Question about Whirlpool LHW0050PQ Front Load Washer
We were given this washer. it has been unplug for a lenth of time. we need easy step by step instructions on how to reprogram it.
    Sergeant:
  • 291 Answers
You can get the manual here:
http://www.searspartsdirect.com/partsdirect/part-model/LHW0050PQ
Posted on Jan 13, 2013
Lenth of time for washes taken 2 long
That varies from washer to washer and it also varies with the size of the load in the washer.
Oct 26, 2016 | Washing Machines
How do I delete preset stations? I can add a new preset, but I have to go through all the presets to get to the station I want. I would like to delete a number of them.
The backup battery needs to be removed from the clock radio. Then, unplug the device from the wall and count to 15. Plug the radio back in and see if the presets have been purged. Unplug the radio again for safety, reinstall the backup battery, plug the radio back into the wall and begin reprogramming.
Now, if you really don't want to have to reprogram all your stations, I suggest you look at the company's website for a free download of the user manual which will give you step-by-step instructions on reprogramming the radio.
Feb 03, 2016 | Audio Players & Recorders
Change on board charger to off board charger
Not an easy job. There are parts that need to be installed on the scooter and wiring changes that can't be given here step by step. Have a service center give you options to consider.
Mar 13, 2014 | Pride Sonic 3 Wheel Portable Scooter
I need an unlock code my imei is 357380048477090
You can get the unlock code for Nokia 1280 phone at reasonable cost from TheUnlockArena.com and unlock it with given easy step by step by step unlocking instructions.
Dec 21, 2013 | Nokia 1280 Cell Phone
My Washer Is Locked!!!!!!
Hello kandlelady_1 - Let's try reprogramming the washer by flipping the household circuit breaker off or unplugging it. It is important to wait roughly ten minutes and then turn the washer back on. If these troubleshooting steps prove ineffective, you may wish to contact a professional as the unit may possibly be experiencing a communication error with the control board, faulty door lock switch or a potential wiring failure.
Jun 30, 2013 | Frigidaire ATF6000ES Front Load Washer
Won't respond
Installation instructions:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
I would recommend verifying that the batteries are new and installed correctly. Under normal circumstances there is no need to reprogram the lock codes when batteries are changed.
I did see that if the bolt does not extend when the lock button is pressed that you need to reprogram the handedness of the door (see Step 4.9).
On page 9 of the installation instructions is Troubleshooting tips and a contact number for Kwikset USA :
1-800-327-5625. I'd recommend calling them directly if, after going through the installation instructions, that you have the same problem.
A note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:
http://get.adobe.com/reader/
Good luck--and please provide feedback if this helps!
Nov 18, 2010 | Kwikset 907 907-15 Satin Nickel Powerbolt...
Cannot program a replacement transmitter.
unplug your antenna and short out all the terminals on the antenna together then try again
Jun 05, 2010 | Remote Start System
Power surge - washing machine Not turning on.
Instructions Things You'll Need:
  • GE/ lg washer
    Primary Method---Newer models
  1. Step 1 Unplug the washer.
  2. Step 2 Twist the control dial around the cycle settings.
  3. Step 3 Place the dial on any setting other than the final spin.
  4. Step 4 Ensure that the water line is securely attached to the washer.
  5. Step 5 Plug the washer back into the wall (making sure it has gone at least 30 seconds without power).
  6. Alternate Method---Older Machines
  7. Step 1 Turn the dial around the cycle settings, but do not lift it to start the cycle.
  8. Step 2 Unplug the washer.
  9. Step 3 Plug the washer into the wall after 30 seconds without power.
  10. Step 4 Lift the washer lid five times, making sure it reaches a height of at least 6 inches or more. There should be no more than a 15-second interval between lifts.
  11. Step 5 Listen for a clicking noise. If a click is not heard, repeat steps 1 to 5 until you hear it.
  12. Step 6 Place a small load of laundry into the washer and start the cycle.
  13. Step 7 Watch the load throughout the wash to ensure the washer is working properly.
Dec 26, 2009 | LG Washing Machines
The washer won't drain the water
Hello there
Please try these easy steps that i have written for you
  1. 1 Checkhose for kinks. Straighten hose best as possible or replace. If hose islooping gravity may be the problem. Try cutting off excess.
  2. Step 2 Testlid switch for "click". If you don't hear this "click" you may tryreplacing it by ordering a new one from the manufacturer and followinginstallation instructions. Fairly easy job for a do-it-yourselfer.
  3. Step 3 Check beltsto see if they are loose or broken. Most washers have removable panelsthat let you get to the pumps, motors and belts. Belts can also be doneby a do-it-yourselfer but can get tricky, you may want to seek a friendwho has some belt experience.
  4. Step 4 Check hose that connects tub and pump. Remove hose with bucket and rags close by, check for obstructions.
  5. Step 5 Check pump with voltmeter could be an actuator(a value that controls what flow). Not a good idea to play with water and electricity2_bing.gif find someone who knows what they are doing.
  6. Step 6 Listento pump. If it sounds like it's trying to pump but the water is notmoving, it could be something stuck in the pump. Remove pump and clean.Again another moderate job for a do-it-yourselfer. Unplug machine frompower source before and remember some electrical equipment will hold acharge even after unplugged.
  7. ok I hope that this is very helpful for you
  8. Best regards Michael
Nov 21, 2009 | Frigidaire ATF6000ES Front Load Washer
Error E10
Step 1 go to http://www.frigidare.com
Step 2 click on CUSTOMER SERVICE on top of page
Step 3 go to PRODUCT MANUALS and click on DOWNLOADS
Step 4 type in MODEL NUMBER and click on SEARCH
Step 5 your error code information is in the TECH DATA file there you can perform a full system check PLEASE READ ALL WARNINGS POSTED
STEP 6 Also access and save, or print PDF files: OWNERS GUIDE, INSTALLATION INSTRUCTIONS, OPERATING INSTRUCTIONS, and PARTS MANUAL(These PDF files will help in replacing, repairing, and maintaining your machine.)
Step 7 save all PDF files to a new folder name it FRIGIDARE for easy availbility for printing and viewing.
Thank you and good luck.
May 21, 2008 | Frigidaire GLTF2940ES Front Load Washer
Whirlpool LHW0050PQ Front Load Washer Logo
52 people viewed this question
Dan Webster
Dan Webster
Sal De
