watch manual. Follow this link, fill in the requested details and download manual. http://world.casio.com/wat/download/en/manual/
Nov 12, 2010 | Casio G-Shock GW500A-1V Wrist Watch
Got mine yesterday and its set on eastern time zone, i need pacific time zone and it will not sync, how to manually adjust ime
You should be able to set your watch to the Pacific time zone.
f you haven't got instructions on how to do this, you can get
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
You shouldbe able to find the setting method in the manual.
May 12, 2010 | Casio Atomic Timekeeping WV58A 9AV Watch
I need a manual for my casio wave receptor
Jan 14, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
G-shock Wavecepter is 1 hour to fast
(I posted this solution elsewhere but it should help you as well.)
Firstly, the manual that comes with these watches is absolute garbage,which is a stark contrast from the watches themselves. ( I love casiowatches - high value)
The good news is that Casio DID make a good manual for these wavecptor watches. If you go to this url
you will be at a spot where you can type in your 4 digit module numberand get a great document that tells you how to operate your unit andsome of how it works. (Adobe Acrobat - PDF file)
You should be able to hold in the "Adjust" button until the time zone starts flashing and push "Time Memo" and/or "Recieve" buttons until you are in the right time zone. Push "Adjust" again and your are done. The Manual above was very useful for me.
Hope that helps. :-)
Dec 05, 2008 | Casio G-Shock GW500A-1V Wrist Watch
My G-shock wavecepter is 1 hour fast. I can't seem to get it to set to the proper time. I live in Oregon on in the Pacific Time zone. My watch is set to LAX. DLS is off and when I tried it on it jump to 2...
This url (below) has a REAL manual for your watch, not the worthless one that comes with the unit.
You can type in your 4 digit module number and get a great document that tells you how to operate your unit and some of how it works. (Adobe Acrobat - PDF file)
The solution involves holding down the adjust button until the time zone starts flashing, adjusting with the right 2 buttons and pushing the mode button to get to other options. You then finish by pushing the adjust button again.
Casio Wave Ceptor WVA430A-1AV Wrist Watch Logo
50 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Jimmy Accardi
Are you a Casio Watch Expert? Answer questions, earn points and help others
